I've got a project with an HTTP API which returns data from a database. The layers it goes through to get to the API look like this:
DB -> Repository -> Controller
I'm looking to restrict the results which are returned based on the permissions of the requester. Should this be included in the repository layer, or the controller layer and why?
Joundill
  • 129
  • Repository layer should be 3 layered. Access control goes in middle layer – overexchange May 19 '20 at 04:04
  • What are the other layers within the repository layer? – Joundill May 19 '20 at 04:06
    top layer will provide public interface for other components. Changing Oracle to MySQL should affect bottom layer only – overexchange May 19 '20 at 04:49
  • Middle layer has highest number of responsibilities like... limit max connections, access control, caching, validate client if this repository layer can be reused in non-webapp scenario etc... – overexchange May 19 '20 at 04:57
  • So the bottom layer should provide the interface with the data source, the middle has the data logic, and top is the interface which the service layer or controllers talk to? What's the disadvantage of combining the three into one repository layer? – Joundill May 19 '20 at 06:41
  • For your question: "What's the disadvantage of combining the three into one repository layer?" Probably the question is: Is the code(set of related responsibilities) de-coupled from the change(set of other responsibilities) that we expect to happen, in future? – overexchange May 21 '20 at 01:50
Ideally, if you really require a high level of security, the DB itself should not return any data for which the requester does not have the permission. So the answer in this case would be "neither" - the DB itself should provide an adequate security model, know about the permissions of a specific requester and restrict the data.
However, most real world applications of today implement their own user/role/permission model, which makes it hard to implement the security model easily inside the DB. So I see two possible ways to define the reponsibilities:
  • Approach 1 is to keep as much business logic out of the repositories. In this case, the repos should only to provide the tools for restricting the returned result sets, but don't know which permissions the requester has. So here, the Controller might be responsible for evaluating the permissions. This may be feasible if there are only a few places in code where permissions have influence on the result sets of DB queries.
  • Approach 2 is to restrict the result sets directly in the repos. That approach makes sense if there are a lot of different places in the system from which the repositories are called and reused, and all of them should obey to the same permission model which involves returning different result sets.
Note that approach 2 can be implemented by splitting the repos into two different layers: one generic layer without any knowledge about the permissions, and one layer on top (maybe by "decorated" repos, or "proxy repos"), which implements the security model:
DB -> Generic Repositories -> Secured Repositories -> Controller
You need to decide for yourself if the kind of security requirements justifies this additional layering (and maybe further layers, as it was suggested in a comment), which comes for the price of more complexity. There is no "one-size-fits-all" solution to this, one has to make such design decisions deliberate with the overall system in mind.
Doc Brown
  • 199,015
  • 367
  • 565
    That's some good advice, cheers – Joundill May 19 '20 at 03:55
  • wait are you recommending each user have their own db user? – Ewan May 20 '20 at 06:06
  • @Ewan: no, I am not recommending any implementation details. But I guess I know what you have in mind: most web applications today will usually manage their own user/role/permission model which makes it actually hard to implement this inside the DB. See 2nd paragraph above. – Doc Brown May 20 '20 at 08:31
  • it reads like that is your prefered option though. I was surprised enough to feel the need to write my own answer – Ewan May 20 '20 at 08:33
  • @Ewan: see my edit. Better now? – Doc Brown May 20 '20 at 08:37
    *shrug* to me the "DB itself should provide an adequate security model" sounds like you mean, "users should run sql as their own db user". which (to me) sounds bad and prompted me to write my own answer, but normally we agree on stuff so I wasn't sure if you had some special situation in mind, meant something else entirely or simply disagreed. – Ewan May 20 '20 at 08:58
  • @Ewan One can always use both approaches, i.e. make sure on the DB level that the type of application/request cannot get more data than it should and do individual user level checks in the application on top. Maybe Doc meant something in that direction, otherwise, yeah it reads a bit weird to connect app users with database users. – Frank Hopkins May 20 '20 at 13:41
  • @FrankHopkins I have seen it done – Ewan May 20 '20 at 13:42
  • @Ewan not saying it's impossible but in most cases I would not recommend it. Unless for very techy folk / cases where it's really mostly a low-level gateway app to the data in the database and not an application to provide some service that needs some database for that purpose. – Frank Hopkins May 20 '20 at 13:43
  • I posted a question about whether users should each have their own db user on the dba stack exchange site. I'm not aware of anyone doing that for multi user web apps. https://dba.stackexchange.com/questions/133387/is-it-ever-good-practice-to-use-a-distinct-database-account-for-each-user-of-an – bdsl Jun 21 '21 at 22:31
  • @bdsl: web apps usually don't establish long-living connections between the client and the web server. Using one DB user per real user would probably require the DB connections to follow this model, and I guess the connection architecture of most DBMS's isn't optimized for this. Using long-living connections, however, is definitely not an option, most DBMS's have a rather small max number of concurrent connections (in Oracle, for example, it is AFAIK ~2000). – Doc Brown Jun 22 '21 at 05:33
Security should be applied by your framework before the Controller.
In most frameworks this means you grant access to Controller Methods.
Controller
The controller will have access to the authenticated user's details and can use these as parameters to filter data accordingly, e.g.
