Rewritten Question
I appreciate the feedback and in response to that I'm re-writing my question. I can't give my specific situation (classes, etc), nor do I think that it would be helpful, as I work in a very niche area that wouldn't make much sense to those outside of it, but I will try and use a similar but invented analogous situation to give something more concrete.
I have an application and two libraries of interest here. These are quite mature (about ten years old) and relate to a product that has been selling that long. The application reads files of various types, including images, and makes them searchable and viewable. It also produces a detailed report.
One library (ImageIO) is responsible for reading images. It doesn't just read JPEGs and PNGs, but hundreds of different formats that have been encountered over the years. Formats are continuously being added to it. It can also spit out standard formats like PNGs and JPEGs.
Another library is responsible for the reporting. It doesn't just handle images, but all sorts of file types. It gives a detailed report including a list of all of the metadata used.
When I got handed the code, the main application has a class called Document which contains, among other things, a list of Images. An Image has some set properties and methods including Height, Width, and GetBitmap. Each of the image types has its own subclass; JpegImage, PngImage, TiffImage, DicomImage and so on. Most of these have custom properties; camera used, white point, colorspace, title, GPS location and so on. Most have between one and six extra properties. Some properties are common to many types (like exif data), while many image types, particularly the more niche types (like BobsImage) have properties that are unique to that image type.
// Some methods
int[][] GetBitmap()
// Some properties
int Height
int Width
The main application only uses a few of these properties when they exist. The reporting library reports on them all. There are dozens of properties. There are no special methods, though behind the scenes, some types use some properties for the standard methods. For example, using the aspect ratio for producing the BitMap.
The application uses a magic string to tell the reporting library what sub-class the images really are. The reporting library then uses that to cast the Image back to it's subclass, and then heaps of ifs and switches to report accordingly.
I was not happy with this architecture. My first attempt was to turn Image into and an IImage interface, and then bundle properties into groups and have relevant interfaces for the extra. The IImage seems to work fine, but the properties are an issue; there were about as many interfaces as properties, and then they were tested with an "is a" style test, which felt like I was pretty much back with the switch statements.
IImage
// Some methods
int[][] GetBitmap()
// Some properties
int Height
int Width
IGps
Double[] GetGps()
My second attempt was to just add bool HasProperty(PropertyId id) and T GetProperty<T>(PropertyId) to the IImage. Then none of the other interfaces were required.
enum PropertyId
GpsData,
ExifData, ...
IImage
// Some methods
int[][] GetBitmap()
// Some properties
int Height
int Width
// New methods
List<PropertyId> GetSupportedProperties()
This really cleaned up the Reporting library; it could enumerate over the GetSupportedProperties and no ifs or switches. It also means it didn't have to care about the hundreds of sub-classes, and in fact, sub-classes weren't even required. A generic Image class that implemented IImage could be made that just contained a list of properties, types for run-time type checking and values.
It still feels bad. It removes compile-time type checking. For example, var gps = GetProperty<string>(PropertyId.Gps) would compile, but a Gps is a double array, not a string. So it would throw an exception at runtime.
Also, Flater points out I'm corrupting the point of interfaces, and he is completely right. The reason I'm asking this question is because I think my answer is dirty; it's just the least dirty answer I have. The first and second approaches seemed worse (the original seemed much worse).
The solution would preferably be able to handle adding properties easily. I have no control over what data image formats decide to use. We have not written a single image format; we either get them from specs (like PNG), or as with about 95% of out formats, we reverse engineer them. That is the benefit our software brings; it understands, views and reports on rare file types (including image formats). About 70% of our time goes into reverse engineering new formats, which arrive on our doorstep faster than we can reverse engineer them.
The reverse engineering really hampers forward planning. You might find it hard to believe some of the data that is stored. I'm constantly surprised, and I've been doing this for over a decade. This means that we have to be reactive, as we can't be proactive.
When I used the tree of interfaces (I don't care if they inherit from IImage or from others as needed) I find that I do have fewer interfaces than there are image types, or properties, but still dozens. And checking to see if an object implements an interface doesn't feel much better than calling HasProperty, but perhaps that is my own subjective issue.
Flater's suggestion seems to line up with my first attempt (the second model) a bit, and Simon B seems to be suggesting my current, second attempt (the third model) is best. I could be reading this wrong. If either is true, I'll live with the dirty feelings; it just felt like there must be some better approach out there, though I haven't found it.
I hope the context, though fake (but only a little fake) helps. I'm sorry I wasn't more clear the first time around. I hope this is better. I appreciate the time people took to help, and I will eventually accept an answer.
