I was looking at the angular documentation and noticed this code:
export class QuestionBase<T> {
value: T;
key: string;
label: string;
required: boolean;
order: number;
controlType: string;
type: string;
options: {key: string, value: string}[];
constructor(options: {
value?: T,
key?: string,
label?: string,
required?: boolean,
order?: number,
controlType?: string,
type?: string
this.value = options.value;
this.key = options.key || '';
this.label = options.label || '';
this.required = !!options.required;
this.order = options.order === undefined ? 1 : options.order;
this.controlType = options.controlType || '';
this.type = options.type || '';
They use this as the base class for different types of questions such as "DropdownQuestion", "TextboxQuestion", etc. I've copied the usage they included in the docs below:
export class DropdownQuestion extends QuestionBase<string> {
controlType = 'dropdown';
options: {key: string, value: string}[] = [];
constructor(options: {} = {}) {
super(options);
this.options = options['options'] || [];
//in some other file...
new DropdownQuestion({
key: 'brave',
label: 'Bravery Rating',
options: [
{key: 'solid', value: 'Solid'},
{key: 'great', value: 'Great'},
{key: 'good', value: 'Good'},
{key: 'unproven', value: 'Unproven'}
order: 3
new TextboxQuestion({
key: 'firstName',
label: 'First name',
value: 'Bombasto',
required: true,
order: 1
key: 'emailAddress',
label: 'Email',
type: 'email',
order: 2
As you can see, only the DropdownQuestion uses the "options" property, and has it's own property for "options", but they've included it in the base class. From what I can tell, it literally does nothing in the base class, because it's not used in the constructor, and it will never reach the prototype. What is the point of doing that? Shouldn't it just be included in the DropdownQuestion?
Slightly unrelated, but making the "key" and "label" properties optional when they seem to be required in all questions also seems like an odd thing to do.
Can anyone provide some clarification on what is ideal to do?
