36
Suppose I'm creating a game played on a 2D coordinate grid. The game has 3 types of enemies which all move in different ways:
  • Drunkard: moves using type 1 movement.
  • Mummy: moves using type 1 movement, except when it's near the main character, in which case it will use type 2 movement.
  • Ninja: moves using type 3 movement.
Here are the ideas I've come up with in organizing the class hierarchy:
Proposal 1
A single base class where each enemy is derived from:
abstract class Enemy:
    show()   // Called each game tick
    update() // Called each game tick
    abstract move() // Called in update
class Drunkard extends Enemy:
    move() // Type 1 movement
class Mummy extends Enemy:
    move() // Type 1 + type 2 movement
class Ninja extends Enemy:
    move() // Type 3 movement
Problems:
  • Violates DRY since code isn't shared between Drunkard and Mummy.
Proposal 2
Same as proposal 1 but Enemy does more:
    move()           // Tries alternateMove, if unsuccessful, perform type 1 movement
    abstract alternateMove() // Returns a boolean
    alternateMove(): return False
    alternateMove() // Type 2 movement if in range, otherwise return false
    alternateMove() // Type 3 movement and return true
Problems:
  • Ninja really only has one move, so it doesn't really have an "alternate move." Thus, Enemy is a subpar representation of all enemies.
Proposal 3
Extending proposal 2 with a MovementPlanEnemy.
class MovementPlanEnemy:
class Drunkard extends MovementPlanEnemy:
    alternateMove() // Return false
class Mummy extends MovementPlanEnemy:
    alternateMove() // Tries type 2 movement
Problems:
  • Ugly and possibly over-engineered.
Question
Proposal 1 is simple but has a lower level of abstraction. Proposal 3 is complex but has a higher level of abstraction.
I understand the whole thing about "composition over inheritance" and how it can solve this whole mess. However, I have to implement this for a school project which requires us to use inheritance. So given this restriction, what would be the best way to organize this class hierarchy? Is this just an example of why inheritance is inherently bad?
I guess since my restriction is that I have to use inheritance, I'm really asking the broader question: in general, when is it appropriate to introduce a new layer of abstraction at the cost of complicating the program architecture?
1201ProgramAlarm
  • 1,529
Frank
  • 471
    Your example looks incomplete and your use of private is confusing. It is not clear what methods are supposed to be overrides. – Martin Maat Feb 15 '20 at 21:29
  • Are you using a programming language that requires all code to be placed in a class? If not, there should be a way to share the movement-type-1 code between `Drunkard` and `Mummy` in the first approach. – Bergi Feb 16 '20 at 06:01
  • `abstract move()` has to be implemented as required, so where is the problem? Even combined with `abstract alternateMove()` this wouldn't be a problem - because one does not necessarily have to add code into every single implementation of the method. – Martin Zeitler Feb 16 '20 at 09:00
    I don't think it's worth me creating a new answer because it would be a rewording of existing answers, but I'd like to offer some recommended reading on the component pattern and the 'type object' pattern (for which there is some overlap here): http://gameprogrammingpatterns.com/component.html, http://gameprogrammingpatterns.com/type-object.html – Pharap Feb 16 '20 at 10:10
    This shows the weaknesses of the object approach. Classes are used for all of polymorphism, code reuse and encapsulation, but you actually need different structure for each aspect. That's why new languages like Go or Rust separate them. – Jan Hudec Feb 16 '20 at 21:24
    Your mind is too focused on reusing code via inheritance. You can reuse code by simply invoking a function. Trying to solve all problems with a single big inheritance tree is not a good way. – Gherman Feb 17 '20 at 17:01
    I wrote a series of articles about this tendency to try to capture rules of a game into a class hierarchy and how it goes wrong; see https://ericlippert.com/2015/04/27/wizards-and-warriors-part-one/ to see why going down this road is possibly a bad idea. Particularly in OO languages that have single inheritance. – Eric Lippert Feb 18 '20 at 19:27
  • Consider also whether "Enemy" is the right metaphor here. First: are all entities in the game that can make movements *enemies*? Is the player's tamed dragon an enemy? Is the water nymph that hands out magic swords an "enemy"? Probably not. Second, if it is necessary to capture "show/update/move" in a type, **why does that type not also apply to the player?** Players have all those operations as well. Think about what your game engine is really modeling here. – Eric Lippert Feb 18 '20 at 19:31
10 Answers10
68
I've built a 2D roguelike from pretty much scratch, and after lots of experimentation, I used an entirely different approach. Essentially an entity component architecture.