Old question kept for reference only
I am refactoring a smelly class and I'm sure I'm making a pig's ear of it. It feels like a common problem, but I can't see a common solution. As the domain is fairly niche, I've changed names etc.
I have an interface, let's say IThing, which has a few methods and started with a few properties. As time went on, many different IThings cropped up with different properties. (IThing is a sort of interface to multiple different reverse-engineered Things that we have no control over, so the properties are thrust on us.)
We ended up with a pattern of the sort bool HasSpecialNumber, int SpecialNumber {get; set;}. This got smelly as we added more and more properties, with every implementation having to implement 20+ methods just to say they don't support a property.
I thought of using a mixin approach, but maybe I'm thinking of this wrongly, because it would involve as many interfaces as properties or combinations of properties, and a lot of casting. It also seems heavy-handed when I'm only providing properties here and the methods are not changing.
An IThing looks sort of like this (C#ish pseudo-ish code)
IThing
// Some methods every Thing supports
DoSomething
DoSomethingElse
// A bunch of properties some Things support
bool HasSpecialNumber { get; }
int SpecialNumber { get; }
bool HasName { get; }
string Name { get; }
... and so on
Apart from the smell, every time a property was added, a whole bunch of classes broke. These all needed to be serialized too, using protobuf-net. Many of these classes were only distinct in that they had special objects.
The next thing we tried was reducing the properties to two methods, with a private method for adding properties.
IThing
DoSomething
DoSomethingElse
bool HasProperty( PropertyIdEnum propertyId )
T GetProperty<T>( PropertyIdEnum propertyId )
// Private method for adding properties
void AddProperty<T>( PropertyIdEnum propertyId, T value )
This sort of worked. Dozens of properties became two accessor methods, and updating the PropertyIdEnum didn't break anything. The AddProperty was used to add properties to a dictionary that mapped the IDs to objects, with a Type stored alongside to ensure no weird casting errors. But I exchanged compile-time type checking for run-time type checking. Also, protobuf-net doesn't support serializing Objects or Types, though that is an implementation detail.
We ditched the AddProperty abstraction and went back to dozens of classes. That resolved the protobuff-net issue at the cost of having a lot more classes to worry about. We still lack the compile-time type safety.
I see this issue all over the place in areas I work. For example, ffmpeg and the CODECs they deal with, each with special behaviour. The solutions they use are constrained by backwards compatibility though, an they are working in heavily optimized C while I'm in C#. Is there some pattern or advise for dealing with a run-away set of properties that need to be handled trough a single common interface? If I had control over the properties I would just not be in this situation in the first place, but I don't, so here I am.
timbo
  • 149
    If you use a boolean for every property to indicate if it has a value, why not simply use nullable types and null? Like `int? SpecialNumber`? If your interface needs all those properties is a different question, maybe it does, but that is hard to answer by looking at meaningless terms like `Thing`, without knowing the precise requirements. – Doc Brown Apr 13 '20 at 19:23
    @DocBrown: I'm not suggesting OP's approach doesn't have flaws, but nullables aren't always the answer, e.g. when null itself is a meaningful value and not the same as when the boolean is false. – Flater Apr 13 '20 at 19:58
  • Is it viable to make `IThing` a supertype and build `Thing`s as subtypes? You say you have attributes "all" `Thing`s support, and attributes only "some" `Thing`s support, that sounds like an inheritance problem to me, am I wrong? – ewhiting Apr 13 '20 at 19:58
  • This question statement is a bit short on details to determine the problem. I mean, if you were doing everything perfectly correctly and not encountering any problems, then that'd actually tell us more; but, since there're a million different ways in which an otherwise-correct approach can go astray, it's hard to guess which specific potential issue you might be encountering. – Nat Apr 13 '20 at 23:10
  • To fix this, might help to go in one of two directions: **(1)** Give tons of details. Show the starting point, and where it ended up. (Perhaps on SE.CodeReview, instead?) Point out the parts of the process that you're concerned about and why, then ask how the concerns could be addressed. **(2)** Instead of asking about what you might be doing wrong, describe the general problem and ask how it could be solved correctly. – Nat Apr 13 '20 at 23:15
  • Like, if I had to guess how to write an answer to this question, I might start out by discussing how designing a class-tree (or whatever) requires starting from a top-down approach, where you understand the domain and break it down into chunks, as opposed to a bottom-up approach in which you'd try to create chunks to combine. I'd speculate that, when you're trying to refactor, you're designing little chunks of logic along the way, then trying to merge them -- resulting in a big mess. Still, that'd largely be speculation. – Nat Apr 13 '20 at 23:25
