Consider that you've got a POJO that you intend to serialize and send through a socket.
You can use whatever serialization strategy you wish (JSON, XML, protobuf, ..., etc) to serialize the actual POJO into a byte[], then you send it through the socket.
The byte[] arrives on the other end, but in this receiving context you do not know what class the information represents, so how do you know which POJO class to construct to begin populating its fields?
I'd want to do this without the need to have multiple endpoints/sockets within the context of which I could assume the type of data that is being received. I want to receive all sorts of different POJOs in the same socket context.
One idea was to share a mapping across these contexts, mapping a type code to a class type. I could then build some sort of user defined frame with which to transport the data.
| 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 |
|                      TYPE CODE SECTION (32 bit int)             |
|                      PAYLOAD LENGTH SECTION (32 bit int)        |
|                          PAYLOAD SECTION                        |
|                          PAYLOAD CONTINUED....                  |
On serialization, I would insert this type code into the frame, then append on the byte[] that is the serialized POJO, then send this frame!
On the other end, I could extract this type code from the frame, and look it up in the shared mapping. Voilla! I now know which class was sent through the socket, and can de-serialize smoothly
However, this seems bad, because now all of these contexts are coupled together with this shared mapping. What if I want to make my project micro-service oriented? It could get ugly, especially if the mapping could be different for a different use case.
It occurred to me that this is a problem people have solved, and maybe I just don't know the name for this type of thing, or the high level design patterns/ideas.
Could someone provide some context? What solutions already exist that already solve this problem? Is there a name for this type of thing?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
tgabb
  • 131
    It sounds like you're asking how to get two sides to communicate with each other without one or the other side knowing anything about the format messages of being sent or received? If so, It would help to understand what you think the actual problem(s) would be by having both sides knowing how to serialise and deserialise a message, since this is a normal thing to do with any kind of messaging - I can't think of any reason why it would be a problem. – Ben Cottrell Mar 04 '20 at 21:30
  • You're basically **multiplexing** multiple transports (for OOP objects like POJO) onto a single byte-stream transport - single in point-to-point sense. – rwong Mar 05 '20 at 03:43
  • As for the "mapping", it just need to be "unique" or "incapable of ambiguity" as far as your own business is concerned. – rwong Mar 05 '20 at 03:50
  • Object (class) versioning can be handled depending on your needs. Do you want to handle it like missing/ignored fields, for example? – rwong Mar 05 '20 at 03:52
  • Do you need sender and end-recipient to negotiate for readiness e.g. both agrees that they are capable of handling a particular object type, e.g. by having the correct version of Java bytecode for that class? – rwong Mar 05 '20 at 03:54
The short answer is that you have to provide sufficient metadata to allow the receiver to recognize what to do with the message data.  You want some approach that supports extensibility and loose coupling.
A client and server are already somewhat tightly coupled if your metadata assumes that all receivers are Java with POJO classes readily available to instantiate.
So, rather than describe metadata about what the original Java class was on the sender's side, we might prefer to describe the nature, content, and format of the message itself.  It's probably easiest to assume one of either JSON or XML on both sides, since they at least offer a way to parse the syntax of messages so you can get on to the semantics of the messages: understanding the fields and their content.
Focus on describing the domain oriented nature/intent of various messages, and, versioning to allow evolution — ideally, independent versioning of clients and servers.  In some of these approaches you'll see some fields described as "must understand", for example; while other newly added fields can be safely ignored when not understood.
Schemas are good to use here — they'll give you a way to describe what forms a legal message of some type and a way to encode that description within a message.  Different messages kinds will either have their own schema or augment some common schema with additional field information.
Protocol buffers are good to use when you know what you're doing, want fast and simple, and don't want the baggage of a lot of built-in flexibility.  From wikipedia:
Canonically, messages are serialized into a binary wire format which is compact, forward- and backward-compatible, but not self-describing (that is, there is no way to tell the names, meaning, or full datatypes of fields without an external specification). There is no defined way to include or refer to such an external specification (schema) within a Protocol Buffers file. The officially supported implementation includes an ASCII serialization format, but this format—though self-describing—loses the forward- and backward-compatibility behavior, and is thus not a good choice for applications other than debugging.
Of course, you can include your own string or id number to name or identify the schema, but now you're inventing a custom schema system, and it might be better to use an existing one as there are lots of pitfalls to encounter.
Erik Eidt
  • 33,282
  • 57
  • 91
    I've been reading up on those links you provided, and considering the nature of protocol buffers and the need to provide some sort of context in order to resolve a buffer into a POJO/POCO, I think your schema-oriented suggestion helps to simplify things a bit. I could define the structure of a message, reject those that are not valid, and parse validated JSON in order to determine the intent of the message, and invoke some behavior accordingly. Correct me if I'm wrong, but your suggestion eliminates the need for having POJO/POCO classes ready for instantiation, which greatly reduces coupling. – tgabb Mar 05 '20 at 19:23
The fundamental basis of communication is that the sender wants the receiver to reach a desirable state (otherwise why would the sender bother?).
