I'm working with several Excel worksheets and workbooks that need to consolidated or linked to each other. These workbooks will track client interactions for different team members.
I did the initial consolidation in Microsoft Excel, but realized that going forward, there's a risk of people overwriting each other or working from an older version of the master workbook.
After some research, I realized one idea could be to have each person track their own client interactions. I can regularly consolidate each workbook into the master using Excel data models.
But are there additional risk to doing this? Is an Excel data model as good as an Access database? I've shied away from Access because my team is not comfortable using SQL and overall dislike the Access Interface.
This is why I started off using Excel. But managing multiple workbooks (with changing names) has already created several version control issues. Any feedback would be helpful!
I'm limited to using Microsoft Office 365.
Use Cases
Log interactions
  • Each person can keep a log of daily client interactions
  • Individual logs are regularly synced to a master list that shows interactions for the whole team
Log contact information
  • Each person can contact information for new clients
  • New contact info is synced with the master list
Add or update broad company information
  • Each person can add or update general company information (ex Company A is focused on xyz for 2020). This is separate from the individual interactions
  • Updates to general company information can be added directly or synced with a master list
Filter for a list of interactions, contacts and broad information
  • Search interactions based on criteria (ex company's city, interaction date, contact's place of employment)
  • Print all information (interactions, contacts and broad information) based on a specific company name
Reporting
  • Send scheduled reports (weekly, quarterly) based on recent updates and other specified criteria (ex company with the most logged interactions for the month)
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Jasterix
  • 51
  • They are two different things, so one is not inherently better than the other. But it does sound like you need something that can handle multiple users. – GrandmasterB Feb 05 '20 at 19:21
  • Thanks for replying! It's not that it needs to handle different users. Since everyone will have access to the file (no login necessary), it needs to have a pretty simple interface, as well as generate reports about any updates/ activity – Jasterix Feb 05 '20 at 19:23
  • For what purpose? Neither should be used for a production database, but for one-off tools one will fit your needs better than the other. Identify your needs. – Berin Loritsch Feb 05 '20 at 19:26
  • @BerinLoritsch This was great feedback. I've added some use cases. This would be very much a tool for right now, to get us through the next few months – Jasterix Feb 05 '20 at 19:42
  • How many concurrent users? – Robert Harvey Feb 05 '20 at 19:47
  • OK, so Access does seem to be a better tool for your use cases. Using shared Excel spreadsheets will just cause endless headaches. – Robert Harvey Feb 05 '20 at 19:48
  • @RobertHarvey There would be 7 concurrent users. Each person would keep their own individual Excel file. Once per week, I would refresh the master to sync with their individual files. All files would be saved to your typical network shared drive (no cloud access as of now)....Edited for clarity – Jasterix Feb 05 '20 at 19:49
    Seven users seems reasonable for an Access application. You will need to have some basic knowledge of how databases work first, though. I see at least 3 different tables in your use cases: Companies, Contacts, and Interactions. – Robert Harvey Feb 05 '20 at 19:51
  • Shared access applications always have *two components:* the shared database that lives on the shared drive, and the front-end that lives on each user's workstation and connects to the shared database. Don't make the newbie mistake of putting it all into a single Access file, dropping it onto the shared drive, letting everyone open that same file from their workstation directly and expecting that to work. – Robert Harvey Feb 05 '20 at 19:53
  • @RobertHarvey thank you for your help! My team is pretty much against Access because they find the interface challenging. This is why I'm hoping to make this work with the Data Model and PowerBI tools. You're exactly right-- I would be created a front -end for each individual's workstation, and a shared database (the master list) on the shared drive. Will look more into this, since I'm used to having everything in the cloud or locally. – Jasterix Feb 05 '20 at 19:57
  • What you really need is neither Excel or Access, you are looking for a small-budget CRM system. Google for "small CRM", and you will find several suggestions. – Doc Brown Feb 05 '20 at 20:05
  • @DocBrown thanks for replying! Unfortunately, we're limited to only Microsoft Office 365. For now, we're unable to use a CRM. Do you think it's possible to make Excel work? – Jasterix Feb 05 '20 at 20:07
  • @Jasterix: most commercial CRMs are Web based and only need a web browser and internet access. – Doc Brown Feb 05 '20 at 20:08
  • @DocBrown we're unable to use any third party CRM, including web apps – Jasterix Feb 05 '20 at 20:10
  • @Jasterix: then feel free to reinvent the wheel. – Doc Brown Feb 05 '20 at 20:10
  • @DocBrown This is a pretty challenging position to be in, so I'm trying to find a creative solution that circumvent very rigid constraints. I'm not trying "to reinvent the wheel". As engineers, I'm sure you've come across similarly frustrating challenges. But I'm also sure you were able to find the solution with help and support from your peers. – Jasterix Feb 05 '20 at 20:19
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/104105/discussion-between-jasterix-and-doc-brown). – Jasterix Feb 05 '20 at 20:21
Here's your answer. There is a strong argument to use Excel because it is what your team is comfortable with, and that is pretty darned valuable.
You can use an Excel front end and have it connect to an Access database behind the scenes. If you store everything centrally then a lot of the versioning issues will be much easier to deal with-- for example, you can release new versions of your Excel workbook with new code, without users having to move their data. It also allows you to store data in real time, meaning that you don't have to deal with merges (and merge exceptions) any more.
John Wu
  • 26,032
  • 63
  • 84
The datamodel is (mostly) independent of the database. Excel is not a database.
Ms Access is a great RAD (rapid app devel) frontend, but db (MDAC/Jet) is limited on multiuser, security and backup (no dumps, binary log, etc), but fast and no db-server needed!
You can work with Excel, but fetch data from a db (company enviroment Sql Server, MySql, Postgre are recommended (besides other)) as for speed, function, security and backup from a data connection. Also the MDAC connectors bitness issue is sad! Connectors (ODBC/ADO) can't be used side by side for x86/x64 apps, because you can only install one bitness, limiied to apps of that bitness (this is a killer of MDAC at all)!
Basic SQL is mandatory (for devel, not user), but you will see the benefits in pure excel too, as you can use sql on it to simplify tasks (no more loops in loops on cells).
First to master is database normalization, then decide the rest. I recommend Access as you will bind data to form (updates/inserts your changes back to db) within seconds. Try that on excel
