I am working on learning native iOS development in Swift, and I am trying to find something that is similar to what I've learned in Android development with Kotlin.
In particular I am referring to the concept of having the db as the "single source of truth", that is advertised by the Android team as one of the main points of their recommended app architecture. This is possible by the use of LiveData, an observable data holder, and Room, a persistence library based on SQLite that returns LiveData objects. Those objects are observed in the UI layer to display data to the user. With this architecture, the typical Repository call looks something like this:
 * The database serves as the single source of truth.
 * Therefore UI can receive data updates from database only.
 * Function notify UI about:
 * [Result.Status.SUCCESS] - with data from database
 * [Result.Status.ERROR] - if error has occurred from any source
 * [Result.Status.LOADING]
fun <T, A> resultLiveData(databaseQuery: () -> LiveData<T>,
                          networkCall: suspend () -> Result<A>,
                          saveCallResult: suspend (A) -> Unit): LiveData<Result<T>> =
        liveData(Dispatchers.IO) {
            emit(Result.loading<T>())
            val source = databaseQuery.invoke().map { Result.success(it) }
            emitSource(source)
            val responseStatus = networkCall.invoke()
            if (responseStatus.status == SUCCESS) {
                saveCallResult(responseStatus.data!!)
            } else if (responseStatus.status == ERROR) {
                emit(Result.error<T>(responseStatus.message!!))
                emitSource(source)
(taken from here)
This allows also to encapsulate both the data and its loading status in a single object (Result in the example), so the UI can start showing the old data coming from the DB while the new one is retrieved from the network, and the status as well.
I have been looking for something similar in iOS but it seems that there is no straightforward solution. The closest to it seems to be a combination of Realm or CoreData for the data layer, and then RxSwift for the observable bits. This seems to involve quite some more coordination between the different parts, and not as straightforward as in Android.
Am I missing maybe an easier path in doing what I need?
papafe
  • 171
  • You just use a Notification and a NotificationHandler. No need for RxSwift or any other library. Built into iOS since about 2007. – gnasher729 Apr 26 '20 at 09:58
    I am considering to apply technique mentioned in https://github.com/groue/GRDB.swift/blob/master/README.md#valueobservation – Cheok Yan Cheng Dec 31 '20 at 12:06
  • Store your model in CoreData and use notifications: https://cocoacasts.com/how-to-observe-a-managed-object-context – Daniel T. Sep 20 '21 at 01:42
0 Answers0
