C# supports reflection, so you can write a solution to take advantage using introspection. You would use XmlClass.Convert
to convert foo
(or any class).
In more general terms (and not specific to C#), if you are using a language that does not support reflection you should have foo
do the conversion. This is because foo
knows the details of what a foo
is; XmlClass
does not, nor should it. foo
should implement a ToXml
method to convert its data to an XML string. It won't do this in isolation, and can (should) call helper methods in XmlClass
to convert standard data types (like Int
and String
) to XML. Having a ToXml
method is also helpful because the XML conversion code is in the class, and any future changes to the class are less likely to miss updating the XML conversion code.
If you have XmlClass
to the conversion, then XmlClass
needs to know the details of foo
. This will cause a coupling between the two classes that does not need to exist, and increase the likelihood of bugs when changes are made to foo
and the XML conversion code is not updated. This would also violate the idea of Separation of Concerns.
