29
I recently came across an MSDN article about branching and merging and SCM: Branching and Merging Primer - Chris Birmele.
In the article they say 'big bang merge' is a merging antipattern:
Big Bang Merge — deferring branch merging to the end of the development effort and attempting to merge all branches simultaneously.
I realized that this is very similar to what my company is doing with all of the development branches that are produced.
I work at a very small company with one person acting as the final review + trunk merge authority. We have 5 developers (including me), each of us will be assigned a separate task/bug/project and we will each branch off the current trunk (subversion) and then perform the development work in our branch, test the results, write documentation if necessary, perform a peer review and feedback loop with the other developers, and then submit the branch for review + merge on our project management software.
My boss, the sole authority on the trunk repository, will actually defer all of the reviews of branches until a single point in time where he will perform reviews on as much as he can, some branches will be thrown back for enhancements/fixes, some branches will merge right into trunk, some branches will be thrown back because of conflicts, etc.
It's not uncommon for us to have 10-20 active branches sitting in the final review queue to be merged into trunk.
We also frequently have to resolve conflicts in the final review and merge stage because two branches were created off the same trunk but modified the same piece of code. Usually we avoid this by just rebranching off trunk and re-applying our changes and resolving the conflicts then submitting the new branch for review (poor mans rebase).
Some direct questions I have are:
  • Are we exhibiting the very anti-pattern that was described as the 'big bang merge'?
  • Are some of the problems we're seeing a result of this merge process?
  • How can we improve this merge process without increasing the bottleneck on my boss?
Edit: I doubt my boss will loosen his grip on the trunk repository, or allow other devs to merge to trunk. Not sure what his reasons for that are but I don't really plan on bringing the topic up because it's been brought up before and shot down rather quickly. I think they just don't trust us, which doesn't make sense because everything is tracked anyway.
Any other insight into this situation would be appreciated.
muru
  • 142
user6567423
  • 433
    Why is merging deferred? Usually, there is a reason for not doing it immediately. is the single guy overworked and the backlog just gets so big? is there some other reason why merging isn't done in a timely manner? – Polygnome May 17 '19 at 04:42
    I was in a similar position as you, several times. I can tell from personal experience that many companies do version control, especially branching, horribly wrong. – MechMK1 May 17 '19 at 11:14
    What happens when the boss goes on holiday? – Liath May 17 '19 at 13:28
  • How would you define the linux kernel branching/merge strategy? – Braiam May 17 '19 at 15:04
  • Do the changes that are thrown back because of conflicts but not other defects need to go through the approval process again once the conflicts are resolved or are they considered "provisionally approved"? – Greg Nisbet May 17 '19 at 16:19
  • @Polygnome - I believe it is because he has too much on his plate and must juggle several other jobs. – user6567423 May 17 '19 at 18:19
  • @Liath - We wait till he gets back hahaha, usually we are given larger projects that will carry through till he is back. – user6567423 May 17 '19 at 18:21
  • @Gregory Nisbet - Depending on how much work was required when they were thrown back, small changes not really, big design changes yes, but we try to avoid those big design changes. – user6567423 May 17 '19 at 18:21
  • @user6567423 Have you talked about your boss about hiring more people to get merges done faster? You can't solve missing manpower with software engineering. – Polygnome May 17 '19 at 19:05
  • @Polygnome I think the company is at it's limits for now :) But I think I may be entering the role of second gatekeeper sometime in the future. I think the limits are well known by the management, I was just looking for potential solutions to help them. – user6567423 May 17 '19 at 20:34
  • An equally serious problem emerges from between the lines of your question... "Big bang merge" implies "big bang releases", a wonderful way of making the product difficult to test, every (infrequent) release proving to be a "hold-your-breath" moment, where management start to get shifty if you book time off work at or around the big release day. Continuous integration done right reduces this risk to the point where deployments on friday afternoon are a happy thing. I'd also steer towards a more modern SCM (such as git). Merges in Subversion are so much more likely to cause serious pain. – spender May 18 '19 at 12:53
7 Answers7
61
Some suggestions:
  • There is nothing wrong in having a lot of feature or bugfix branches as long as the changes done in each branch are small enough you can still handle the resulting merge conflicts in an effective manner. That should be your criterion if your way of working is ok, not some MSDN article.
  • Whenever a branch is merged into trunk, the trunk should be merged into all open development branches ASAP. This would allow all people in the team to resolve merge conflicts in parallel in their own branch and so take some burden from the gatekeeper of the trunk.
  • This would work way better if the gatekeeper would not wait until 10 branches are "ready for merging into trunk" - resolving merge conflicts from the last trunk integrations always needs some time for the team, so it is probably better to work in interwoven time intervals - one integration by the gatekeeper, one re-merge by the team, next integration by the gatekeeper, next re-merge by the team, and so on.
  • To keep branches small, it might help to split larger features into several smaller tasks and develop each of those tasks in a branch of its own. If the feature is not production ready until all subtasks are implemented, hide it from production behind a feature toggle until all subtasks are completed.