To achieve this the sender must send a message that will cause the desired outcome in a well behaved receiver (an insane or subversive receiver can not be reasoned with anyway...).
Immediately this requires some form of agreement between sender and receiver. The goals of the sender need to be achievable. (If the hat of who is the sender moves around in the communication, then each sender hat wearing participant needs to be able to reasonably achieve their goals).
So the question is what are the goals you wish to achieve?
If you want to describe data, your friends are JSON, YAML, XML. Use them or take inspiration from them. They define a number of primitive types, and provide a mechanism for combining them into more complex structures. This allows you to pass arbitrary arrangements of data without having to agree upfront on the structure. The Data itself self-describes its format. The downside is figuring out on the client how to deal with the message, its not immediately obvious.
If you want to describe specific messages, then block style languages like PNG (yes the image format, take a look at the spec), and BitTorrent are your friend. Each block has a header with total block size, potentially some management flags, and a type identifier. This allows messages to be skipped if irrelevant/indecipherable, and those messages which are understood can be safely deserialised. This is great for latency as the communication is streamlined and any reaction to a message can be done very quickly. The downside is that the messages have to be agreed upon in advance. You can get around this by making one of these messages transmit just data (like JSON).
If you want to have an extensible language take a look at FTP, VT (Virtual Terminal), Telnet wire protocols. They have a special kind of meta message for negotiating which extensions are available, which are preferred, and then to enable those extensions. This provides a kind of half-way point. Both sides have to reach an agreement but can agree to different sets of messages, and may choose to enable/disable those message throughout the communication. This allows for new messages set to be made later, and only when both sides have implemented them will they (possibly) be used.
Kain0_0
  • 15,888
A design that requires disambiguation by default, I'd consider broken unless there was a specific reason to do so. Now, are these objects completely orthogonal or are they polymorph? By polymorph I mean there is some sort of base class, like
class eventbase {
     string sender {get; set; }
     DateTime time {get; set; }
     string type {get; set; }
class usernamechangedevent: eventbase {
     string name {get; set; }
In this scenario, you can often deserialize into a the base type, read the acutal type, then deserialize into the actual type. See also: Polymorphism in protocol buffers
We (developers) worked long and hard to make things type safe. In general I would recommend to keep it that way.
Martin K
  • 2,867
  • They need not be orthogonal, no. In the end my goal is to transmit a message/instruction in the form of a serialized object, that can then be used to publish an event in the application layer, to which some sort of listener is waiting to enact an action/behavior. The information needed to convey the instruction may differ from message to message. My concern is, mainly, that I must share information across the transmitting/receiving contexts in order to define what has been received. For example, the use of the string "CAT" in the forWire and fromWire. – tgabb Mar 04 '20 at 21:18
    The simple answer is to "wrap it". Wrap the actual (discriminated) message/instruction types in a wrapper class that carries just the basic info to allow limited handling. One way to do this is to serialized the actual thing first, then put the data in the wrapper object's field as a byte array. The wrapper object should contain the type code, sender, intended recipient(s), and some kind of event ID and/or sequence ID. Meanwhile, recipients need to have a mechanism to handle that when they receive a novel type code that they aren't prepared to receive (e.g. they don't have the byte code) – rwong Mar 05 '20 at 03:33
    As for keeping the type code stable and synchronized across a fleet of computers, there are many approaches. But if you really need to fit that into 32-bit, it will probably involve some central authority. (Hashing the class name from a string into 32-bit wouldn't eliminate hash collisions. Meanwhile, 64-bit hash will do.) – rwong Mar 05 '20 at 03:38
  • Thank you @rwong I had tried hashing before but I was using java's built in object hash, which can differ across different run-times. If I were to use some sort of standard like SHA-256 (or something a bit lighter) that guarantees a string hashed to the same value no matter the runtime, then I could remove ambiguity. In regards to your comment about central authority, what are your thoughts on moving all possible messages and type-codes into a separate library for example that the server/client can import? – tgabb Mar 05 '20 at 17:55
    Compiling all message POJO and type-codes into a library for easy deployment and import sounds like good idea; that depnds on whether you can pull it off. As in, you need a systemwide build automation or continuous integration, and make sure nobody does anything that disrupts it. – rwong Mar 05 '20 at 20:36
    I really suggest allowing 64-bit hash as it does "almost practically" eliminates hash collisions for class name strings. Instead of having a Message POJO library, you may also consider a server-client Java bytecode distribution system, where unseen hashes can be used by nodes to download the new classname string and POJO definition bytecode from the "bytecode" server. (Of course it might be unnecessarily complication; it is up to you to decide how to keep things simple) – rwong Mar 05 '20 at 20:40
  • also consider a schema registry – Martin K Mar 06 '20 at 12:42
