JSON
"hello": "world"
Protobuf
message HelloWorld {
required string name = 1;
Why do we say that protobuf uses binary format during network exchange and json don't, even though network always will transfer using binary data format?
pzk
    The question in your title is different than your question in the post. The JSON example you provided is the _message_, while the Protobuf example is the _schema_. You define the schema in a text file, but that doesn't mean the Protobuf message will be sent as text. Can you clarify your question? – Vincent Savard Apr 03 '19 at 13:21
  • Thanks @VincentSavard I was aware that I am putting schema, but I thought data would also be textual for protobuf (wrongly assumed, apologies). I was following logic of xml xsd as both are in text. – pzk Apr 03 '19 at 13:33
This would be more clear if you were comparing two more similar pieces of data with non-text data components.
For example, the following JSON is ALL text:
    "NumberOfClients": 20
The 20 is two separate characters in JSON, but would be represented as an actual binary integer in Protobuf, which in this case would be a single byte: ‭00010100‬
Further, I am not sure you are properly understanding Protobuf as you are comparing apples and oranges in your question. You are comparing JSON Data to a Protobuf Schema
TheCatWhisperer
  • 5,231
  • 41
    Ok, understood. Thanks for explanation. Though I knew I was putting schema in case of in case of protobuf, I wrongly assumed (apologies) that data would also be same. – pzk Apr 03 '19 at 13:31
  • Sounds very much to the all XMLBeans in Java. – Laiv Apr 03 '19 at 20:36
    The last paragraph of the answer seems to be the actual answer to the question - that 20 isn't "20" but 00010100 in the protobuf says more about JSON than about protobuf. I feel this answer would be better of that last line where made the main point. – Jory Geerts Apr 04 '19 at 14:21
  • @JoryGeerts noted, remedy attempted – TheCatWhisperer Apr 04 '19 at 16:08
