I'm working on a feature where users can get data based on the if statement they write. The if statement looks something like the excel's conditionals.
Basic syntax:
IF ( lhs == rhs, ifTrue, ifFalse)
Examples:
IF ( (2 + 2 - (2 * 1)) == 2, "Equal!", 0)
IF ( "ABC" > "a", IF (1 == 1, 100, 200) , 0)
IF ( "hello world" == concat("hello ", "world"), $myVar$, 0)
Note: There can be nested if statements/expressions and variables are identified by $
wrapper. Example: $var$
What I've tried so far:
- Using Regular Expressions and string manipulation but I realized that it won't hold when the statement gets complex.
- Using Doctrine Lexer package to breakdown the statement into tokens as per the grammar. This helps in identifying the type of tokens but doesn't help in checking if the statement is syntactically correct or how to evaluate the expressions.
Question
How do I go about parsing the statements correctly, checking if the syntax is correct and evaluate them?
Lexer code, for reference:
<?php
require_once 'vendor/autoload.php';
use Doctrine\Common\Lexer\AbstractLexer;
class Lexer extends AbstractLexer
// All tokens that are not valid identifiers must be < 100
public const T_NONE = 1;
public const T_INTEGER = 2;
public const T_STRING = 3;
public const T_INPUT_PARAMETER = 4;
public const T_FLOAT = 5;
public const T_CLOSE_PARENTHESIS = 6;
public const T_OPEN_PARENTHESIS = 7;
public const T_COMMA = 8;
public const T_DIVIDE = 9;
public const T_MODULUS = 10;
public const T_DOT = 11;
public const T_EQUALS = 12;
public const T_GREATER_THAN = 13;
public const T_LESSER_THAN = 14;
public const T_LESSER_THAN_EQUAL = 15;
public const T_GREATER_THAN_EQUAL= 16;
public const T_MINUS = 17;
public const T_MULTIPLY = 18;
public const T_NEGATE = 19;
public const T_PLUS = 20;
public const T_OPEN_CURLY_BRACE = 21;
public const T_CLOSE_CURLY_BRACE = 22;
// All tokens that are identifiers or keywords that could be considered as identifiers should be >= 100
public const T_ALIASED_NAME = 100;
public const T_FULLY_QUALIFIED_NAME = 101;
public const T_IDENTIFIER = 102;
public const T_VARIABLE = 103;
public const T_FUNCTION = 104;
// All keyword tokens should be >= 200
public const T_ALL = 200;
public const T_ELSE = 215;
* Creates a new query scanner object.
* @param string $input A query string.
public function __construct($input)
$this->setInput($input);
* {@inheritdoc}
protected function getCatchablePatterns()
return [
'[a-z_][a-z0-9_]*\:[a-z_][a-z0-9_]*(?:\\\[a-z_][a-z0-9_]*)*', // aliased name
'[a-z_\\\][a-z0-9_]*(?:\\\[a-z_][a-z0-9_]*)*', // identifier or qualified name
'(?:[0-9]+(?:[\.][0-9]+)*)(?:e[+-]?[0-9]+)?', // numbers
"'(?:[^']|'')*'", // quoted strings
'\?[0-9]*|:[a-z_][a-z0-9_]*', // parameters
* {@inheritdoc}
protected function getNonCatchablePatterns()
return ['\s+', '(.)'];
* {@inheritdoc}
protected function getType(&$value)
$type = self::T_NONE;
switch (true) {
// Recognize numeric values
case (is_numeric($value)):
if (strpos($value, '.') !== false || stripos($value, 'e') !== false) {
return self::T_FLOAT;
return self::T_INTEGER;
// Recognize quoted strings
case ($value[0] === "'"):
$value = str_replace("''", "'", substr($value, 1, strlen($value) - 2));
return self::T_STRING;
// Recognize identifiers, aliased or qualified names
case (ctype_alpha($value[0]) || $value[0] === '_' || $value[0] === '\\'):
$name = strtoupper($value);
if (defined($name)) {
$type = constant($name);
if ($type > 100) {
return $type;
if (preg_match('/[a-z]+[ ]*(\((?:`[()]|[^()]|(?1))*\))/', $value[0], $match) !== FALSE){
return self::T_FUNCTION;
if (strpos($value, ':') !== false) {
return self::T_ALIASED_NAME;
if (strpos($value, '\\') !== false) {
return self::T_FULLY_QUALIFIED_NAME;
return self::T_IDENTIFIER;
// Recognize input parameters
case ($value[0] === '?' || $value[0] === ':'):
return self::T_INPUT_PARAMETER;
// Recognize symbols
case ($value === '.'):
return self::T_DOT;
case ($value === ','):
return self::T_COMMA;
case ($value === '('):
return self::T_OPEN_PARENTHESIS;
case ($value === ')'):
return self::T_CLOSE_PARENTHESIS;
case ($value === '='):
return self::T_EQUALS;
case ($value === '>'):
return self::T_GREATER_THAN;
case ($value === '<'):
return self::T_LESSER_THAN;
case ($value === '+'):
return self::T_PLUS;
case ($value === '-'):
return self::T_MINUS;
case ($value === '*'):
return self::T_MULTIPLY;
case ($value === '/'):
return self::T_DIVIDE;
case ($value === '%'):
return self::T_MODULUS;
case ($value === '!'):
return self::T_NEGATE;
case ($value === '{'):
return self::T_OPEN_CURLY_BRACE;
case ($value === '}'):
return self::T_CLOSE_CURLY_BRACE;
case ($value === '$'):
return self::T_VARIABLE;
// Default
default:
// Do nothing
return $type;