Each game object is an Entity, and an Entity has many attributes which control how it responds to stimuli from the player and the environment. One of these components in my game is a Movable component (other examples are Burnable, Harmable, etc, my GitHub has the full list):
class Entity
    movable
    harmable
    burnable
    freezable
Different types of enemies are distinguised by injecting different basic components at object creation time. So something like:
drunkard = Entity(
    movable=SometimesRandomMovable(),
    harmable=BasicHarmable(),
    burnable=MonsterBurnable(),
    freezable=LoseATurnFreezable()
and
ninja = Entity(
    movable=QuickMovable(),
    harmable=WeakHarmable(),
    freezable=NotFreezable()
Each component stores a reference to its owner Entity for information like position.
The components know how to receive messages from the game world, process them, then generate more messages for the results. These messages land in a global queue, and there is a main loop each turn which pops messages off the queue, process them, then pushes and resulting messages back on the queue. So, for example, a Movable component does not actually edit the position attributes of the owning entity, it generates a message to the game engine that they should be changed, along with the position in which the owner should be moved to.
There's essentially no class hierarchy for the basic game entities, and I did not find myself missing it. Behavior is distinguished entirely by what components a entity has. This works for every entity in the game world, player, enemy, or object.
Matthew Drury
  • 754
This is why we often like interfaces over inheritance: Many real-world problems cannot be modeled in an object hierarchy.
interface IMove
    // returns an intermediate location chosen with
    // the intention to move toward destination
    Point Move(Point currentLocation, Point destination)
Now we can inject an IMove, or we can write a "move this object using strategy ninja" type of function.
We can also test the movement strategies separately
Martin K
  • 2,867
I would follow your first option, but then use the strategy pattern for the different move styles. This will allow you to swap move styles and alter moves styles easier moving forward.
So you’d have an interface called MoveStyle and then several classes implementing it for each kind of movement.
Adam B
  • 1,506
    So would this be moving toward the "composition > inheritance" style? In "composition > inheritance," I would just implement a "Movable" interface (which would contain a movement strategy) that you would pass in to create a new game object. – Frank Feb 15 '20 at 19:51
  • Not quite. You still have inheritance for your enemy types. But you use a composition style for their movement. – Adam B Feb 15 '20 at 20:00
  • @AdamB If the only difference between those enemy types is that they use different move styles, you should indeed just inject the move style into the `Enemy` class. – Bergi Feb 16 '20 at 06:09
  • Agreed but something like enemy movement is very liable to change. And be extended to other classes. Like ally. So using this protects you from such future changes. – Adam B Feb 16 '20 at 08:07
    Composition is woefully underused - for two reasons: 1) because most books promoting O-O design promote inheritance to a much greater degree, and 2) because most programming languages supply built-in constructs to support inheritance and nothing built-in to support composition (e.g., automatically forwarding method calls). (So composition requires manual "effort" where inheritance is practically free to the programmer.) Nevertheless - composition should be used much more often, and here's an example of where it should be used. – davidbak Feb 16 '20 at 20:16
    @davidbak Books, and _courses_! Think university, schools etc. And they all focus on it a lot when in reality the problem that it solves is... an edge case. Every "real" professional codebase I have seen uses inheritance in less than 1% of the code. – R. Schmitz Feb 17 '20 at 10:40
    @R.Schmitz - correct: courses too and how inheritance is used in practice _except_ in Java codebases where you frequently (and stupidly) have multiple "parallel" inheritance trees for model/data access/uI. BTW - should have mentioned this before, but look at Kotlin for a language (only one I know of) with decent support for composition. Hopefully the idea will spread and even be improved on. – davidbak Feb 17 '20 at 14:15
The answer to your main question:
is relatively simple and straightforward:
When the benefit outweighs the cost
You need to be certain about the benefits and costs involved. An additional abstraction layer will not complicate a project with 3 classes too much, but it might be a deal-breaker in a project where dozens of classes would be affected. Refactoring logical abstractions into a model is very much nontrivial and needs to be carefully weighed against the benefits.
