I've written a class that synchronizes a table between two databases using Dapper. The public and private Methods in the class are generic and the generic parameter is the POCO class that is being synchronized.
var Sync = new syncClass(localConn, remoteConn);
await Sync.SyncTable<myTablePoco1>();
I feel a little back story will help:
For simplicity sake, I want to wrap all of the synchronization inside a serializable transaction(pushing and pulling), so that if anything goes wrong, I can rollback.
Next, I want to synchronize multiple tables and trying to come up with an appropriate way manage the multiple tables. The consumer could write multiple lines:
await Sync.StartTransaction();
await Sync.SyncTable<myTablePoco10>();
await Sync.Complete();
I was trying to find a way to encapulate all of the table syncing like so:
Sync.AddTablePoco(typeof(MyTablePoco1));
await Sync.SyncAllTables();
Public async Task SyncAllTables()
foreach (var pocoClass in TableList)
Sync.SyncTable<pocoClass>(); <-- compiler does not like this
I have started to re-write all the generic methods to something with a signature like this:
public async Task SyncTable(Type tableEntity)
At some point down the line of converting I run into this scenario :
private async Task<Ienumerable<?>> FindRecordsToSync(Type tableEntity) <--cannot return a generic type How to handle this
(This method uses Dapper's QueryAsync<T>
Do I need to use Dynamic types? Is that a code smell?
I'm a little stuck and looking for some direction on how to accomplish this.
How can I do this? Do I stick with the generic methods and just define all the syncing at compile time? Or is there a more elegant/cleanway?
(I've looked into reflection as an option to invoke a generic method, but would prefer a non-reflection way.)
More Code Added:
public static async Task<int> UpsertAsync<T>(this IDbConnection db, IEnumerable<T> entitiestoUpsert, IDbTransaction transaction = null) where T : class
var contribType = typeof(SqlMapperExtensions);
var type = typeof(T);
var tableName = contribType.GetTableName(type); //GetTableName
var sbColumnList = new StringBuilder(null);
var allProperties = contribType.TypePropertiesCache(type); //TypePropertiesCache(type);
var keyProperties = contribType.KeyPropertiesCache(type);// KeyPropertiesCache(type).ToList();
var computedProperties = contribType.ComputedPropertiesCache(type);// ComputedPropertiesCache(type);
var allPropertiesExceptKeyAndComputed = allProperties.Except(keyProperties.Union(computedProperties)).ToList();
//added need to include key column for upsert
var allPropertiesExceptComputed = allProperties.Except(computedProperties).ToList();
var explicitKeyProperties = contribType.ExplicitKeyPropertiesCache(type); // ExplicitKeyPropertiesCache(type);
if (keyProperties.Count == 0 && explicitKeyProperties.Count == 0)
throw new ArgumentException("Entity must have at least one [Key] or [ExplicitKey] property");
keyProperties.AddRange(explicitKeyProperties);
var columns = allPropertiesExceptComputed.Select(x => x.Name).ToList();
var dbConnectionType = db.GetType().Name;
int result;
switch (dbConnectionType)
case "SQLiteConnection":
result = await db.ReplaceInto<T>(entitiestoUpsert, columns, tableName, transaction);
break;
case "MySqlConnection":
result = await db.MySQLUpsert<T>(entitiestoUpsert, columns, tableName, keyProperties.First().Name, transaction);
break;
default:
throw new Exception($"No method found for database type: {dbConnectionType}");
return result;
Here's the ReplaceInto code:
private static async Task<int> ReplaceInto<Tentity>(this IDbConnection db, IEnumerable<Tentity> records, List<string> columns, string intoTableName, IDbTransaction transaction = null)
var intoColumns = String.Join(",", columns);
var valueSb = new StringBuilder();
var inserts = new List<string>();
var dynamicParams = new DynamicParameters();
long i = 0;
var type = records.First().GetType();
foreach (var r in records)
var valueList = new List<string>();
foreach (var column in columns)
var value = type.GetProperty(column)?.GetValue(r, null);
var p = $"p{i}";
dynamicParams.Add(p, value);
valueList.Add($"@{p}");
i++;
valueSb.Append("(");
valueSb.Append(String.Join(",", valueList));
valueSb.Append(")");
inserts.Add(valueSb.ToString());
valueSb.Clear();
var cmd = $"REPLACE INTO {intoTableName} ({intoColumns}) VALUES {String.Join(",", inserts)}";
return await db.ExecuteAsync(cmd, dynamicParams, transaction);
I'm trying to follow some of the patterns/conventions that Dapper uses, in particular Dapper.Contrib.Extensions and how the use reflection on the POCO class to build the queries.
