I have a basic java Dropwizard service within cluster of microservices. It manages user resources with restful api styles. Let's call it user-app Then there is a new operation / api endpoint that takes long time. I decided to have a background jobs (with Quartz) to remove the long running operation from user-app and instead only let the user-app to trigger new quartz job for users/long-operation. This Quartz jobs is called user-scheduler service, a separate service in the cluster. Both user-scheduler and the main user-app service is using user-db database. The original thought of creating user-scheduler is to separate concern when scaling jobs, i.e. we can add/remove user-app without changing user-scheduler.
Now I have concern that these two services are integrating via database, which is a violation of https://microservices.io/patterns/data/database-per-service.html . But is it really though? those two are still part of user-xxx service, and thus they are allowed to talk with database.
So my question is, Do you create separate service for background job? If not, how do you handle scaling for the job?
Fajarmf
  • 125
  • When it comes to databases, you do need to be pragmatic to some degree. See my answer here: https://softwareengineering.stackexchange.com/questions/372795/in-microservice-is-it-single-database-or-single-database-instance-for-each-serv/372807#372807 As with most things in Software Engineering, the answer to whether you should use one approach or another depends on a number of factors. – Berin Loritsch Mar 16 '22 at 17:53
I think we could provide a more detailed answer having more context (eg. what this job do? which are the responsibilities of user-app?) but in general: yes, that's a very serious antipattern
Imagine we have a users-service which exposes the User resource trough CRUD apis and a userstats-service which is an async job that calculates statistics such as "how many users have the isPremium=true to tell marketing (eg through email reports) how many premium users are registered. This works fine as of now but then two (predictable) things happen
  1. the tech organization decides to separate the ownership between the "user management team" (UM) and the "reporting team" (RP)
  2. the UM works on a new feature to transition towards a three tiers pricing model: basic, premium, enterprise
What a good UM member would do here is to write a migration that transforms the boolean isPremium into an enumerated column pricingTier. Now the overall system stabilty relies on the fact that someone from UM remembers that shares a contract with the RP and communicates the imminent change, otherwise the userstats-service is gonna be broken, a bug will be opened and a fix provided
One of the main purposes of microservices is to avoid this situation by reducing the contract surface. No shared resources, barely minimum IPC, privileging denormalization. All this burden pays its cost through organizational scalability, which in many cases is more important than system scalability, but this really depends on the company size
But the consequence of this reasoning is not just "don't share the database", but rather ask yourself why to components need to share so many things. 99% of times no splitting is better of a bad splitting
Carmine Ingaldi
  • 637
I have a different view on the scheduler you have implemented. A scheduler service/module is largely supposed to be very dumb, you provide it a handler, and this gets invoked at a specific time. The scheduler by itself is unaware of the specifics of the handler and the handler should be implemented in its own business module /service.
With this view, although your scheduler would be a trigger for the module accessing the database, your logic is still in the right place and you don't violate the guideline or accessing db from multiple services.
skott
  • 489
That's not (yet) an engineering question. You have to provide more (engineering) details like expected requests per seconds, level of isolation (transactions, if any), consistency/availability requirements, whether it is required to persist (checkpoint) running jobs for them to be able to recover faster without recomputed already computed intermediate result, etc. Depending upon that you might get quite different solutions, which require different implementation/maintenance efforts.
Without abovementioned details all the answers/arguments are nothing more but a matter of taste.
Zazaeil
  • 345
  • I don´t think this information are needed. Because the main question is if its good practices to share a database between two microservices which are closely related to a domain. – Darem Jan 20 '21 at 14:57
  • @Darem well, that's kind of a dogma - each microservice comes with it's own persistence. However, it does not work when it comes down to transaction writes/read from multiple microservices (and, eventually, multiple databases) or highload. – Zazaeil Jan 20 '21 at 15:00
    true, of course. I assumed, since the question was very general, that it was also more about a general solution (dogma) than about specific use cases in which optimization is necessary. So of course you are absolutely right. Sorry for my hasty comment. – Darem Jan 21 '21 at 07:00