  • It's hard to tell because not much information is given, but my gut feeling is that you're trying to force one interface to do the job of many interfaces. You can, and sometimes should, have more than one interface on a class. – Turksarama Apr 14 '20 at 00:55
  • @Flater: I want to know from the OP what semantics these boolean/value pairs express *in their real situation*. Sure we can "invent" cases where such a pair makes sense, but I am really interested what the OP has to say about it. – Doc Brown Apr 14 '20 at 05:34
  • @DocBrown I think that it can be implemented with nullable types. I've never seen a huge advantage outside of databases; they are basically implemented as a bool and the type slapped together anyway. The implementation is something I never dictate in an interface, so certainly it could be implemented with nullable types, I just chose not to. Likewise, I could get rid of "HasProperty" and dictate that if the property doesn't exist, return null. It is something I'm happy to discuss, but I don't think it leads to a solution of the core problem here. – timbo Apr 24 '20 at 17:37
  • @DocBrown Also, as I think Flater is getting at, null can be distinct from not having the property, or from not supporting it. It might be that the property exists, but the value actually recorded is null. – timbo Apr 24 '20 at 17:40
  • @ewhiting It definitely could be inheritance. If I had a single Image and just PNG and Jpeg, no problem. The problems here are the scale, and the frequent addition of unforseeable properties. It can, and has, been implemented with hundreds of subclasses. It causes huge numbers of ifs and switches to deal with though. Interfaces simplified it a bit (a lot actually) but left a lot to be desired. – timbo Apr 24 '20 at 17:42
  • @Nat I hope the re-write helped. – timbo Apr 24 '20 at 17:42
    *"It still feels bad. It removes compile-time type checking."* - that is your problem. You are trained way too much in "everything must be compile-time checked" that you overlook that compile time checks and run-time checks are nothing but a trade-off. For some use-cases, compile checks are more appropriate. For reporting, your `HasProperty` approach is fine, and the fact there is no compile-time safety is simply worth it. You can try to balance this by automated tests, – Doc Brown Apr 24 '20 at 17:43
  • @Turksarama I definitely could be. I mean, I am, but both many interfaces and one interface feel bad, but with different problems. – timbo Apr 24 '20 at 17:44
  • @DocBrown It seems you are suggesting my final approach might be the best I can do? I'm starting to feel that might be the case. I've gone through dozens of such issues in this code base, and always had nice elegant solutions before. Maybe I just have to accept there aren't always nice elegant solutions to every problem and just accept the compromise. – timbo Apr 24 '20 at 17:46
  • @timbo: who says its not elegant? For reporting, it is not unusual to require every property as a string. In case you don't do any calculations or evaluations in the reporting modules, why bother with a `T GetProperty`at all? Why not have a method `string GetProperty(propertyId, formatHint=null)` instead? – Doc Brown Apr 24 '20 at 17:56
  • EXIF allows for a limited number of data representation types (strings, integers, datetime, etc). The backend is a byte array. You can implement conversion functions. – rwong Apr 28 '20 at 02:23
7 Answers7
You're trying to metaprogram and it's going to cause you more issues than you're actually solving. You're trying to create an interface which takes any (not yet defined) set of properties, which defeats the purpose of the interface: enforcing that your classes implement a given set of properties (or methods).
Interfaces should list what a class must have. Not what it could possible have. That's just not the purpose of an interface. This is an unusual variation on a Liskov (LSP) violation, you are signing yourself up for having to write constant checks whether your thing actually contains a given property or not, along the lines of:
if(myThing.HasSpecialNumber)
    // do something with myThing.SpecialNumber
Your second attempt would rewrite the above syntax, but it doesn't actually prevent you from needing to constantly doublecheck your things.
Statically typed languages focus heavily on knowing the structure of your objects, and not having to guess/check for it. Split your interfaces and only implement them in classes that fulfill the interface's contract, and don't trying to fake-implement them in other classes.
Something along the lines of:
public interface IThing
    void DoSomething();
    void DoSomethingElse();
public interface IThingWithName : IThing
    string Name { get; set; }
public class ThingWithoutName : IThing
    public void DoSomething()
    public void DoSomethingElse()
public class ThingWithName : IThingWithName
    public string Name { get; set; }
This enables you to know for a fact that a given class (ThingWithoutName/ThingWithName), and thus any of its instances, has a Name property or not, and thus you don't need to keep checking if it does.
This ensures that you have strong and static typing instead of runtime object evaluations, which C# isn't built to do (it can be done on a technical level, but it's a bad approach with many drawbacks).
