51
As the sole developer in a startup, I had the luxury of being able to make a lot of decisions in the architecture and frameworks of our application.
Fast forward 4 years and an acquisition later, I have a team of 5 and a lot of times it feels like the wild west. People making whatever design decision pleases them: integer and enums for DB types in one place and string another, this framework for a problem and then a different framework for the same problem elsewhere, etc.
How do I go about enforcing consistency? It feels important to me but my team members seem to subscribe to the "if it works, it works" methodology.
I guess a big part of my question is: is it unrealistic of me to expect standards like this? I struggle with the idea of coming across as a dictator that stifles creativity but doing whatever they want seems to not be scalable.
Deekor
  • 507
    Can you tell us as much as you can about your existing SDLC process? Are you Waterfall, Agile, etc? Do you use TFS or task management? Do you perform code reviews or use FxCop or other forms of code validation? Do you produce design documentation? Do you have a designated architect role? – John Wu May 21 '19 at 17:40
    Possible duplicate of [What must be done to allow a development team to minimize difficulties as new team members are added?](https://softwareengineering.stackexchange.com/questions/20721/what-must-be-done-to-allow-a-development-team-to-minimize-difficulties-as-new-te) – gnat May 21 '19 at 17:41
    @gnat: Not a great duplicate, if the answers are any indication. – Robert Harvey May 21 '19 at 17:47
    To be fair, these standards should have been set very early on and based on some widely accepted "best practices" document so no one can complain about favoritism or elitism. If you are getting hard pushback from an individual you will have to consider whether one cowboy is worth the healthy environment for the rest of the team and replace that one, they'll be leaving on their before long anyways, they always do. Then I think that all advice given below to use strict code review before check-ins and to add an architecture component will work wonders. – Patrick Hughes May 21 '19 at 18:53
    That's the holy grail of software engineering (aside from the other holy grail, which is accurate requirement elicitation). – pmf May 22 '19 at 10:08
  • Do you have a plan to deal with existing code when new features are added to the language? For example, say you are working with Java 4 and you have string constants, and then Java 5 comes out and now you can have enums...will you stick with string constants since that's the existing design, will you spend the time to go through and update all of your strings into enums where applicable, or will you grandfather in old code and say that all new code going forward needs to use enums, even if you then have multiple standards? (Maybe you do not care about enums, but iterators, forEach, etc.) – user3067860 May 22 '19 at 17:12
What makes you so special?
My CPU says it works and I want to go home. Why are you bothering me?
You can deal with this attitude by forcing everyone to issue pull requests. But now the deadlines are looming. Bad code presses on the gates of your pristine castle and you finally give in to the pressure. Or you win only to find everyone leaves and no one uses your pristine castle.
There are plenty of tools that help with this issue. Source control, code reviews, coding standards, etc. but the heart and soul of the problem is your subjective opinions about what is best have to be seen as relevant. For that you have to earn and maintain their respect. Do that and this is much easier. Fail to do that and no tool or practice will save you.
The best way to do that is communicate early. Don't tell me "we don't use strings for our DB types in this shop" 6 months after I settled on the idea. Telling me it's been buried in the documentation for 2 years is no justification for letting me do that.
For whatever reason you have things you care about. If you care about them and have a point get those things communicated clearly before, during, and immediately after the coding of every module.
Code stalking is a wonderful practice. Invest in whatever tools and practices you need so you can review code within minutes of it being written. Pair program and the tool is simply a guest chair.
Why? Every second that passes after I write code exponentially increases the cost to change it. That's because my memory of the code has a half life. I start forgetting it the moment my bladder demands a break.
Reduce the things you care about to their underlying principles. Rather than hit me with a list of 101 rules to follow, give me the 10 principles that they violate so I can figure out what rule 102 should be on my own.
Empower me to impose my own vision by helping me see yours and we'll get along great.
Then don't dictate! Make this a positive experience. This isn't some new age hippy nonsense. It's basic psychology. You are trying to modify human behavior. Random and positive is the most reinforcing (just ask Las Vegas). If you go negative you have to be consistent with your reinforcement. That's an unobtainable pain. Be positive as you spread the wisdom and you can be casual about it.
I know where you're coming from because I've been there. You had control and now it's gone. You want it back. Well get over it. Now you have a team. They don't need to be controlled. What they need is leadership. What you need isn't control. It's influence. It works better and is a lot less work. Master that and relax. This should be fun.
