Before giving my opinion and suggestion, it is better to apprehend the definition from the previous cases:
Methods that make extensive use of another class may belong in another class. Consider moving this method to the class it is so envious of.
https://blog.codinghorror.com/code-smells/
with that quote in mind and assuming a simple logic of your proposal summed in an example:
TimeTable.java
public class TimeTable{
private int time1;
private int time2;
private List<Location> locations = new ArrayList<>();
//getters
SchedulerValidator.java
public class ScheduleValidator{
public List<Location> getLocationsByTime(int time){
//some logic
public List<Location> getLocationsByTime(int begin, int end){
//some logic
The above snippet in any form, is a great example of a FeatureEnvy on top of that against SRP Violation
To stay clean and complaint, the below solution meets all criteria:
private final int time1;
private final int time2;
//constructor
//some logic
//some logic
//getters
public void validate(int timeValue1, int timeValue2, TimeTable timeTable){
//some validation against user inputs, in case throws an exception
public class ScheduleChecker(){
public void check(int userProvidedTime1, int userProvidedTime2, TimeTable timeTable){
//some validation against the time table list and user inputs
//I assume this is where you will use all
public class ScheduleController{
private final ScheduleValidator scheduleValidator;
private final ScheduleChecker scheduleChecker;
private final TimeTableRepository timeTableRepository;
//constructor
public String saveSchedule(int time1, int time2){
TimeTable timeTable = timeTableRepository.find(1L);
scheduleValidator.validate(time1, time2, timeTable);
scheduleChecker.check(time1, time2, timeTable);
//no exceptions further business logic carries on after this line
This example is also testable, you can simply mock all easily and write Unit and Integration Tests.
Last of all, my suggestion is to approach breaking requirements down :
- Validator: If you receive an input and test whether they have some dirty data entries,
- Checker: Checks whether given user input corresponds to your system data
