40
Recently I learned about GraphQL which claims to be superior to RESTful. However, I started wondering why don't we simply put SQL statements into an HTTP GET request.
For example, in GraphQL I would write
  Movie(id: "cixos5gtq0ogi0126tvekxo27") {
    id
    title
    actors {
      name
Which isn't much simpler than its SQL counterpart
SELECT id, title FROM movies
  WHERE id = cixos5gtq0ogi0126tvekxo27;
SELECT actors.name FROM actors, actors_movies
  WHERE actors.id == movies.actor_id
  AND movie.id == cixos5gtq0ogi0126tvekxo27;
Maybe we can URL-encode the query and send to the server
GET endpoint?q=SELECT%20id%2C%20title%20FROM%20movies%20WHERE%20id%20%3D%20cixos5gtq0ogi0126tvekxo27%3B%0ASELECT%20actors.name%20FROM%20actors%2C%20actors_movies%20WHERE%20actors.id%20%3D%3D%20movies.actor_id%20AND%20movie.id%20%3D%3D%20cixos5gtq0ogi0126tvekxo27%3B HTTP/1.1
Yes, the query URL can be too long, but you can put it into the body of a POST request if you don't care about REST compliance. (By the way, I think the HTTP RFC need be revised for REST to make sense: capping the length of query strings mixes implementation with specification at the very beginning)
Directly issuing SQL from the client also has the advantage of
  1. No server-side code/library is required to parse GraphQL, reducing development time.
  2. No server-side overhead is needed to parse GraphQL, reducing runtime.
  3. SQL statements are much more flexible than GraphQL because (in most cases) the latter will reduce to SQL anyway.
  4. Everyone knows SQL.
So, what the advantages GraphQL have over SQL?
Kjartan
  • 157
nalzok
  • 549
  • 51
    Little Bobby Tables. – Philip Kendall Apr 06 '19 at 07:05
    @PhilipKendall Do you mean SQL injection? This can be solved conveniently by setting the role of the corresponding SQL user to read-only. Also, I can always require some kind of API secret key, or employ other authentication techniques. – nalzok Apr 06 '19 at 07:09
    1. I can still DoS you with arbitrarily complicated SQL queries. 2. There's no chance a malicious actor would ever obtain a valid key... – Philip Kendall Apr 06 '19 at 07:16
    @PhilipKendall You are right, but using GraphQL (or REST or whatever) doesn't solve these problems either, right? – nalzok Apr 06 '19 at 07:18
    What you suggest already [exists](https://www.odata.org/getting-started/understand-odata-in-6-steps/) and It doesn't expose your DB to the world as you are suggesting too. It also abstract the QL from the DB so that you can use SQL, noSQL or whatever your DB is. – Laiv Apr 06 '19 at 07:19
  • @Laiv Thanks for letting me know OData, and it seems that this proposal isn't that crazy! Just want to point out that AFAIK, SQL is still the mainstream data store in 2019, and my architecture has a totally flat learning curve, which might be a big advantage. I mean, imagine a one-liner API document: "Just URL-encode your SQL statement and POST to us"! – nalzok Apr 06 '19 at 07:28
  • Injecting SQL would raise so many alarms in any company. DBs are sensible assets for the company – Laiv Apr 06 '19 at 07:32
  • @Laiv SQL injection *is* a big problem, but it happens regardless of the architecture. Nobody can stop an attacker from embedding `; DROP TABLE users; --` in a REST request. IMO the only solution is always validating your data, but architecture doesn't play an important role here. – nalzok Apr 06 '19 at 07:38
    @nalzok: SQL is Turing-complete, which means it is impossible to validate statically. – Jörg W Mittag Apr 06 '19 at 07:45
    There're more risks than injection tho. And architectural boundaries like having more than one DB or having no DB at all. You are assuming that behind an HTTP there's a SQL DB. SQL, graphQL, odata, etc are mere query languages no the DB itself. – Laiv Apr 06 '19 at 07:45
  • What about caching? You learn that your Graphql node is slow so you decide to cache it to redis. How do you solve this with your SQL approach? The reason why your proposal is not mainstream is because in most cases it is a complete non sense and a dumb thing to do. – Andy Apr 06 '19 at 12:01