  • Sooner or later you will encounter refactoring tasks which affect many files in the code base - these have a high risk of causing a lot merge conflicts with many branches. Those can be handled best by communicating them clearly in the team, and make sure to handle them exactly as I wrote above: by integrating them first into all dev branches before reintegration, and by splitting them up into smaller sub-refactorings.
  • For your current team size, having a single gatekeeper may still work. But if your team will grow in size, there is no way around having a second gatekeeper (or more). Note I am not suggesting to allow everyone to merge into trunk, but that does not mean only your boss is capable of doing this. There are probably one or two senior devs who could be candidates for doing the gatekeeper's job, too. And even for your current team's size, a second gatekeeper could make it easier for your team to integrate to the trunk more often and earlier, or when your boss is not available.
Doc Brown
  • 199,015
  • 367
  • 565
    I think you have the best comment here, acknowledging that we cannot simply open trunk to everybody, and that our stack of branches isn't exactly always a problem (only when they conflict). I think you did a good job pointing out how we can reduce conflicts and ensure the merge cycle is smooth, I also think you are completely correct when you say we may need another gatekeeper. Thanks a lot for this insight! – user6567423 May 16 '19 at 23:19
  • @user6567423 Another thing you might want to consider is making branches for each development version (e.g. 5.2.3 or whatever), that each developer can branch off of for feature work and then merge onto, and which can then be merged back onto the main release branch by the boss when development is complete. – nick012000 May 17 '19 at 04:57
  • @nick012000: would that suggestion not make it harder for the gatekeeper to accept or reject individidual feature branches for / against integration into trunk? I mean, if several features are mixed up into one development branch, reintegrating those changes *partly* into trunk would become really hard. Or am I missing something? – Doc Brown May 17 '19 at 06:35
    "_resolve merge conflicts in parallel in their own branch and so take some burden from the gatekeeper of the trunk._" - I feel like this part is unjustly reduced to a side note. "It's better for the company BUT ALSO _easier for you_" seems like the main selling point when suggesting this to the boss. That goes more into the direction office politics, which SE isn't about - but in this situation, without buy-in from the boss, everything else in this technically excellent answer just won't happen. – R. Schmitz May 17 '19 at 09:32
  • @DocBrown Yeah, it would, but it would also mean that you’d have a lot less conflicts between the dev branches and it’d still give you the degree of safety given by not directly merging onto the main branch - and he can simply decline to accept the work as Done and perform the merge until he’s happy with the state of the code as a whole. – nick012000 May 17 '19 at 09:41
  • @nick012000: I guess with 10-20 active branches in the review queue it is quite unlikely there will be ever a time where the gatekeeper will be happy with all of them. Since merging them all into one dev branch makes reintegration into trunk an "all-or-nothing" decision, the release process will become blocked. Does not seem to be a viable option for this team. – Doc Brown May 17 '19 at 14:18
18
Sounds like it.
Definitely
At my company, every dev has the ability to merge. We assign a Merge Request to another dev, go through the review/feedback/update cycle until both parties are satisfied. Then the reviewer merges the code.
10-20 branches waiting to get merged is a sign that your process is flawed. If we had that many, all dev work would stop until it was cleared up.
Matthew
  • 1,085
    Not the answer I was looking for because I doubt my boss is going to loosen his grip on the trunk repository. But an incredibly helpful answer none-the-less, thanks for the insight! – user6567423 May 16 '19 at 19:34
    @user6567423: If your boss becomes the bottleneck, which he now is according to your description, he's going to have to either change his approach or accept that he's the cause for delays (which his employees then cannot be blamed for). Refusing to change your approach, ignoring the problems you're creating, and pushing the blame onto others are no way of running a business. – Flater May 17 '19 at 13:14
    He does agree that he is the bottleneck and he most certainly does not blame others for it. But yes, I was looking for any tips that might not be readily obvious that could possibly reduce our bottleneck. Thanks for the insight – user6567423 May 17 '19 at 18:23
    @user6567423 I'm curious if he has ever explained why he's the only one who can merge to trunk. – Matthew May 18 '19 at 02:05
13
This is essentially how a lot of open source projects work, including most notably the Linux kernel, which has a lot more branches in flight than you do at any given time. The typical way to avoid big bang merges in these projects is to create another branch (or multiple branches) for continuous integration. This is the branch you use to make sure your changes work together with your colleagues, and it gets periodically rebased onto the trunk when the gatekeeper gets around to doing reviews.
Optionally, you can use this branch to combine several of your own pull requests into one big cohesive request for your boss to review. Linus Torvalds typically gets pull requests that have been integrated two or more levels deep, and can have a size on the order of, for example, a complete new filesystem driver.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
  • Thanks I think the tips on combining branches and preventing conflicts will probably be our best course of action. – user6567423 May 16 '19 at 20:29
I agree with both Doc Brown but I also see another antipattern:
In my humble there are some management antipatterns:
  1. He/she is the single choke point constraining the velocity of the team. Your bus factor is 1. The theory of constraints say that you should put your effort in improving the slowest part of chain.
