I often find a situation where I need to write duplicate codes in a for loop, where the "init step" to identical to the "update step":
// duplicate `next()`
for (let x = next(); p(x); x = next()) {
  f(x)
// the same in a while loop
let x = next()
while (p(x)) {
  f(x)
  x = next()
It is not much a problem when next() is short, but often it's not:
// problem is evident when next is long or even inline
let x = mmmmm(rewqreqw(rewqrqew()), rewqrewq(), rewqreqw())
while (p(x)) {
  f(x)
How can I deal with this situation?
golopot
  • 246
    Related question: [What is priming the pump? Sometimes called a priming read](https://softwareengineering.stackexchange.com/q/316209/131624) – candied_orange Sep 27 '19 at 08:51
There are multiple common approaches to avoid repeating a complex update-step:
  1. Use a lambda:
    auto g = [&]{ return mmmmm(rewqreqw(rewqrqew()), rewqrewq(), rewqreqw()); };
    for (auto x = g(); p(x); x = g(x))
        f(x);
  2. Use a dummy initialization and assign in the condition:
    auto x = dummy;
    while (p(x = mmmmm(rewqreqw(rewqrqew()), rewqrewq(), rewqreqw())))
        f(x);
    A variant using the comma-operator:
    auto x = dummy;
    while (x = mmmmm(rewqreqw(rewqrqew()), rewqrewq(), rewqreqw()), p(x))
        f(x);
  3. Use an infinite loop with a break:
    for (;;) {
        auto x = mmmmm(rewqreqw(rewqrqew()), rewqrewq(), rewqreqw());
        if (!p(x)) break;
        f(x);
Which looks and performs best in your case?
You decide.
Deduplicator
  • 8,591
  • 50
I'm not sure what language you're using, but many languages have an abstraction already for calling a function to produce the next element of a sequence, in a more precise way than a for or while loop. It's often called an iterator or a generator.
For example, in Scala, you can write:
Iterator.continually(next()).takeWhile(p).map(f)
If your language supports higher-order functions, you can create your own abstraction easily. It's also sometimes implemented in OOP languages by implementing an interface with something like a getNext and a hasNext function.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
