I have a microservice I am designing for getting "Book" information, and one of the capabilities is to query Solr and fuse it with some DB results that I queried.
I am looking for, what I am calling a "query maker pattern" something that will generate dynamic solr queries. The idea in my head was a class like
public class Query {
    public Attribute[];
public class Attribute {
    public String type;
    public String value;
But I'm not sure what the best way to generate dynamic queries in an object oriented way. There is a bad way of having a bunch of functions that append strings like:
public function String addSort(String value, Boolean isAscending){
    return value + "+" + (isAscending ? "asc" : "desc");
public function String addFacet(String facetName){
    etc etc
It would be best to have something like a toString() function for the Query object, and then using that as a the request to Solr?
greg b
  • 71
  • A URI is made up of a "path" and a "query". Both of them have syntax and must be composed using uri-encoding rules. You could create a domain-specific-language (DSL) on top of those bases that gives you what you want. – BobDalgleish Dec 18 '19 at 22:33
    You'd be better just using a library for Solr for whichever language you're coding in. – Chris Murray Dec 19 '19 at 11:53
I believe the pattern you are looking for is the Builder Pattern
It should look something like this:
    public Attribute[];
    public Query(string suffix) {
public class QueryBuilder {
    string suffix;
    public QueryBuilder() {
        this.suffix = "";
    public QueryBuilder WithFacet() {
        // etc etc
        return this;
    public QueryBuilder WithSort(bool isAscending) {
        suffix += "+" + (isAscending ? "asc" : "desc");
        return this;
    public Query Build() {
        return new Query(this.suffix);
Usage:
Query myQuery = QueryBuilder.WithFacet().WithSort(true).Build();
Depending on the language you are programming you can even add some syntactic sugar:
public static class A
    public QueryBuilder Query => new QueryBuilder();
    public implicit operator Query(QueryBuilder builder) => builder.Build();
Usage:
Query myQuery = A.Query.WithFacet().WithSort(true);
ianmandarini
  • 2,758
  • 26
To build a query, you can build an expression tree then compile that into the domain-specific language.
C# does this extensively, for example it allows you to construct an IQueryable in memory and linq-to-sql will translate it into SQL.
Apparently, there is a linq-to-solr.
Martin K
  • 2,867
