When writing a flow chart, I can understand that it is a best practice to generally read left-to-right or right-to-left per locale, and/or top-to-bottom and generally for the directional flow of the chart to be consistent.
But, when it comes to a diamond ("decision") element and its yes/no or true/false result arrows, is there a convention as to which one ought to be pointing down and which one to the side?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Douglas Held
  • 129
  • As far as I know, no. But I can't say that with any authority. Either way, whether there is or isn't - the important thing is to be consistent - even if your graph is different from many others, it will still be readable. – Baldrickk Feb 15 '19 at 12:32
  • No. You just “label” the outgoing arrows with T/F or Y/N and the like to say which is which. – PhD Feb 17 '19 at 17:18
Yes, there is such a convention, but it is not based on true or false. The "happy flow" will always be pointing down and any exceptional or side-tracked flow will be pointing left/right.
E.g. if you have a decision based on whether you are having to set up a new client or use an existing client, the existing client is the nice direction ==> go down.
Menno Hölscher
  • 195
No, there is no such convention. I have even seen flowcharts where both the yes and no (or true and false) arrows attached to the side of a decision element.
It all depends on how you can best get the idea across that you are showing in the diagram.
Bart van Ingen Schenau
  • 71,712
  • 110
  • 179