  • @Andy Um I don't get it. Why can't I just compare the URL (or SQL query) against keys in Redis before performing the actual query on the RDBMS? By the way, I came up with this funny idea because I feel many people are overdoing things. [You are not Google.](https://blog.bradfieldcs.com/you-are-not-google-84912cf44afb) – nalzok Apr 06 '19 at 12:11
    This is very simple to understand why it's a terrible idea. Implement it yourself. At some point, you will realise that your are investing the time mostly in 1 thing: security. Not too later you will feel somewhat upset because you are implementing a caped TOAD. Then you will realise how hard is mapping rows all over the system and you will try to reinvent the ORM wheel on both sides: client and server. By the time you give up, your PM will ask you for report: *how is the users' service going*? *Is it done?*"... – Laiv Apr 06 '19 at 12:24
  • "*No server-side overhead is needed to parse GraphQL*" - but with SQL, significant client-side overhead is needed to parse SQL results into the structure that you actually need – Bergi Apr 06 '19 at 21:44
  • @Laiv Everyone here is worrying about security, and that certainly makes sense, but how can GraphQL and REST protect my data? If an attacker has unrestricted access to a (GraphGL/REST) API, then user privacy is doomed anyway; if they doesn’t have such unlimited access, what makes using SQL dangerous? – nalzok Apr 07 '19 at 03:20
  • @Bergi I believe it won’t be hard make a structured response from the server side. Major languages all have binding to some major DBMS. – nalzok Apr 07 '19 at 04:30
    This site is not a forum for arguing with answers. – whatsisname Apr 07 '19 at 05:43
  • @whatsisname Um... Actually l’m not intended to start a holy war, just wanted to clarify my doubts... It would be great if you could rephrase my edit! You know, I’m expressing my thoughts and exchanging them with others, like everyone else on this site. – nalzok Apr 07 '19 at 05:49
  • @nalzok But structured how? The advantage of GraphQL is that it already describes the structure and even allows nesting. – Bergi Apr 07 '19 at 11:35
    @Bergi This is a good point! To paraphrase, the structured nature of GraphQL makes creating a JSON response easier, and JSON is a really handy format. – nalzok Apr 07 '19 at 11:49
  • @PhilipKendall [Wow, it's amazing how quickly I knew what those three words meant... xD](https://media.tenor.com/images/14c7622858611258e4af76cf4f435fc4/tenor.gif) – varun Apr 07 '19 at 17:21
  • For the SO chaps who didn't understand @PhilipKendall 's comment: https://xkcd.com/327/ – varun Apr 07 '19 at 17:23
    see also: `SQL is a better API language than GraphQL` https://news.ycombinator.com/item?id=22892946 and https://docs.datasette.io/en/stable/ – jimmont Sep 10 '20 at 08:18
  • By all means use SQL, but safely, so only after exposing the necessary views, restricting access, and metering queries. Then there are graph databases which don't use SQL, and so you'll have to expose whatever they offer. GQL over SQL is 99% just busywork. – Asclepius Aug 07 '22 at 21:57
  • Upvoting this question merely from amusement. – mukunda Jun 18 '23 at 14:15
Basically, abstraction.
SQL requires your clients to know your exact database structure, which is not good. On top of that, analysing the SQL in order to perform special operations based on the value sent as the input is a really difficult thing to do. There are entire softwares which are pretty much responsible only for that. Do you know what those are? If you have guessed the databases, you are right.
Thanks to not exposing the SQL directly, you are not limiting the consumer of the API to the internal representation of your database. You easily expose only what you want to expose.
And since clients of the API depend only on the abstraction, you are free to have as many layers as possible between the API input and the actual database (security, caching, loading data from multiple databases on a single request,...).
For public services, exposing a database directly is pretty much never the right approach. If you however have a few internal systems, sure, your approach might make sense but even then it might just be easier to connect to application A's database directly from Application B by giving the database credentials to the Application B, rather than trying to come up with a custom HTTP interface for the database SQL language.
