Dictionaries (C# or otherwise) are simply a container where you look up a value based on a key. In many languages it's more correctly identified as a Map with the most common implementation being a HashMap.
The problem to consider is what happens when a key does not exist. Some languages behave by returning null
or nil
or some other equivalent value. Silently defaulting to a value instead of informing you that a value does not exist.
For better or for worse, the C# library designers came up with an idiom to deal with the behavior. They reasoned that the default behavior for looking up a value that does not exist is to throw an exception. If you want to avoid exceptions, then you can use the Try
variant. It's the same approach they use for parsing strings into integers or date/time objects. Essentially, the impact is like this:
T count = int.Parse("12T45"); // throws exception
if (int.TryParse("12T45", out count))
// Does not throw exception
And that carried forward to the dictionary, whose indexer delegates to Get(index)
var myvalue = dict["12345"]; // throws exception
myvalue = dict.Get("12345"); // throws exception
if (dict.TryGet("12345", out myvalue))
This is simply the way the language is designed.
Should out
variables be discouraged?
C# isn't the first language to have them, and they have their purpose in specific situations. If you are trying to build a highly concurrent system, then you cannot use out
variables at the concurrency boundaries.
In many ways, if there is an idiom that is espoused by the language and core library providers, I try to adopt those idioms in my APIs. That makes the API feel more consistent and at home in that language. So a method written in Ruby isn't going to look like a method written in C#, C, or Python. They each have a preferred way of building code, and working with that helps the users of your API learn it more quickly.
Are Maps in General an Anti-pattern?
They have their purpose, but many times they may be the wrong solution for the purpose you have. Particularly if you have a bi-directional mapping you need. There are many containers and ways of organizing data. There are many approaches that you can use, and sometimes you need to think a bit before you pick that container.
If you have a very short list of bi-directional mapping values, then you might only need a list of tuples. Or a list of structs, where you can just as easily find the first match on either side of the mapping.
Think of the problem domain, and pick the most appropriate tool for the job. If there isn't one, then create it.