As far as the benefits are concerned, the two broad aspects I would be looking after are high expressive power, as well as high adaptability. In short, if it makes your code more expressive, that's a plus. If it makes it flexible to easily adapt to forthcoming unforeseen requirements, that's an even bigger plus!
Do not underestimate the expressive power, because that's where adaptability also hides. The better you understand and "mimic" your modeled domain, the better you can "foresee" potential future requirements.
Also
Depending on your perspective, you might be confusing the true meaning of abstraction. Abstractions are powerful, because they hide details. You state:
No, it's the other way around. Your "Proposal 1" has a higher level of abstraction compared to "Proposal 3". Take a step outside of where you stand. You know nothing about your design, and you present it to others.
From your "Proposal 1", I immediately know you have some kind of entity termed Enemy which you can show, update and move. Plus you have some specific types of Enemy.
From your "Proposal 3", I know, additionally, that there is a special type of Enemy, called however you like, e.g. MovementPlanEnemy. Some of your types implement this instead of the basic Enemy type, so now, I know more about your types. You are becoming more specific, you offer two types of movement, plain and alternative.
Think about where you are going to use these types. Within your game, you will, eventually, have to declare the general base types, so that you can compose your logic. Wherever you declare your types as MovementPlanEnemy, you are "leaking" more details than if you would declare them as Enemy. When I know more about your design, you go down the ladder of abstraction, towards "concretion". When you do that, you usually lose expressive power because you have less flexibility. You now offer more information and this complicates things more as you will have to support these specific provisions of yours in future versions of your code (or force everyone using them, including you, to change their code to adapt to your new decisions).
Also (part II)
For your "Proposal 1", you state:
You might be being somewhat too strict with your assessment there. Of course code will not be shared between Drunkard and Mummy. DRY (Do not Repeat Yourself) does not mean do not write identical lines of code. It means, strive to reuse your concepts. Type 1 Movement is a concept and you can avoid repeating yourself regarding that quite easily by, for example, using static helper classes, or, as others have stated, through composition and interfaces (strategy pattern and whatnot). But tomorrow, you may be required to add another character that moves like two already existing characters. Would you change the abstraction again, in order to separate movement types into more groups?
In short, you don't need to change your entire model just to accommodate the fact that some of your classes share part of their behavior. The reason for this is that, in your case, the common code is most likely a coincidence and not an actual design detail decision. You need characters that move on a 2D-grid, each in its own way, based on the circumstances. Your other proposals, implying characters that can move in two different ways (at most), will also necessitate the actual support of two ways at most and, suddenly, you will find yourself making additional checks throughout the main game logic, to find out how your characters should move (i.e. which method to call, move() or alternativeMove()). The decision about how characters should move is best contained (encapsulated) within the character classes, potentially aided by supplying additional details (preferably through the constructor of each character). The only model that supports this design choice is your "Proposal 1" and you should keep this and try to solve the rest of your problems without sacrificing its high abstraction level.
Vector Zita
  • 2,372
If you make Mummy extend Drunkard (you could argue it's a slightly smarter drunkard) instead of Enemy, your conditional can either call the base (i.e. Drunkard) move() or use type 2 movement. You can see this as a variant on Proposal 3, in which there's no alternateMove(), and Drunkard serves the role you gave to the MovementPlanEnemyclass. That class's name, incidentally, is more suggestive of the strategy-class approach in @AdamB's answer.
Another way to prevent DRY violation is to make a type 1 movement method live outside all enemies' classes, and have Drunkard and Mummy call it as needed. Depending on how you implement this approach, it can reduce to @AdamB's idea to also have a MoveStyle class. You don't have to create yet another class, but the type-1 movement method has to live somewhere.