Do it right and you can go on vacation and this will still work. How? By not just being a leader but by getting the others to be leaders as well. Once you've instilled your vision in the team they can work while you're gone simply by imitating what you've been doing. Mentor the newbies and encourage them to step up and influence others as well.
I know it's hard. We didn't go into this profession because we're good at dealing with people. We communicate best with code. That's fine. Just do it quick and often. Show me why yours is better. Listen if I say it's not. Do this while I'm still thinking about it. I love to code. There are few people on the planet that I can talk to about it. Be one of them.
candied_orange
  • 102,279
  • 197
  • 315
    It's pretty evident what you mean by "code stalking"... But google gives me nothing but crime law from around the world. – Jeremy May 22 '19 at 07:24
    add "coding standards" to the list – BЈовић May 22 '19 at 08:16
    Since I seem to be introducing the term I'll give the etymology of 'code stalking'. I had checked in some code that used an abstract factory to get it's timestamps. A peer developer was trying to merge (check code in) and was scrolling through the code changes since her check out. She noticed my factory and thought it was curious. She wasn't sure why I was doing this. So she walked over and asked me. When I looked confused she said, "Oh I was just code stalking you". Facebook is changing our vocabulary. – candied_orange May 22 '19 at 18:01
    True! "*Empower me to impose my own vision by helping me see yours and we'll get along great.*" i love when poetry, code and philosophy mix! – Pedro Lobito May 23 '19 at 02:09
  • @candied_orange: I'm a bit baffled by the whole "code stalking" thing. Were you just punking her? In the context of your answer, it seems like she would be code stalking you. – Robert Harvey May 24 '19 at 14:41
  • @RobertHarvey I was not punking anyone. She was code stalking me by reviewing my check in at her workstation. She said so. It was the first time I'd heard the term but I love the practice. It gave me feed back much sooner than a formal conference room code review would have. – candied_orange May 24 '19 at 14:50
  • Oh, I see now. So basically she cared enough to ask, but not enough to wait for a real explanation. – Robert Harvey May 24 '19 at 22:30
  • @RobertHarvey huh? A formal code review doesn't make the explanation "real". It just makes it take longer to happen. She challenged me early while it was still easy to change my code. That's a good thing. – candied_orange May 25 '19 at 04:16
  • I clearly need to read more Facebook. – Robert Harvey May 25 '19 at 04:22
23
First, get people to maintain things they didn't write. It's very easy for a developer to get into habits of using frameworks and techniques they are used to. It's jarring to have to switch between frameworks and methodologies. If someone is forced to move outside of their own corner of the code and experience that often, it will prompt some complaining and hopefully some productive discussion that can lead to people wanting to standardize on something.
Next, pull requests and code reviews. Never allow code to be merged to your main branches without a code review first. Anyone can do it. Again, when someone sees something that's different than what they would have done, it can prompt discussion and teamwork to come to a better solution. It also makes everyone a caretaker of the code base, which (hopefully) gets people to care about it and the state of the code that goes into it.
Finally, have design discussions. They can be formal or informal, but have them. Let those that want to participate do so. Discuss what frameworks you want to use, the pros and cons of enums vs ints, etc. Then come to a decision and document it somewhere (like a standards document). Then you have something to point to when problems arise. Also, don't be afraid to revisit a standards decision. Technology changes (quickly) and so can your needs as a team and as a company.
Help people to see what you see and feel like they have a stake in the quality of the code. Then gently prod discussions towards finding a standard when differences of opinion come up.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Becuzz
  • 4,815
  • The nice thing about this method is that the manager isn't just imposing his preferences, he's giving the team the chance to decide, and giving them to power to enforce it. – Robin Bennett May 22 '19 at 10:44
Perform code reviews every time someone wants to merge code into the main branch/trunk and hold people to those standards when reviewing the code.
And I don't mean that only you should perform the code reviews. Everyone should review everyone else's code. This disseminates knowledge about the system across the team but also creates a situation where Carol reviews Bob's code and says, "I see you used an integer there. I always use an enum." They discover the discrepancies that you've seen and, assuming they care, they will realize that everyone's got to get on the same page.
The accepted, agreed-upon standards will emerge, at which point you document them and make sure people follow them. This would include things like "enums in the DB for ...", etc. You can also include documenting which frameworks to use, etc.
