Context: Java, fairly new developer
I have inherited code from a friend for a project that processes variables. The first thing i notice is the class has a ton of member variables. I have always been under the impression that a lot of member variables means the class is designed poorly.
The class itself only has one function, to "process" the variables from an input map of varying variable types and with more variables than the class has (it is one step on a multi step variable processing journey) and then return an output map with separate derivation variables. This is currently done by taking in a map type (String, Object), initializing 50 member variables (all related to a the specific function of the class) using the input map, then running helper methods to change the class wide member variables (example later), then using a write method to write the variables to an output map.
I was wondering about the design of this class. Is there a variable processing design structure in Java? Ive heard of Plain Old Data but this is actually doing something with the data and has methods. Still, seeing 50 member variables made my stomach crawl a little. but I dont think I have enough experience to know if it is correct for this functionality or not. It seems the class has one function, it seems like the variables have high cohesion, all the variables are private, the only thing I can see that seems wrong is the helper methods seem to have tight coupling because they use the member variables so if you change any youd have to change it a lot.
I looked up SO and SE questions and many people who said having a lot of member variables usually means low cohesion which i dont think is the case here. I know that global variables are a no no and that passing variables into methods are generally preferred, but I was wondering what the design should be of a class that does processing on a large amount of variables and if there is any best practices. Every example ive seen only deals with like 3-5 variables per class and a couple methods.
public class DataProcessor
private var1;
private var2;
private var3;
private var4;
private var50;
public Map<String,Object> calculate(Map<String,Object> input) {
initialize() //wont show but writes each input to the var as the var name same as write
run()
write()
return outputMap
private run() {
outputVar = helper();
outputVar2 = helper2();
private helper() {
var1 = var1 + 10
private write() {
writeToMap(outputVar, outputMap)
