For example, suppose I have an android application, in simple, there are 3 activities :
MainActivity -> Main2Activity -> Main3Activity
,which user can visit them in sequence (eg: by button click), also there is some global data to show:
public class GlobalData{
public static String userId;
public class MainActivity extends AppCompatActivity {
//button click listener
public void toMain2Activity(View view){
Intent i = new Intent(this, Main2Activity.class);
this.startActivity(i);
public class Main2Activity extends AppCompatActivity {
public void toMain3Activity(View view){
Intent i = new Intent(this,Main3Activity.class);
public class Main3Activity extends AppCompatActivity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main3);
One day, Main3Activity needs to display userId in GlobalData, so I modify Main3Activity:
@Override
Toast.makeText(this,GlobalData.userId, Toast.LENGTH_LONG).show();
But according to Why is Global State so Evil?, I should avoid global state, so I try to pass the original data object instead of allowing global state, so I try to pass the global object to Main3Activity instead of share it everywhere:
public class GlobalData implements Serializable {
public String userId="user_67890";
private GlobalData globalData=new GlobalData();
i.putExtra("global",this.globalData);
private GlobalData globalData;
@Override
setContentView(R.layout.activity_main2);
this.globalData=(GlobalData)this.getIntent().getSerializableExtra("global");
Intent i = new Intent(this, Main3Activity.class);
@Override
GlobalData globalData=(GlobalData) this.getIntent().getSerializableExtra("global");
Toast.makeText(this,globalData.userId, Toast.LENGTH_LONG).show();
But I think avoiding global state is less maintainable and more unpredictable in my case because:
With global state, I don't need to modify Main2Activity, which seems more fit the open closed principle, but if I want to avoid global state, I need to modify all intermediate (eg:Main2Activity) UI from start(source of GlobalData) to terminal (UI that uses GlobalData), which my android application is usually one UI component is included by another UI in depth.
If I pass the GlobalData only when I need it, it means I may have many functions need to add something like "GlobalData globaldata=this.getIntent().getSerializableExtra..." and "Intent i=..." everywhere, which I think it is less readable
In the modified version, it is possible that the this.getIntent().getSerializableExtra is failed because I may forget to put the object into the intent, and I need to handle if I get GlobalData failed, which I think it is less maintainable
Usually the GlobalData is not involved in Unit Test because the GlobalData is usually displayed directly, so I think sharing GlobalData doesn't make the app harder to test
Using intent let me need to think how to write additional codes to pass data between same level UI components (eg:same Activity, from EditText to error message detail label)
As above, I think avoid global state is more evil than having global state in my case. So my question is, are "I'm writing android applications" and "follow open-closed principles" reasons to allow global state?
