Indeed, you're close to the limits. So close that you might very soon face it for good. And in this case, refactoring all your code to work with several tables would be time consuming, whereas anticipating this situation now would only be a very small overhead. So better think twice.
In your situation, you could just create 2 tables, using a one to one relation. The split of columns/fields could be arbitrary. But you could have a closer look at the columns:
- Maybe you can discover some groups of columns that are at least logically related ?
- May be you can discover some groups of columns that are often either filled or empty at once. This would be a typical symptom of a single table inheritance.
- Maybe even, the one table is an artificial design simplification that mentally joins several independent but related tables? In my own experience, most of the very large tables fall into this category
- Maybe you find in the name of the columns some naming patterns (e.g.
planned_start
, planned_end
, real_start
, real_end
) that could suggest a non-obvious separate table (table key_dates
: id
, plan_or_real
, start
, ende
The advantage of one table are:
- simplicity of reports (always based on a select on the single table)
- simplicity of queries (no joins)
- performance of the queries (but the overhead of a join based on indexed columns is marginal)
- simplicity of data acquisition, if the many columns are provided by an existing file format
- no analysis risk (if some supposed relations between columns prove to be wrong, there will be no issue with the single table).
- no consistency risk (existence of oter records, validity of ides accross tables do not need to be verified).
- you don't need to manage the id: you can use an automatic id easily (with two tables, you'd need to have one table with auto id, but you'd need some code to copy the auto id in he second table; but this is only possible after the first record was inserted).
But despite all these advantages, and unless I would have to provide a solution without code, I would nevertheless go for a solution with several tables instead of starting with so little margins to add more.