Matthew
  • 1,085
  • I guess a big part of my question is is it unrealistic of me to expect standards like this. I struggle with the idea of coming across as a dictator that stifles creativity but doing whatever they want seems not scalable – Deekor May 21 '19 at 17:48
    @Matthew, while I generally agree with you, I would do this in a reverse order. Design reviews first, and guidelines emerge from/during the design reviews. If you put the burden of writing everything down upfront on the architect/lead, that's *shifting the burden to the intervenor*. – Nick Alexeev May 21 '19 at 17:50
  • @Deekor: You have to pick your battles. Figure out what you have to put your foot down on, and document that. You don't have to dictate *everything.* – Robert Harvey May 21 '19 at 17:51
    @Deekor, you can enforce standards and common coding practices without "stifling creativity." That's a spurious argument anyway. Common coding standards lead to easy-to-maintain software. Free-for-all coding leads to nightmares. – Matthew May 21 '19 at 19:04
    @Nick Alexeev, I agree; will edit. – Matthew May 21 '19 at 19:04
  • @Deekor Ideally, you would have started this with the first person that your brought on to your team. The larger the team the harder it will be to change the culture. 5 people is still pretty small, though. Get the backing of management and have them help set the stage for this 'transition'. – JimmyJames May 21 '19 at 19:21
  • @JimmyJames ya inexperience on my part. I am the head of engineering now and trying to set the stage for high growth – Deekor May 21 '19 at 19:24
  • @Deekor As the answer suggests, the standards will emerge but I think documenting them is optional. It really depends on the way your team operates. As for platforms/frameworks, there are tools that can help you manage what's used via build and deployment automation. These are worth using just from a security perspective but can also help you avoid the "we're using that?" surprise. – JimmyJames May 21 '19 at 19:32
  • @JimmyJames, while documenting is optional it is extremely helpful when you bring a new person onto the team. It saves time to give them something to read (doesn't have to be much, really) that lays out the org's standards and conventions instead of having them "learn" them during code reviews. – Matthew May 22 '19 at 11:43
  • @Matthew I don't disagree but they can also be a tremendous waste of time on dynamic teams. If can't adapt to changing needs without updating the documentation, it becomes a major drag on productivity. Often the documents just end up being out of date and being of little use. A middle path is to use a wiki and have the new team members update it as they work through it. – JimmyJames May 22 '19 at 14:20
Where possible, you can write tools/scripts to automatically analyse your projects and determine which standards, tools and approaches the project is using. You can do this by running a custom tool as part of a CI build.
Have the output from the tools written to a 'scorecard' document, e.g. a google sheet with a row per unit (e.g. per 'application' or project or api or whatever), with columns for the various metrics/standards followed. This will give people visibility about what standards there are, how well adopted they are etc. and provide some order to the chaos.
You can have manually updated columns too, but good luck keeping them up to date :D
mcintyre321
  • 335
In addition to the answers provided I say you should educate your team of what you expect of them as software development professionals, starting from the moment they're interviewing to join the company.
1 - Create and follow codebase conventions
This is one of the most basic yet beneficial measures you can adopt to improve code quality. As a result of following conventions source code will be uniform throughout the codebase, reducing the cognitive effort for searching and reading code files.
2 - Implement clear software architectures
The codebase of a software project that doesn’t follow a clear architectural style, whatever it may be, deteriorates gradually as new, unstructured code is added to it, becoming harder to modify. Hence the importance of putting in the hours for the design and conservation of an adequate software architecture.
3 - Fewer is better: Languages, Frameworks and Tools
With each additional language, framework and tool you introduce into your system comes an additional development and operational cost. You should always evaluate the long-term costs of a technological decision before making it to solve a short-term problem. Avoid redundant technologies, and take most out of your current stack.
4 - Involve your team in system design decisions
The most effective way to build a shared knowledge environment is to involve the team in all system design decisions. The benefits are plenty:
  • Individuals feel valued and part of the team
  • Important decisions are challenged by the entire team before being made
  • System design strengths and weaknesses are more clearly understood by everyone
  • Creates a sense of collective accountability and trust
5 - The All-in rule
I hold the view that efforts to refactor a system design should be conducted to completion (all-in), rather than being partially concluded. There’s a great risk of eroding your system design if developers feel free to apply different coding styles and architectural patterns locally whenever they see fit.
By this point, if you've successfully implemented the previous suggestions, your team will mostly likely evaluate this rogue developer behavior as unprofessional and irresponsible.
I've recently written a blog post about this subject, you can find detailed information on these topics there: https://thomasvilhena.com/2019/11/system-design-coherence
