Please, consider the below merge sort algorithm. Here we start with a divide portion which splits the array into halves and we do recursive operation on each half separately. I have ignored the merge portion of the algorithm to reduce complexity.
function mergeSort(unsortedArray)
let midpoint = Math.floor(unsortedArray.length/2);
if(unsortedArray.length == 1)
return unsortedArray;
let leftArray = mergeSort(unsortedArray.slice(0,midpoint));
let rightArray = mergeSort(unsortedArray.slice(midpoint,unsortedArray.length));
I know for binary search tree which ignores half of the array in every iteration the answer would easily be arrived at as log2 n.
Now I would like to calculate the Worst Case Time Complexity for only the portion which splits the array into left half i.e. let leftArray = mergeSort(unsortedArray.slice(0,midpoint));
Even if the above code splits the array from index of 0 to midpoint. In the next level of recursion it would work on the entire array unlike Binary Search with index 0 to midpoint/2 going to left recursive call and index midpoint/2 to midpoint going to right recursive half.
So, How would we calculate Time complexity in a scenario where each level of recursion involves multiple recursive calls instead of one?