Some footnotes:
  • IThingWithName is obviously not a great name, but your question doesn't have enough context for me to pick an appropriate name here.
  • It's unclear whether you need to inherit your interfaces, or define separate interfaces and implement both of them on a class. This is a contextual consideration that your question does not specify. I suspect I picked the correct option based on how you phrased your question, but I can't be 100% sure.
  • If you're going to end up with a unique interface for every property, you're probably doing something wrong. But again, the question is too light on context for me to definitively state anything on this.
Flater
  • 44,596
  • 88
  • 122
  • I completely agree with your assessment; that's what feels dirty about my "solution". I hope my re-writing of the question helps explain the reasoning better, and why the obvious use of interfaces was causing me issues. I had actually tried that. It was writing interface number 30 or so I decided to try my one interface approach. – timbo Apr 24 '20 at 17:48
The usual solution is the one you have abandoned, which is generally summarized as "prefer composition over inheritance".
Create a simple class, which has a container to hold the special values. That container could be a dictionary/map, which is effectively a collection of name+value pairs. If you use the right container, querying it can be reasonably fast.
Simon B
  • 9,167
  • 26
  • Thanks Simon. Is "prefer containment over inheritance" the same as "prefer composition over inheritance"? I did actually implement things as you suggest at first; a Dictionary that mapped PropertyId to a tuple of Type and Object, where the Object was the value and the Type used for run-time type checking. I had to abandon it because I use Protobuff-ner for serialization, and it doesn't like Objects or Types, but as an implementation behind the scenes, that worked and allowed a single generic class. It still feels dirty, but it seems you are syaing you prefer the final solution I tried? – timbo Apr 24 '20 at 17:50
  • Yes it is. In fact "prefer composition over inheritance" appears to be the normal wording, so I will change my answer. – Simon B Apr 24 '20 at 18:30
Your problem: You have about hundred different image classes. Some, lets say six, have an "EXIF" property. The user of your library doesn't care what image class handles his image, they want to know whether the image has the "EXIF" property or not, and read or change the EXIF property. And since the user of your library doesn't know at build time what the image is, this has to be done at runtime.
One approach is that the user only sees an "Image" class, and the "Image" class has three methods "hasExif", "getExif", "setExif". "hasExif" returns true or false, "getExif" gets the data or asserts / throws an exception, "setExif" sets the data or asserts / throws an exception. The Image class would have pointers to an implementation of an EXIF setter and getter; Image classes supporting the property set them, others don't.
It will be lots of code, but all very straightforward, all clean code. Having two dozen similar properties isn't complexity.
gnasher729
  • 42,090
  • 59
  • 119
  • Thanks @gnasher729. One thing I like about the has/get/setProperty as opposed to has/get/setExif is that for new properties this is a little more forgiving. I don't need to add has/get/setSpecialNumber to the Image interface and then implement them for every single concrete class - though I can use default implementations in the interface or a Java-style adapter I guess. On the other hand, your approach does give compile time type-safety. I think it is either this, or sticking with what I have. – timbo Apr 28 '20 at 22:33
If I understand your question properly, your problem is not with the image processing at all, it is simply in presenting the full set of properties to the reporting app when you have so many variations of property sets.
There's a very simple solution to this: use a dictionary (a.k.a map). Add a single method called GetProperties() (or something) like that to a base interface that all the image classes implement. Each type of image can then present its properties to the reporting layer. The reporting layer then can simply iterate over all the properties and present them.
It might be good enough to just have a dictionary of strings keys and string values. This leaves the job of how to present them in the image class which can be problematic if some of these properties are complex (e.g. made up of multiple values) and you need to be able to present them in various ways. In that case, it might be useful to define a second interface which accepts a presentation object and calls methods on it to describe the property. I'm short on time at the moment but if you want more detail on that, I can get back to you, upon request.
JimmyJames
  • 24,682
  • 50
  • 92
  • Thanks Jimmy; that's actually pretty much exactly what I did! The final solution I tried exposes five methods; HasProperty, GetProperty, SetProperty, AddProperty and ListProperties. Five might seem excessive when three would do, but I was following patterns used by other Microsoft libraries that we use for consistency. The properties were backed by a Dictionary that mapped an enum to a tuple of Type and object. A string to object would do, but the enum and Type gave some extra type-safety, even if only at runtime. – timbo Apr 28 '20 at 07:26
  • Great. Don't forget to upvote helpful answers and select on as the solution if applicable. – JimmyJames Apr 28 '20 at 14:24
tl;dr Sounds like you're basically decompiling the old source code; since decompilation tends to yield messy results, that you're getting messy results seems like a foreseeable consequence. So instead of a bottom-up refactoring, you'll probably need a top-down redesign where the old code can help fill out implementation details, but probably shouldn't rely on it to provide the overall logical structure.
