I basically read across the entire internet that exceptions are bad, slow and should be avoided whenever possible. This confuses me because I thought I have a "valid" case to use exceptions.
Consider an input parser which transforms a string into an expression tree, that a calculator can evaluate. For me this seems perfectly suited for exceptions, see the following Pseudo-Code
try:
expression_tree = input_parser.parse(user_input);
print "Result: " , calculator.evaluate(expression_tree);
catch division_by_zero e:
print "Error: Division by zero near: " , e.code_window();
catch matrix_dimension e:
print "Error: Matrix dimension don't match near: ", e.code_window();
catch ...
Since I do not plan to fix the error, just catch it and then ask for a new input, the speed factor should be of no concern. Furthermore this makes the code well readable and easy to handle, as I don't need error codes or manual jumps / premature exits from functions. But as I've stated, the overall attitude towards exceptions makes me doubt myself.
