Let's assume that you are trying to refactor a legacy code to make it easier to understand and more testable, how can you do that?
In the book "Working with Legacy Code", a characterization/regression test was recommended. First, you start with a test that invokes the part of the code you want to refactor (e.g. a big method). What this test tells you is for that input you should expect that output. Therefore, if you refactor and the output has changed, this means something was broken.
The assumption here is that the legacy code is harder to understand and thus harder to test. You can find this case explained in another question here: Writing tests for code whose purpose I don't understand
Now you have a refactored code that you can start writing unit tests for (e.g. you broke the big method to smaller testable ones).
Unit tests might help you uncover bugs that you need to fix. Fixing those bugs will make you unit tests pass but will break the characterization/regression tests. Those tests are expecting a certain output which is the output of the code before the bug was found and fixed.
So what is the appropiate course of action here? Can I just remove/uncomment the test? I have seen in the book "Working with Legacy Code" an example of a test that was removed after refactoring. Does this apply here?
