There isn't always a design pattern that will elegantly solve complexity. Some complexity is inherent in the problem you're solving. At most, you can shuffle the complexity around.
So quite possibly, the If Statement Pattern is the best you can do here.
However, if your MyObject
type is some interface and different concrete types have different but simpler logic for drawing themselves, you could replace conditionals with polymorphism. This splits up the complexity and moves it into individual classes. For example:
public void drawObject(MyObject myObject) {
myObject.toElement().draw()
interface MyObject {
public RootElement toElement();
class MyObjectA implements MyObject {
@Override
public RootElement toElement() {
RootElement root = new RootElement();
root.addElement(new XElement());
return root;
class MyObjectB implements MyObject { ... }
class MyObjectC implements MyObject { ... }
Sometimes, instead of testing whether some element should be added, it could make sense to use the Null Object Pattern. You would then always add an element, but the element may not draw anything. Whether that would simplify things depends on your specific code, and your snippet is to abstract to make a statement on this.
But again: maybe this complexity cannot be avoided. As a last resort, you can extract individual conditions into separate helper functions and give them a useful name. This can make a large complex method easier to read, but makes the overall code more complex. Something like this:
addElementForA(root, myObject);
addElementForB(root, myObject);
addElementForC(root, myObject);
root.draw();
private static void addElementForA(RootElement root, MyObject myObject) {
if (myObject.hasA()) {
} else {
root.addElement(new YElement());
private static void addElementForB(RootElement root, MyObject myObject) {
if (myObject.hasB()) {
root.addElement(new ZElement("A"));
private static void addElementForC(RootElement root, MyObject myObject) {
if (myObject.hasC()) {
root.addElement(new ZElement("B"));
Don't use placeholder names like this in the real code, but think about what the condition represents in your problem domain. E.g. if this would assemble a web page with an optional footer, you might call one of these helpers maybeAddFooter()
