Setup
Consider the following models (pseudo-code)
Place:
type: const = "Place"
lat: float
lon: float
# other fields
Event:
type: const = "Event"
start_date: timestamp
# other fields
I am using Python for the BE and CouchDB as DB System.
When creating a new object, I match my data in Python but I use CouchDB queries to get a list of prospective matches, e.g.
// Query1
"selector": {
"type": "Event",
"start_date": {
"$gt": new_event.start_date - epsilon,
"$lt": new_event.start_date + epsilon
"place.lat": {
"$gt": new_event.place.lat - epsilon,
"$lt": new_event.place.lat + epsilon
"place.lon": {
"$gt": new_event.place.lon - epsilon,
"$lt": new_event.place.lon + epsilon
where epsilon
is some constant.
Problem
The current approach requires a non-relational approach as I am using Event.place.lat
in the query. To avoid duplication I would prefer a relational approach, i.e. in the DB Event.place
is an ID as opposed to an actual object. However, with a relational approach I can no longer use Event.place.lat
in my queries.
Possible Solutions
Solution 1: Multiple Queries
To emulate the same query as Query1
I would:
- Query using only
new_event.type;new_event.start_date
to obtainresults_1 = [result_1_1, ..., result_1_n]
- Generate a list of IDs
relation_ids = [r.place for r in results_1]
- Query for the relations using
new_event.place.lat;new_event.place.lon;relation_ids
as filter to obtainresults_2 = [result_2_1, ..., result_2_k]
- Merge
results_1;results_2
to a list ofEvent
objects (Discarding theresults_1
elements w/o correspondingresults_2
element).
Additional Cost: 1 additional DB query and a little bit of computations in the BE (steps 2 & 4).
Soltuion 2: Expanding Models
This approach is straightforward: Add the fields lat;lon
the Event
objects saved in the DB. This way Query1
can be executed almost identically (using new_event.lat;new_event.lon
Additional Cost: Data duplication (lat;lon
being in both Event
& Place
Which would be the recommended implementation? Are there any other approaches that I might be missing (w/o leaving CouchDB)?
