I am working on a distributed application that uses the Manager Worker pattern. The application's manager node submits work to worker nodes through a WorkerNode
object (allowing WorkerNode
to be treated as the server itself).
The manager node can also submit work to its' internal WorkPool
this is currently done by calling the WorkPool
class explicitly without making HTTP calls.
I am at the point to where I am writing a lot of code to ensure 'local work' is submitted to the WorkPool
class on the manager node and that 'remote work' is submitted to the remote WorkPool
class over HTTP (using the WorkerNode
object).
This is causing some awkward edge cases developers need to worry about like distributing WorkUnit
objects evenly across nodes.
Proposed design:
Treat all work pools as if they are remote. I can control the local work pool through a WorkerNode
that is assigned an address of localhost
. This also requires the manager node to have the worker nodes routes added to the application at runtime (flask blueprint so it's easy).
Drawbacks:
The manager nodes makes requests to itself. Possibly causing caching issues, new devs saying "what the heck", or network issues when a reverse proxy server is added later.
Improvements:
Work pool is completely abstracted and there are no edge cases when submitting, retrieving, or killing units of work in the pools.
Unit testing my WorkRouter
class becomes very easy.
Interfacing with local work pools or remote work pools is done through the same object type keeping code DRY.
Similar Question: Is it bad design to internally call API endpoints from within the API instance?
This question seems to have nothing related to distributed systems and so using the service layer is an appropriate answer when dealing with a single stateless application.
