I have asked this question in stackOverflow, but I guess that maybe softwareEngineering is more appropriate. (here is the question in stackOverflow)
I have frames sized with a fixed size of 7 values (t_i, i in {1..7}). Each value is stored on 2 bytes (the max value is then = 2^(16) -1 = 65 535) and is divided by a resolution factor of 10000, which makes 6.5535ms as the maximum value (0xFFFF). Beyond those values, the 2 bytes are no longer enough and the counter overflows.
In my test cases, I often encounter overflow especially when I use quite low frequencies
eg: frequency = 400Hz and t_1 = 1ms => t_7 = 1 + 6 * 1/400 = 16 ms > 6.5535 ms
To handle this overflow, what has been done until now was that that we allowed the overflow as it was detectable during the decoding.
To detect this overflow, the time delta between 2 consecutive (t_i) has been calculated to see if the result was lower than the max value (0xFFFF equivalent to 6.5535 ms) in which case, there is an overflow (counter and growing by definition, a decay shows an anomaly ).
I am thinking about extending the frame (x2) in case of overflow. How can I proceed to do so?
Existing lines to bypass the counter's overflow problem :
if (timeCounterInMs > 2000000000) { // 2000000000 is the value to be substracted to the counter to transform long into double
timeCounterInMs -= 2000000000;
isCounterOverFlow = true;
} else {
isCounterOverFlow = false;
currentIndexInBytes += 4;
body[index++] = timeCounterInMs; // body of the frame
for (int j = 0; j < 7; j++) {
long timeInTimeRatio = /*transform bytes to long*/;
currentIndexInBytes += 2;
body[index++] = timeInTimeRatio;
if (timeInTimeRatio == 0 && j != 0) {
// the end of the packet
} else {
if (timeInTimeRatio <= theLastValueInPacket && j != 0) { // If the time counter declay => overflow and start to zero
timeInTimeRatio = timeInTimeRatio + 65536; // 0xFFFF = 65536
Thank you so much