  2. Your manager is making your feedback cycle slower and reducing the agility of your team. Can you release every week?
  3. Merges complexity grow exponentially with the amount of code. It is better to make 10 merges with 100 lines than 1 of 1000 lines. That is just one of the reasons why you should do it ASAP
  4. If you detect a failure in the trunk you will do it latter in time. Which of the several branches was the problematic one
  5. Decissions should be made by those who have more knoledge about them. Who knows more in this case? I bet that the developers that made the code.
  6. You can't fix a bug in production if your manager is on holydays.
  7. You are redoing work and throwing back branches. This is a waste of time. The time it is waiting to reach production is also waste.
Recomendations:
  • Your manager needs to delegate responsability to the team. You need to show that the team is mature, professional. Make clear that they can trust in the team
  • Implement some review method. May be you need the aproval of two other team members.
  • May be using SVN is making it harder. Give Git a try and see if it helps you. Even more. If you use GitHub you can use the Pull Request mechanism so that a merge requires certain votes.
  • Read and share information about agile practices, continous integration and DevOps.
Borjab
  • 1,339
    I've worked professionally with both SVN and git, and I'd say that SVN is definitely part of the problem: It forces a single-merge-back-commit policy on branches which is not present in git. In git, all merges are equal, in SVN, some are more equal than others. Also, the lack of local commits makes it much harder to experiment with SVN than with git, and the lack of a staging zone only adds to the inflexibility of SVN. There's a reason why Torvalds did not just use SVN instead of developing git... – cmaster - reinstate monica May 17 '19 at 12:49
  • Git is so much better than svn in my opinion for the reasons @cmaster laid out and more – reggaeguitar May 17 '19 at 15:43
  • I agree git would probably solve some of our merging problems, and dear god would I love to have rebase available. But I don't think we're going to make the switch anytime soon :( – user6567423 May 17 '19 at 18:25
    @user6567423, I did a consultation last year where I helped a small team transition from svn to Git and change their workflow over, including training them on Git and setting them up with GitLab community edition (which is open source) for code reviews and collaboration. They were very enthusiastic about it; it was a night and day difference. (Also it took only three days.) – Wildcard May 17 '19 at 20:03
When you do feature work in separate branches, you can't easily do any integration testing until one of the branches is merged to trunk and pulled into the other feature branches. In my experience, this is the main problem with the Big Bang Merge anti-pattern. Ideally, you would do feature work, test it in the feature branch, merge it into trunk, and at that point you are done with the feature. If it hasn't been merged, you have to revisit it each time something else is merged into trunk before it. The pain of this anti-pattern is that you have a lot of integration-type bugs showing up at the end of the development cycle.
bmm6o
  • 129
So you have 20 branches. Branch 1 is just merged. Then the developer of branch 2 has to merge branch 1 into their branch to be able to merge into main without conflict, then merges. Then the developer of branch 3 has to merge branch 1 and branch 2 into their branch to be able to merge into main without conflict, then merges.
Exercise for the reader: Write a program that prints my complete post :-)
This is madness. You will be spending an incredible amount of time merging.
gnasher729
  • 42,090
  • 59
  • 119
  • Well not necessarily, unless the branches are in conflict then he can just merge them all into trunk seamlessly. We will usually try to prevent any conflicts by doing a test merge before we submit the branch for review but the conflicts come up inevitably as the number of branches in the queue increases. I do agree that it sounds like madness though. – user6567423 May 16 '19 at 19:38
    Normal SVN merging behavior, as far as I can tell... – cmaster - reinstate monica May 17 '19 at 12:51
Given the way you are working and that your boss is a responsible control freak, branching itself seems to be the problem. Rather than creating a branch for every feature, have each developer commit his feature in parts, directly into the trunk. This puts the burden of integration on the developer in multiple smaller steps (win-win). Gate keeper can keep up with tracking smaller changes over a longer period earlier in the development cycle and still be the master reviewer.
Branching itself is something you do not want to do unless you have a very good reason to do it or you have no other option. You are small enough to keep things in sync more tightly, which will be easier and safer.
Martin Maat
  • 18,218
  • 30
  • 57
    And how are you going to handle the release if just 1 of those features has a bug or isn't finished in time? "Branching itself is something you do not want to do unless you have a very good reason to do" -- Once you have 5 people working on multiple features each, you have to use branching unless you have a very very good reason not to. – Ivo van der Veeken May 17 '19 at 12:53
  • It was about two thing: boss wants to remain the one and only gate keeper and things are not supposed to diverge too much. Yes, there will be a moment at which something was pushed that is yet to be scrutinized by boss. He should be able to do that quickly though and in the unlikely event he needs to deliver immediately he can revert the latest commits. This will keep things in sync and if you fail at anything you will certainly fail fast. Looks like a good compromise to me for the situation at hand. – Martin Maat May 17 '19 at 13:23
    I would consider this as a last resort – reggaeguitar May 17 '19 at 15:45
