By default, the HTTP response code for "file not found" has always been 404. I never really thought about it until recently someone was saying that if the missing file is part of an application then the response should be 500 (internal server error) because it's not a client error (4xx error class). The example for that situation was when the deployment for media files failed.
So, in that situation, should the status be 404 or 500? If it's 404, what is the reason for that situation?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
imel96
  • 3,488
    404 is a client asking (or guessing) for something nobody knows if it exists. The server looks for it **and it does not fail at searching**. it just doesn't find it. 500 is the server failing at searching/serving the file due to a crash that was not meant to happens. – Laiv Mar 20 '19 at 13:53
  • @Laiv their idea is they don't want to show to users a 404 page because the client app doesn't have search feature. So, when the user stumble upon a broken link then it must be a server issue – imel96 Mar 20 '19 at 14:23
  • I think you need to clarify a bit here: for starters, is the file in question being retrieved by the call or is it some sort of configuration file? – JimmyJames Mar 20 '19 at 14:32
  • @JimmyJames basically files loaded by a Javascript client app – imel96 Mar 20 '19 at 14:36
    I agree with your friend. If a web application is borked because a file it needs to run properly is missing, on an URL that would otherwise be valid, it's a 500, not a 404. – Robert Harvey Mar 20 '19 at 14:46
  • While I understand the point, semantically is still a 404 if the server is not failing due to internal errors. it's a client requesting something (meant to exist) but for whatever reason, it doesn't. That said, following semantics is not a must, just keep in mind that you are interpreting them in your way. Using 500 could be misleading, overall among web developers (if you have any experienced in the team) – Laiv Mar 20 '19 at 15:01
    @Laiv I don't think that's right on the semantics. The text of the RFC states: "The 4xx (Client Error) class of status code indicates that the client seems to have erred." That's clearly not the case here. – JimmyJames Mar 20 '19 at 15:12
  • By the same reasoning, any 404 should be a 500 because "maybe" if there were something in the request URI, the client would not fail. Then there would not be a way to differentiate when the resource is really missing and when the server is failing due to real internal errors. – Laiv Mar 20 '19 at 15:25
Technically, if there's never a reason why this file should be unavailable when your application is configured and running properly, you probably should return a 500 (or 500 class error). It's an unexpected server side issue.
In practice, however, it's typical to use a 404 here because that's what web servers tend to do on static file retrieval. I wouldn't spend a lot of time on trying to fix this unless there's some meaningful impact either way.
JimmyJames
  • 24,682
  • 50
  • 92
    I agree, if we rely on semantics then a 5xx error would be the most indicated (the server is unable to fulfill the request as it has encountered an unexpected condition that prevents it from completing it successfully), however probably a 404 is the best choice when we talk about missing imported static files (usually a 5xx error implicitly refers to a malfunction, not to a missing file). Upvote for `I wouldn't spend a lot of time on trying to fix this unless there's some meaningful impact either way.` – n0idea Mar 22 '19 at 08:56
As far as I understand it, there is no way to know that "missing file is part of an application". Client comes with some URL "https://example.com/foo", and the "foo" is just not there. Was it client mistake of application improperly installed? You don't know, but generally you assume that the first is more probable. So it's 404. If you verify path some other way, and conclude that the path would be working if you install the application properly, then you can return some 5xx status, for example "503 Service Unavailable";
max630
  • 2,543
  • I'm going to upvote this, but no further analysis is required. If the application falls over because a deploy file is missing on an otherwise working URL, it's a 5xx. Very likely, the server with throw some sort of exception before it ever determines that the URL is valid. – Robert Harvey Mar 20 '19 at 14:44