Because it's not easy. Even if someone uses a very simple query, such as:
SELECT st.id, jt.name
FROM some_table st
INNER JOIN join_table jt ON jt.some_table_id = st.id
WHERE st.name = 'hello
world' AND st.type = 'STANDARD'
how do you make sure the result is properly cached? This query includes newlines, but someone could just as well write the query in the following way:
SELECT st.id, jt.name FROM some_table st INNER JOIN join_table jt ON jt.some_table_id = st.id WHERE st.name = 'hello
and it's still supposed to be cached in the same way as the one above. I have specifically included a where in which a string search contains a new line, so simply finding line endings and replacing them with a space is not going to work here, parsing the request correctly would be much more complicated.
And even if you do fix that, another query could switch the order of conditions and the query would look like this:
FROM some_table st
WHERE st.type = 'STANDARD' AND st.name = 'hello
world'
and another request could contain a redundant WHERE argument, like this:
FROM some_table st
world' AND st.stype = 'STANDARD'
All of those queries are still supposed to return the same result, should be cached in the same way. But handling all of the possible options is pretty much impossible. That's why you cannot simply compare the URL against keys in Redis.
Andy
  • 10,238
  • 50
  • This is a nice answer, but please see the update. – nalzok Apr 07 '19 at 04:16
    _how do you make sure the result is properly cached?_ parse it into an AST and hash that. Not that you would want to do that which the DBMS is probably already doing. – StingyJack Dec 21 '20 at 18:52
    and GraphQL doesn't require you to know your GraphQL structure? – user253751 Dec 22 '20 at 18:33
  • @user253751, what I meant by that sentence is the inversion: by exposing SQL directly, you're pretty much required to expose all your tables - which is detailed in the next paragraph. Having a control of your underlying layer without exposure is extremely important, because it makes refactoring much easier, since clients do not depend on the implementation (the DB structure), they rely on the abstraction you've provided. ACL is better implemented in the application layer, along with other mechanism which prevent unwanted access to the data. – Andy Dec 22 '20 at 19:08
  • @Andy views and permissions solve the basic table access and operation security problem. I think Ewan gives a better explanation, there are more precarious features like temporary tales, etc, which are hard to reason about the consequences of. – Justin Meiners Apr 26 '21 at 17:59
  • Mindyou thats not to say your GraphQL implementation is doing much better job under the hood. Did some recent investigation on a popular Postgres to GraphQL server I shall decline to name due to an association we have with the company, we where using due to timeouts and memory hogging, and the SQL the thing was generating was *apalling*. I swear to god doing EXPLAIN over the result produced output that, could have been most succinctly described as "The query planner is currently traumatized". – Shayne May 27 '22 at 02:59
  • @Shayne, well that is expected, for high performance systems you are required to write the data layer yourself, not relying on some code generation. – Andy May 30 '22 at 08:49
  • Yeah. It wasn't my first choice, I'm much more a person who prefers a good spicy SQL statement. But this wasn't just bad, it was bafflingly bad, recursively bracketed WHERE TRUE=TRUE type clauses and the like. It was just weird that it even worked. But only barely. – Shayne Jun 01 '22 at 14:32
31
In theory there is no reason you can't expose an SQL interface like this.
In practice SQL is far too powerful to be effectively limited to the security scope you want to expose.
Even if you allow only read access, a bad query can still hog resources.
Other languages such as graphQL are designed to be exposed. They are merely giving users a filter option on what they could already see.
The benefit of using these languages is that they have gone through all the things you would want to stop users doing in SQL and taken them off the table.
