I have known about the Delegation normally as you have demonstrated in your answer, but not the Forwarding.
Short answer: what you provided with the Printer code snippet is Delegation. On top of that, the given Wikipedia example 1 is yet another acceptable answer as well.
Long Answer:
I'll break the descriptions down which makes it easier to apprehend the terms and the concepts.
A simple visual to better explain the given terms :
| WRAPPER(Sending) |
| + WRAPPEE + |
| + (Receiving) + |
The Delegation
evaluating a member of one object (the receiver) in the context of another, original object (the sender). 2
This indicates to what we know from printer example. The Wrapper
The Forwarding
An often-confused technique where a sending object uses the corresponding member of another object, without the receiving object having any knowledge of the original, sending object.2
In addition, the slight difference between Delegation and Forwarding is that how the "self" keyword is bounded, according to Wikipedia;
They differ in what self refers to on the receiving object (formally, in the evaluation environment of the method on the receiving object): in delegation it refers to the sending object, while in forwarding it refers to the receiving object.3
Furthermore, the definition goes on as;
The difference between forwarding and delegation is the binding of the self parameter in the wrappee when called through the wrapper. With delegation, the self parameter is bound to the wrapper(this is what we have with the 'this' keyword in Java), with forwarding it is bound to the wrappee.3
In essence, for the sake of the Forwarding, the Receiving object should not know the details of the Sending object. This stackoverflow answer 4 explains in details the "this" and the "self" keywords in Java and Python that will give you some understanding of the Forwarding breakdown.
However, I have found out also different answers in the context of Delegation and Forwarding. I sense that there can be mixed opinions 5, 6
https://en.wikipedia.org/wiki/Delegation_(object-oriented_programming)#Language_support_for_delegation
https://en.wikipedia.org/wiki/Delegation_(computing)
https://en.wikipedia.org/wiki/Forwarding_(object-oriented_programming)#Delegation
https://stackoverflow.com/a/37657923/1958683
https://stackoverflow.com/questions/7816011/in-oop-what-is-forwarding-and-how-is-it-different-from-delegation
https://stackoverflow.com/questions/1384426/distinguishing-between-delegation-composition-and-aggregation-java-oo-design