My suspicion is that you're doing a bottom-up approach rather than a top-down approach.
For example, consider a well-designed program that's then compiled to native code with aggressive optimizations enabled. Then someone takes that compiled-program and decompiles it. Regardless of the input program's clear, elegant structure, the decompilation of it can be a real mess.
So my suspicion's that, in refactoring this older program, you're doing it kinda like a decompiler – instead of taking a top-down approach, you're trying to decompile the old source code piece-by-piece, resulting in the same sort of mess that decompilers typically produce.
Fundamentally, you can't do the refactoring piece-by-piece; instead, you need to figure out some general logical structure that can describe everything, then descend from that, as in a top-down approach. This is, write your new program as a new program rather than as a decompilation of an old program.
Specifically, forget about the issues with interfaces and properties and whatnot for now. Instead, focus on how to structure the overall logic that describes, say, images, if that's what you're working with. Figure out an abstraction that encompasses them all, then build subtypes that narrow in on specifics. Once you have a good logical structure, then you can draw from the old code to help fill out the implementation details.
Otherwise, it'd seem like you'd be stuck doing the work of a decompiler, with the messy final product being a foreseeable consequence.
Thought experiment: Why do decompilers produce such messy results?
You may want to take some time to look into decompilation and consider why, exactly, decompilers don't exactly reproduce good source code, especially when the original program was written in a very high-level language and then compiled to native code with aggressive optimizations.
Once you get a handle on that, look at the source code you're refactoring as compiled native code. I mean, yeah, you may be refactoring stuff that's already in C#, but C# isn't the real source code; the real source code existed in the original software designer's mind, which they then compiled into C#. This compilation from-mind-to-C# is a lossful process, much like compiling C# to native-code is; and, like a decompiler not getting the structure that was lost in the compilation, you're not getting the structure that was lost when whoever first wrote the code compiled it into C#.
Which you can't really fix. Unfortunately, if the original programmer is gone, the original source code is, too. The C# you've got is a poor substitute for the actual full specification that once existed in someone's mind.
In short, my suggestion'd be to focus on how your refactoring approach is like what a decompiler does. Once you get that, I suspect that the way to fix it should be more obvious.
Nat
  • 1,063
  • Thanks for taking the time Nat. Actually, I do not decompile anything. I usually start with a known image file in an unknown format. I then work out how to go from that data to a viewable image. If I have data left over, I try and work out what that data represents. This metadata often represents values I had not anticipated. For example, it might include a reference to a user account on some site. It might include medical jargon referencing the type of medical imaging used. The point of the program is to report on all of the data. This makes top-down design that handles unseen cases difficult – timbo Apr 27 '20 at 16:52
The problem here is the lack of encapsulation. Interfaces should opt to expose methods over properties. By having the calling code access the properties in each of these implementations, knowledge leaks out from the implementation to the caller.
Would it be possible to delegate the responsibility of reporting to each implementation? You would then have a GenerateReport method on your interface and the caller would not need to know what properties the class has.
Repeat for the other ways in which the class is used and you might find that the responsibilities are more clear.
The dictionary solution sucks because you lose static type checking, but those properties shouldn't be publically accessible in the first place. Once they are private, static typing will work out naturally and you will be forced to figure out ways to keep the format specific knowledge in the format class itself.
Jared Goguen
  • 200
  • The images are one part of a document, but there are others. Reporting needs to report on all files of all types. Putting that responsibility on the image library starts to turn the whole thing into a monolithic class. Reporting on multiple different data types seems clearly different to Image IO to me, and having individual GenerateReports wouldn't allow the kind of integrated reports we have now. – timbo Apr 30 '20 at 06:05
In Swift, and possibly other languages, another approach may be possible: in Swift you define a protocol (almost the same as an interface) say ExifHandler with two methods getExif and setExif. Any class or struct independent of can declare that it supports ExifHandler. Your code accessing the property would look like
If let handler = image as? ExifHandler {
    let exif = handler.exif
    handler.exif = newExif
Or:
If let exif = image as? ExifHandler? .exif {
gnasher729
  • 42,090
  • 59
  • 119
  • This does seem very similar to Interfaces. I'm not sure how a protocol differs in any meaningful way, at least in the context of this problem. – timbo Apr 30 '20 at 06:06
