Let's say I have a react component like this:
const MyComponent = ({data}) => (<div>{JSON.stringify(data)}</div>);
const myReduxSelector = (state, id) => state.someData[id];
export default connect(
    (state, ownProps) => ({
     data: myReduxSelector(state, ownProps.someId)
)(MyComponent);
Now this works fine, if the data already exists.
What's the tidiest way to handle this, if the data doesn't already exist?
The only way I can really see to to this, to add an onMount/construct function to dispatch an action that will fetch it.
eg.
class MyComponent extends React.Component {
    constructor(props) {
        super(props);
        if (!props.data) {
            this.props.fetchData();
    render() {
       const {data} = this.props;
       return <div>{JSON.stringify(data)</div>;
     (dispatch, ownProps) => ({
        fetchData: () => dispatch(createFetchDataAction(ownProps.someId))
)(MyComponent);
The problem with this is - say I have lots of components that all do this, it just becomes a pain to write and maintain.
Is there a tidy, established pattern for solving this problem? Use of redux-saga is acceptable.
dwjohnston
  • 2,543
  • 49
Sounds like a typical scenario for HOC (higher-order-component) or RenderProps if you prefer it that way. The component would receive the action type that needs to be fired and does so on it's componentWillMount.
Though it's 2019, so a custom effect (React Hook) that dispatches the action from a FunctionalComponentwould probably be the way to go with the current setup based on the information you provided.
andras
  • 212