[Authorize(Role='editor')] //framework binding to requests limits access
GetMyArticles()
     var userId = context.user.Id; //required data extracted from auth token/user context
Repository
A Repository's responsibility is returning data, so you can have a method on it such as GetDataByUserId, but it shouldn't be doing security.
eg
this.repo.GetArticlesByUserId(userId)
NOT
this.repo.GetArticles(user);
Passing the user object or context into the repo violates the single responsibility rule and should not be attempted
Database
Most databases don't have fine grained enough security controls for business logic and a web API will normally be using some sort of central sign on token. You don't want to have to duplicate all your web users in the database's security or be sending their credentials to the API so that it can log on as them.
e.g.
var connstr = appsettings[connstringWithServiceUser]
var repo = new repo(connstr)
NOT
var connstr = "database;user" + context.user + context.password
This exposes the users' password; you shouldn't have access to it.
ALSO NOT
var connstr = "database;user=thisProcess"
...impersonate calling user
This is super tricky to pull off correctly. You will need Kerberos multihop impersonation and row level database security.
Your databases security model just isn't designed to hold all the front end users of your website. Having them all in there is an auditing nightmare and will lower your security.
Additionally you now have to implement your "user can only see their own articles" business logic via the DB's row level permissions. Good luck unit testing that. It's a super bad idea and I can't believe its getting upvotes.
Auth → Controller → Repo → DB
Is the almost universal solution for web APIs.
Glorfindel
  • 3,137
Ewan
  • 70,664
  • 76
  • 161
  • You are either describing an antipattern where business logic depends on the controller layer or your answer isn't specific enough about the difference between authentication and authorization. – Mateusz Stefek May 20 '20 at 20:43
  • how do you mean? – Ewan May 20 '20 at 20:55
    I left the service layer out because the OP didnt mention it and I dont think it adds anything to the answer – Ewan May 20 '20 at 20:57
  • @Ewan I'd be interested in hearing more about the implications of a service layer on the pattern if it's not too much of a hassle. – Joundill May 21 '20 at 02:26
  • @MateuszStefek What's the antipattern you're talking about? – Joundill May 21 '20 at 02:26
    theres no real difference, you just put it inbetween the controler and the repo to separate your business logic out – Ewan May 21 '20 at 05:28
    @Joundill if you consider authorization rules as your „domain” or „business rules”, it should not be implemented in the controller/web layer. The original question mentioned only two modules and there’s the problem that the architecture has too few boundaries. The repository is responsible for abstracting away the database, the controller is to handle the HTTP protocol, so who’s responsible for the authorization? You end up with a Fat Controller. – Mateusz Stefek May 22 '20 at 05:22
Security is Layered
The truth of the mater is that Bad People™ will try and by pass your security.
By adding security you want to make it as genuinely difficult as possible for someone who is not there legitimately to do anything, while also reducing the amount of being in the way experienced by people who legitimately use the system everyday.
Boundaries
Your picture isn't entirely accurate, it looks more like:
DB -> Repository -> Controller -> User
The -> are the boundaries. Even though that is still a simplification, we could through networks and other issues in.
The point is that each boundary needs to allow the good stuff through, while making the bad stuff difficult/impossible to do.
You could place all of your security between the user and the controller, but if someone bypassed that, then they would have a field day.
Similarly you can't just place all of the security between the Database and Repository. It's already to late as the service itself is exposed, and any data being passed to it, must presumably be available to anyone using it. Which probably isn't reasonable to expect.
DB -> Repository
The actual Database Engine needs to enforce permissions, to the Repository. Obviously the Repository can't just do anything:
  • creating/dropping tables,
  • adding indices,
  • updating rows in these tables,
  • inserting rows to these other tables,
  • etc...
The Engine should give exactly the rights needed for that repository, and no more.
The Repository similarly needs to ensure that a controller can't just do anything with it:
  • Delete a customer record, especially if it is linked to other records
  • Insert Multiple Payments against an already paid order
  • Permit the viewOrder controller to insert User Records.
This is partly done by implementing business sanity checks, and partly done by checking to see if the Controller has the right to do so. This is usually implemented by some form of whitelist checking that the caller is on the list, and has the required rights, or by some permissions object that can itself be verified.
Controller -> User
The Controller itself has to establish that the user has the required permissions. Usually done by some login method, or certificate. If the login/certificate passes muster, the users permissions are checked to see if they can access the controller.
This provides layers of security.
If for example an admin account got breached, and the used the OrderViewController with some sort of exploit, then the repository will reject odd requests, as the controller only has privilege X, Y, Z.
If they bypassed the controller and somehow got to within the repository, then they can't just drop all the data, or use it for storing their own in an easy way.
Kain0_0
  • 15,888
The approach you take depends upon the method of authentication you're going to choose. Your authentication can be as simple as verifying user's identity using username and password in the first call and thereafter you might issue a token for subsequent validation.
The amount of information stored in the token will decide whether access control would happen at controller level or at the model/repository level. Let's say your application has two kinds of users
  1. Admin User - This one has access to all kinds of records stored in the database
  2. Normal User - This one has access to only records it has created
If your authentication token only has the information about the user's identifier then to extract full information about the user from token you'll have to query the database and interaction with the database is not the work of controller it should be done by repositories as discussed here in the question Check permissions on the top layer before going deeper .
If your authentication token has all the information about the user's access and its role then in that case at the controller level itself you can extract all the permissions by decrypting the token and reject and accept the request based on the information you got from token.
Better approach IMO would be to store as much information as possible in the token, as mentioned here in the question Should access permissions and roles be included in the payload of JWT.
Anshul Sahni
  • 365