As @Gqqnbig noted, the first of these suggestions has one big downside: maintenance. It only "works" in the YAGNI sense that we don't currently need Mummy to differ much from Drunkard, so such an inheritance respects the spirit of our current needs. Mummy inheriting from Drunkard may lead to many more overrides being needed in the long term. Since this is for a game, the most obvious issue is we'll eventually add audiovisual indicators of the enemy type. That's probably why they call it YAGNI rather than YDNIRN (You Don't Need It Right Now).
J.G.
  • 325
    I'm highly against at making Mummy extend Drunkard. Thinking from real word or from the general background of your game, is Mummy a type of Drunkard? Does Drunkard in the game world somehow evolve to Mummy? If no, then do not extend solely because of their movement style. In the future, if you develop the game more, Mummy and Drunkard are likely to reveal some other distinct behaviors. – Gqqnbig Feb 16 '20 at 07:02
  • @Gqqnbig You're right, I should have thought more about the future. I've added a paragraph addressing this. – J.G. Feb 16 '20 at 09:57
You're overusing object hierarchies.
(For a bit of background reading: An execution in the kingdom of the nouns, by Steve Yegge.)
You've created an object hierarchy of Enemy's. That's a perfectly fine thing to do in itself, when there's enough shared data and functionality among all Enemies. However, into this hierarchy you have shoved functionality which doesn't reasonably belong in it: show(), update(), move().
These methods:
  • Are mostly not from the game's conceptual space (Mummies don't update themselves, and drunkards don't switch from being not-shown to shown).
  • Require information, and affect state, which is not part of the Enemy object.
  • Do not specialize in accordance with the class hierarchy - which is what you noticed: A Mummy and a Drunkard partially share a kind of movement.
  • Likely don't need access to the Enemy objects' private members (/protected members), and can make do with the pubic fields and methods.
Many answers here suggest you use even more objects, more nouns, complex combinations of interfaces or aspects or abstract base classes which can capture the commonality of Mummy and Drunkard movement. But - I'd say that this kind of shoe-horning is a bad idea.
IMHO, you need to let go of the assumption that game logic belongs in class definitions, and you have to force it in there if it doesn't fit.
Focusing on movement - you should seriously consider:
  • Making move() a freestanding function, or a method of your Board class etc., which takes an Enemy as a parameter.
  • Collecting most of your "move logic" into that function.
  • If you really need a lot of flexibility, having a helper function, say, resolve_movement_type(), which takes an Enemy and some state information as parameters (e.g. distance from player, or time-of-day and so on) etc. Then you can call a more specialized movement routine - type 1, 2 or 3.
and perhaps something similar in spirit for show() and update().
einpoklum
  • 2,478
  • 30
Note: You forgot to mention preferred P.L.
Conceptually speaking, each Enemy has a single movement, either simple or complex so, lets start with :
  show( )
  update( )
  move ( )
Let's add the subclasses, for the moment, just think, every class move is just different.
class Drunkard: extends Enemy
  /* override */ move ( )
class Mummy: extends Enemy
class Ninja: extends Enemy
Ok, we already know move can be mixed or simple, and simple may not be used for all subclasses.
There are two ways to deal with it. One is to add the simple methods as protected methods like:
  show( )
  update( )
  move ( )
  /* protected */ simplemove1 ( )
  /* protected */ simplemove2 ( )
  /* protected */ simplemove3 ( )
And, each subclass move method calls the required simple methods. But, this will not help, if we want to add more enemies, and movements.
Another way is to use "traits", similar to "interfaces", but its not implemented by several P L.
The third option is, as you already know, to delegate the move operation to another class.
abstract class MoveOperation:
  move ( )
  show( )
  update( )
  move ( )
And, it does add an extra, but still valid, layer.
For a moment, lets suppouse movements are simple.
  abstract move ( )
class MoveOperation1: extends MoveOperation
  abstract move ( )
class MoveOperation2: extends MoveOperation
  abstract move ( )
class MoveOperation3: extends MoveOperation
  abstract move ( )
Then each overriden move( ) operation will create and call the required method.
