Your assumption that the sum of CCs is the aggregate CC is correct, but perhaps not very useful.
Cyclomatic complexity is based on the control flow graph. Usually, we only look at the control flow graph of a single function. We can also look at the control flow graph of an entire program, as if all functions had been inlined into the main()
. Looking at the entire program is not really useful as the CC will be unreasonably large, and conveys little useful information.
McCabe developed cyclomatic complexity in the context of unstructured programs: built around gotos or jumps rather than if/else, loops, and functions. Part of his motivation is to show that the correct use of structured and unstructured features can simplify a program. He also defines the term of a “structured program”. Essentially, he suggests: if a code snippet can be extracted into a function, we can count it's complexity as 1 – no matter what the internal complexity of this function is. As a consequence, any “structured program” that starts with a main()
function would have a whole-program cyclomatic complexity 1.
As an aside, I'd like to point out that the use of exceptions technically violates this structuredness property, since a function that can throw exceptions has one entry point but two exit points: one for normal return, and one for throwing. Another interesting question is how to count polymorphic calls, i.e. OOP method calls. A polymorphic call site doesn't jump to a particular function, but dynamically selects a function at run time. Pedantically, such a call might have infinite cyclomatic complexity.
So does it make sense to speak of the combined cyclomatic complexity of a bunch of functions? Not really, at least in practice. These functions are independent. Even when they share control flow graphs because they call each other, we can treat them as structured programs and ignore the called control flow graph. What matters for maintainability is every function by itself.
However, it is fundamentally correct to simply add the cyclomatic complexities of all functions. Ignoring calls, each function has an independent entry point and exit point: a combined control flow graph exists but is disconnected. The sum of the individual cyclomatic complexities then accurately describes the number of independent paths through the code. Arguably, it would be correct to only include public functions that can be called from the outside, but not private functions.
