So I have an engine in progress that's structured like this:
- entities are simple ids (unsigned short)
- components are stored in pools which are static members
- systems are stored by the manager, and all inherit from a single base
What this looks like in code is like this:
struct transformComponent {
const unsigned short id;
vec2 pos, dim;
transformComponent(vec2 pos, vec2 dim, unsigned short id): pos(pos), dim(dim), id(id) {}
static componentPool<transformComponent> pool; // allows for scalability
struct physicsComponent {
vec2 v, a, f;
unsigned short mass;
float invmass
physicsComponent(vec2 v, vec2 a, vec2 f, unsigned short mass, unsigned short id): v(v), a(a), f(f), mass(mass), invmass(1.0/mass), id(id) {}
static componentPool<physicsComponent> pool;
// same for other components
struct system {
virtual void update() = 0; // don't care about virtual call, there will be only one per system
struct physicsSystem: public system {
virtual void update() override; // the problem
struct room { // the manager
std::vector<system*> systems;
std::unordered_set<unsigned short> activeIds;
void update() {for(auto* sys: systems) {sys->update();}}
Now I did everything I could, until now, to make this as cache-friendly as possible. The thing is: if the physics loop reads the physics components and writes to the transforms, doesn't that completely eliminate the point? I'll let some code explain what I mean:
/* either:
physicsSystem has a hashmap of ids that it has to loop over to component pointers, which only gets updated when necessary (std::unordered_map<unsigned short, std::tuple<transformComponent*, physicsComponent*>> comps;), breaks purity (systems have no state)
or
comps is created every frame (for every system), terribly inefficient
// either:
void physicsSystem::update() {
for(auto pair: comps) {
physicsComponent* phy = std::get<physicsComponent*>(pair.second);
transformComponent* tra = std::get<transformComponent*>(pair.second);
phy->a = phy->f * phy->invmass;
phy->v += phy->a;
tra->pos += phy->v;
// cache misses to load both transform and physics twice, for every entity, for every system, for every frame
// or:
// comps is actually an std::unordered_map<unsigned short, std::tuple<transformComponent*, physicsComponent*, vec2>>
vec2& schedule = std::get<vec2>(pair.second);
phy->v += phy->a;
schedule = phy->v;
std::get<transformComponent*>(pair.second)->pos += std::get<vec2>(pair.second);
// smooth first loop, but still cache misses in the second (I think)
So, my question is: how would one go about making this loop cache-friendly? By that I mean, no cache misses for every entity, but only when the array size exceeds the cache and when switching between component types to update. I'd be happy to receive any different approaches, as well. TIA.