Ninja.move ( ):
    MoveOperation M = new MoveOperation1( )
    M.move( )
But, since you can combine those, then lets create a simple class and a composed class:
abstract class SimpleMove:
  abstract move ( )
class MoveOperation1: extends SimpleMove
  move ( )
class MoveOperation2: extends SimpleMove
  move ( )
class MoveOperation3: extends SimpleMove
  move ( )
And then, the composed operation:
abstract class ComposedMove:
  abstract move ( )
class DrunkardMove: extends ComposedMove
  move ( )
class MommyMove: extends ComposedMove
  move ( )
class NinjaMove: extends ComposedMove
  move ( )
NinjaMove.move:
  SimpleMove1 M1 = new SimpleMove1( )
  SimpleMove2 M2 = new SimpleMove2( )
  M1()
  M2()
And the Enemy class provides:
  /* protected */ ComposedMove Action
  show( )
  update( )
  abstract move ( )
Ninja.move ( ):
    this.Action = new NinjaMove( )
    this.Action.move( )
And the "Beauty" of this, is that you can add later, other "Enemies":
class EvilKittyMove: extends ComposedMove
  move ( )
class EvilKitty: extends Enemy
Cheers.
umlcat
  • 2,146
  • I would agree, but this seems overengineered. You can drop the `DrunkardMove`, `MummyMove`, `NinjaMove`, `Drunkard`, `Mummy` and `Ninja` classes. All you need are `Movement1`, `Movement2`, `Movement3` and `ComposedMovement` (plus their interface), and give the `Enemy` a `movement` attribute / constructor parameter. – Bergi Feb 16 '20 at 06:06
  • The first method might be something like what the instructor had in mind, given the stipulation that "I have to use inheritance." It's not as general a solution as `MoveOperation` but it's better than copy-and-paste between the various `move` functions. – David K Feb 16 '20 at 13:27
  • What exactly is P.L.? – candied_orange Feb 16 '20 at 14:47
  • @candied_orange Programming Language – umlcat Feb 19 '20 at 23:36
From where mainCharacter comes from?
From your description, move() sometimes depend on data from main character, sometimes not.
In this situation, mainCharacter must be a parameter of move() in the interface. It's a implementation detail in derived class if it is used or not.
If mainCharacter is a global or contextual data in your game engine, so any code can reach, then it's a implementation detail of Mummy's move() to:
    move()
        if ( self.IsNear( context.MainCharacter ) )
            moveType2()
        else
            moveType1()
In a game engine, you probably return a composite object containing:
class CalculatedMove
    var Sprint
    var Location
    move()
        return new CalculatedMove( self , calculateNextPositoin( context.MainCharacter ) )
The user @Vector makes an important point which is obscured by his lenghty answer: DRY does not mean do not write identical lines of code.
With that said, Proposal 1 is clearly preferred, but it's potentially incomplete.
Your concern over duplicating the code for moves using type 1 movement can be addressed in at least a couple of different ways:
Option 1. Don't worry about it, go ahead and duplicate it. As your code evolves to accommodate future requirements, what are the chances that the movement for Drunkard and Mummy will remain exactly the same forever? In this case, having duplicate lines of code may prevent the introduction of future bugs where a change to one breaks the other.
Option 2. More appropriate if the movement related code is non-trivial: create a separate class hierarchy for Movement and make it an attribute of Enemy. Now you can re-use code within the Movement class:
TL;DR
abstract class Movement:
    abstract move() // Called by Enemy code to move itself
    abstract movement() // Called in update
    movement(): return new Type1Movement
    movement(): if isMainCharacter return new Type1Movement else return new Type2Movement
    movement(): return new Type3Movement
class Type1Movement extends Movement:
    move(): ... your code here ...
class Type2Movement extends Movement:
class Type3Movement extends Movement:
Alex R
  • 109
It's nice when the code resembles the spec.
Here's the spec again:
And here's a way to write the code so it resembles it:
enum EnemyType {
    Drunkard,
    Mummy,
    Ninja,
class Enemy
    EnemyType enemyType
    move() {
        switch (enemyType) {
            case Drunkard:
                movetype1()
                break
            case Mummy:
                if closeToPlayer()
                    movetype2()
                else
                    movetype1()
                break
            case Ninja:
                movetype3()
                break
Ryan1729
  • 234
