A project is structured as so:
A build server listens to changes in two repositories: a frontend and backend repo. When it picks up a change it builds, tests, and deploys the updates to a production server that exposes a publicly accessible endpoint.
On the production server, the backend is a Golang https server that serves static files and then has a designated endpoint handling CRUD interactions with the database via REST API. The frontend is split between a static react app built and updated by the build server that reads dynamic content from the backend REST API and then a similarly static authenticated CMS interface to manage the content itself.
Is this a solid or terrible way to structure a non-commercial webapp? Are there any obvious weaknesses I'm overlooking (besides pushing from build to production automatically)?
Coupcoup
  • 200
Directly allowing interactions from the frontend to your database is very risky, especially when the database contains sensitive information. Instead of a POST request to /api/db/addItem containing the body { "foo": "bar" }, do something which is more like /api/db/addFoo with no body.
All of the verification should be done on the server's REST api.
DaCool1
    Not sure I agree with that statement. It's risky to concatenate a database command (SQL or otherwise) with user supplied data. That doesn't change whether it's supplied with `addItem` and `addFoo` or with a JSON body. But if you aren't concatenating strings and using prepared statements (or equivalent), then you are typically safe. – Berin Loritsch Mar 01 '22 at 03:18
