In JavaScript (ES6), I can have optional function parameter with default value. So to add a new behavior to the existing code base, I could either introduce new method(s) or extend the existing method with an optional parameter.
Consider the following example:
Existing method:
doSomething(param) {
// code to do something trivial
Desired new behavior: the ability to do something special after doing something trivial
Option 1: extend the existing method
doSomething(param, isSpecial = false) {
if (isSpecial) {
// code to do some more thing special
Usage:
doSomething(param); // do something trivial
doSomething(param, true); // do something special
Option 2: add a new method
doSomethingSpecial(param) {
doSomething(param); // just call the existing method to do something trivial
Usage:
doSomethingSpecial(param); // do something special
Option 3: extend the existing method and add two new methods
doSomething(param, isSpecial) {
if (isSpecial) {
doSomethingTrivial(param) {
doSomething(param, false);
Usage:
doSomethingTrivial(param); // do something trivial
Currently I'm mostly using the first option, because it's less code to write. But thinking of the open closed principle, it doesn't sound right for me.
So which option should I choose? (in general, not special in JavaScript)
