All exceptions are not created equal. Exceptions need to be exceptional and your code needs to be concise, readable, and you need to be able to reason about your code.
Of course, you can throw anything you like in your constructors. Or you can avoid throwing. The question is... do you have a plan? Writing code is, in a way, like writing a story. You have infinite options, dozens of which are almost identical or equivalent. Why am I saying that? Because when you think of your code as a part of reality, you can exploit your mental capacity of grasping concepts and ideas from real life and translate them to code. And then you can be more productive because you think in patterns.
Allow me to suggest a plan: Consumers of your code should be able to skip the instructions to the farthest extent possible.
- The only information you can safely convey to consumers of your constructors, and be sure that they will understand it, know about it, and even expect it, is that it puts the pieces together and ensures structural integrity, i.e. if the constructor is successful, the instance of the object is ready for use!
Be extra careful that you understand exactly what "structural" means. Structural integrity is what you have when things are in place and they are what they say they are. Having a null value instead of a valid instance spoils structural integrity. Having an empty string does not inherently do so because it's still a valid string. You can obviously choose to rule empty or whitespace strings out (as the BCL team decided when they made the string.IsNullOrEmpty
and string.IsNullOrWhiteSpace
methods, because empty and whitespace strings are often as good as null values) but that's that. All other string instances still don't inherently spoil structural integrity. Additional rules about what you want to count as a valid string is information you just cannot cleanly convey through a constructor.
Apart from this information, there is nothing, really, that you can convey to the consumers of your constructors without actually getting them to read the instructions, your instructions. So, in order to spare them the instructions, you can simply avoid doing anything more specialized in a constructor. So, to keep constructors trivial to execute, you have to:
Only throw ArgumentNullException
s and ArgumentException
s by checking for null
or empty strings.
Only make assignments to members.
Make sure any clever tricks you do in there don't really matter much.
This is really just the principle of least astonishment at work. When I retrieve a property of an object, I don't expect it to take more than a trivial amount of time. Same goes for a constructor, otherwise, the consumer will be caught by surprise.
Now, read Eric Lippert's terrific article on vexing exceptions. Then, you will know that, whenever our code does actually stubmle upon an ArgumentNullException
in a constructor, it's not the user screwing up, it's us. These "guard" checks are there to ensure that when we screw up in passing our arguments, we find it out as soon as possible, i.e. upon construction. In production, these guard checks are never expected to throw at all, except if something goes extraordinarily wrong.
One thing that experience teaches is that this is a pattern consumers can very easily get their heads over. Consumers almost always know in advance and expect that they cannot trick constructors into (or simply fall unknowingly into the trap of) creating problematic instances by passing null
values. Beyond that, all dependencies passed into a constructor will be valid, simply by virtue of having been constructed themselves.
Sometimes, you need to do special things to create an instance, because that's life. Again, the consumer cannot know that you need to parse something to create an instance. Spare them the instructions of how to use the constructor. Make the constructor private, and create a static factory method that prepares the arguments and constructs the object or fails. Name the method Parse
or TryParse
if you need to provide a fail-safe. Now consumers know what is going on... the construction of this object takes some processing, and, as a result, it is not entirely trivial (and how could it be, since you need to create the object from a string, a notoriously flexible type). This way, consumers will get the message that you may throw specialized exceptions, or just fail for whatever reason, and they will take precautions.
Also, mind Robert Harvey's excellent advice about the performance cost of exceptions in constructors. Make sure you provide two options, one of which just doesn't care, skips exceptions and fails non-exceptionally. Otherwise, make sure you have some good use for the painfully collected stack traces. All the comments about how exceptions are useful are fine, but do you really care about the stack trace or you simply want to show a fancy message to your users about what they are probably doing wrong? If so, just create an enumeration of a couple of reasons you know could go wrong and output them together in case of failure. Exceptions hurt.
Your second code example seems mostly OK. However, I suggest throwing away the PathHelper
, it's just expanding the codebase for no good reason (unless you want to make extension methods, which would not be that bad an idea, but then you have to keep the constructor public, to make it accessible outside the class and this defeats the purpose of protecting consumers from invalid instances). Place the method inside the NamePath class, close to where it matters.
public class NamePath
public string Name {get; private set; }
public string LastName { get; private set; }
//Now I can have the constructor private, because I don't want
//anyone to ever write (e.g.):
//new NamePath("Humphrey", "Bogart");
//or they will get some bad behavior in other places of the code
//where it is assumed that NamePath instances are reasonable and
//have been created properly.
private NamePath (string name, string lastName)
Name = name;
LastName = lastName;
public static bool TryParsePath(string path, out NamePath output)
if (ParsingOkay())
//create instance and assign to output
return true;
output = null;
return false;
Now, after you have put everything in place, think about the following two lines of code:
Would you prefer to consume the first or the second version? How would you feel as a consumer, if you knew that the two are equivalent (only you have to catch a couple of exceptions in the first case)? How would you feel as a consumer if you just had NamePath
class with a constructor, and you had to dive into the instructions to find out if anything special takes place in the constructor, which you have to watch out for? Would you be prepared to do that for every object constructor you come across within a library?
Take-home message
Try to avoid constructing objects from strings when those strings play a special role for the object and need to have a specific format. Write concise methods that make the consumer feel adequate unease to guard themselves and/or read the instructions. Make consumers feel at ease when just calling constructors... any constructors.
In short, there is no special reason to throw or not to throw specific exceptions in a constructor (other than the structural integrity ensuring ones, i.e. ArgumentNullException
). It is just a consistent plan, the simplest one, really, to not perform additional logic and, as a result, not throw any more specialized exceptions at all. It reduces entropy, it is more productive, easier to follow, and requires a lot less guesswork from the consumer perspective.
