I'm designing an API for our web application, that will be consumed by mobile developers that will create our mobile app.
I chose to document it using Swagger / OpenAPI 3.0.0.
I'm surprised that when I create a new OpenAPI document on Swagger, I get a default version field set to 1.0.0.
The specification also uses 1.0.1 as an example.
While I understand very well, and implement myself, semantic versioning for open-source libraries, I fail to understand how this relates to APIs. An API is, by definition, always up-to-date, and I my gut feeling agrees with this answer on StackOverflow. Full quote:
APIs should only use major versions externally. Following best practice semantic versioning, major versions change when you introduce backwards-incompatible changes to a project.
If you're just adding features, or modifying existing ones in backwards-compatible ways, then you just do it and your existing consumers are not affected (though, they can then make use of the new changes if they want). Your API can change versions from 1.0.0 to 1.1.0 internally, but the version as exposed to your consumers is still just "v1".
If you're just patching bugs, the same applies. Change from 1.0.1 to 1.0.2 internally, but the API should stay at "v1".
Now, if you rename/remove resources, or do some other drastic changes that will break existing clients, your internal version might go from 1.2.0 to 2.0.0, because breaking backwards compatibility requires a major version change. Because of this, the new major version has to be exposed to your API's consumers as "v2".
So, in keeping with this, both your namespaces and your URLs should reflect only the major version (e.g. "v1"), and you should make sure that you never break backwards-compatibility within a major version.
Should I version my API using only a major version, or major.minor.patch as I would with an open-source library?
What's the point in introducing bug fixes and new features as new versions, when you can apply them to the existing version directly?
My main worry is that if I follow this convention, if I fix a bug on v1.0.0, and release the fix as v1.0.1, I would have to let developers know so that they could update to the next patch version, and then wait for end users to update their app.
Whereas if I apply the fix to a v1 API directly, the fix will instantly propagate.
What did I miss?
BenMorel
  • 283
  • Whoever downvoted, care to explain? – BenMorel Mar 25 '19 at 16:03
    If you minor-version an API under semantic versioning rules, doesn't the consumer of your API also know that a minor version change doesn't break the interface? – Robert Harvey Mar 25 '19 at 16:08
    In other words, why would clients be compelled to update to the next minor version of an API if the API itself remains unchanged? – Robert Harvey Mar 25 '19 at 16:09
    To put it another way, you assert in your question that it is possible to fix a bug or add a feature without breaking the API. A minor version change would alert the developers that such a change occurred without compelling them to upgrade. – Robert Harvey Mar 25 '19 at 16:13
  • What are the differences between a library and a Web API? Are not both APIs? SemVer is not about libs or Web APIs or the way you supply the API. Is about documentation. Backward compatibility documentation.. – Laiv Mar 25 '19 at 16:52
  • @Laiv: Well, sort of. Minor revisions are supposed to be non-breaking changes. Major revisions make no such assertion. That's true with or without supporting documentation. – Robert Harvey Mar 25 '19 at 18:34
  • Just to make It clear. You have quoted the above answer because you are versioning the API throught the URI path. Right? Note that Swagger doesn't version our API in that way. The field version is merely informative. – Laiv Mar 25 '19 at 22:22
    The [swagger docs](https://swagger.io/docs/specification/basic-structure/#metadata) indicate that the version is an arbitrary string, which they recommend follows semver but could be anything. I personally prefer to think of it as the version of the _documentation_, which is probably equal to or less than the version of the service that is run in production. Documentation can have errors, too! So, if you were adding documentation for buggy behavior, or errata for previous claims made by earlier versions of the docs, you would have reason to update a non-major version number. – Jesse Amano Mar 25 '19 at 22:24
  • Thanks all for your comments. I guess I mixed the *documentation version* with the *API version*. I guess what confused me is that Swagger creates an Auto Mocking API that has the version field in the URL: `https://virtserver.swaggerhub.com/Foo/Bar/1.0.0`. But this all makes sense now because if the API doc is updated, the mocking server should reflect changes accordingly. The live API, however, would handle all `1.x.x` versions at a single endpoint, and does not *need* to have the full version in the URL. – BenMorel Mar 26 '19 at 09:27
You should use major.minor.patch (or major.minor.patch.build)
Your quoted article is correct in that because the internal implementation is not exposed to the client, they wont care about anything other than the major version. Only a change which breaks the interface will affect them and by definition this would be a major change*
Your routing of requests should reflect this, you don't want to force clients to request a specific patch version.
However! for your own sanity you will care very much about the exact major.minor.patch.build version which is deployed to your many servers. You will want this version to be logged and reflected in the assembly versions which are deployed. So that you can do basic debugging and versioned deployments etc.
*You can imagine edge cases where the internal processing affects the result without breaking the interface. You can also imagine some clients not wanting the 'fixed' version for whatever reason.
What I normally do is allow the full version to be requested but route according to my own wishes. for example I might route:
v0.*.*.* -> unsupported error page  // all v0s go to an error page that tells the client to upgrade
v1.*.*.* -> v1.2.0.0   // all v1s go to the latest v1
v1.1.32.1 -> v1.1.32.1  //need for client who is audited on changes
*.*.*.* -> v2.2.0.0 // all not matched by other rules or unspecified go to my latest version
Ewan
  • 70,664
  • 76
  • 161
  • Thanks for your answer, it makes sense now. As I've mentioned in the comments above, I mixed the concepts of *documentation version* with *API version*, probably misled by Swagger's Auto Mocking API which uses the full version in the URL. I guess my API is simple enough to not justify the minor version separation you follow, and a `/v1/` endpoint will do. Your approach is very interesting though, thanks for sharing it! – BenMorel Mar 26 '19 at 09:33
  • A semantic api version is also useful if you allow other people to self host the application to deal with the case where the client software is using api 1.1 but the server is using 1.0 which will not work if the client is using anything added in 1.1 – Qwertie Apr 23 '19 at 06:16