Ewan
  • 70,664
  • 76
  • 161
    Thanks for the answer, but could you explain how GraphQL solve the problem of resource draining? A rogue GraphQL query can still say “tell me everything about each movie and their actors“, resulting in a huge graph, and exhausting my DBMS and network. – nalzok Apr 07 '19 at 03:14
  • But i can write a recursive SQL query that will lock your table and prevent other users from running any queries at all – Ewan Apr 07 '19 at 11:30
    the problem is not so much restricting access to tables, or deleting, but the shear complexity of SQL. will you allow temp table creation? what about executing CLI? loops? transactions? sub selects? cursors? how will you distinguish when the use of these things is acceptable and when its 'bad' – Ewan Apr 07 '19 at 11:38
    @Ewan, if there was a serious attempt to restrict the power of SQL, wouldn't that be done by implementing a parser for SQL and attaching additional security controls, rather than implementing a(nother) special query language whose only selling point is that it is less powerful? – Steve Dec 22 '20 at 08:00
    tricky if you have single commands that do both allowed and non-allowed operations. It's easier to create a new language from the ground up – Ewan Dec 22 '20 at 08:38
  • @Ewan, do you have an example of two operations which in SQL would have no syntactic distinction, but which a translation layer over SQL, like GraphQL, is capable of separating into syntactically distinct commands with different access control policies? – Steve Dec 22 '20 at 10:07
  • tricky, base graphql doesnt really let you do much at all. Consider SQL allows SELECT to generate data by defining a function. returning the result of a function is desirable, using functions in filters is desirable, but you can write infinite loops, so exposing the functionality is problematic. GraphQL simply doesn't have that depth, but you could implement your own functions and give them special names – Ewan Dec 22 '20 at 10:39
  • Your comment was the key point for me. You can limit access with users and views, but there are too many other features to reason safely about. – Justin Meiners Apr 26 '21 at 18:00
  • I should note, that some APIs *do* in fact implement a limited SQL subset for use over APIs. I don't necessarily trust them, but I must assume that whoever is implementing them must know what they are doing. Big companies and all that. – Shayne May 27 '22 at 03:01
  • This is another ridiculous answer. Metering of resources applies as much to GQL as to SQL. – Asclepius Aug 07 '22 at 21:51
Because almost nobody understand that SQL != RDBMS != Relational model.
SQL is just a query language. It does not even need a relational database system. It is not fully relational either.
It also neither demand that is implemented any more fancy that simple CRUD, and not even need to implement CRUD. It happily is used as just read-only query data back pls.
Is just an (happy) accident that SQL + RDBMS is such a powerful combo that both become conflated. Also, that SQL is standardized across so many RDBMS that some of the capabilities of them surface, meaning that it can look more complex that something anemic like GraphQL or Rest can even dream.
Also, that is extended to be crud + schema manipulation + scripting + anything anybody wants or needs.
SQL is THAT FLEXIBLE.
So, is totally valid to put SQL on top of HTTP and that not means that MUST be directly feed to the database. Can be, totally, alike GraphQL and have a in-memory resolver that do whatever it need to be transformed, later, to the "real" SQL of the RDBMS or ANYTHING ELSE, because is part of the relational model foundational designs to be a abstraction over storage and query.
That is why, you use SQL (tables) on top of Trees (B-Tree) or arrays (Columnar) or Graphs, or files, or whatever on the sun.
mamcx
  • 412
As others have mentioned, exposing SQL directly in the api is a very bad option. GraphQL, despite it's name, is not an abstraction for SQL, but for any data store or even other services.
If you are looking for an abstraction that is closer to SQL, you might want to have a look at odata (if you happen to work in .NET backends, though maybe other implementations exist).
jannikb
  • 231
  • This is another cult-following answer. There is no reason why SQL databases can't have imported tables and extensions. – Asclepius Aug 07 '22 at 21:53
if you want expose SQL like GraphQL, you will could need something like GraphQL, because you will need hide the important information and select what you want to show in the API, this for security.
GraphQl and SQL are different things, SQL is the language to query DataBase and GraphQL is only to manage the data from API,in API you will need make yours schemas to show and querys to manage it, etc.
in any API you will need make those things for simply security, but if you want something that is free data access maybe it would work, you know so many alternatives in the software world
Black Hole
  • 111
    Nonsense, because you can hide using SQL database views (and access restrictions) just the same. – Asclepius Aug 07 '22 at 21:55
  • @Asclepius you're right, that it's an error for my young version hahaha, views can work with the acesss of the data, thanks for show it – Black Hole Aug 08 '22 at 21:12
  • @Asclepius anyways that wasn't the point, was about the interface that GraphQL bring to you, this make you able to make querys from frontend and give to you very flexibility in an API. and with SQL you gonna need make the especific controllers and querys, and of course you can do the same (with UrlQueryParams) but graphQL does very well in this case. – Black Hole Aug 08 '22 at 21:16
