I am writing a method in C# (SharePoint Services) which is supposed to return a SharePoint list name based on three conditions (Client, Country, and Location). There are multiple clients, countries and location, and the number is going to increase in the future.
Th method I wrote uses a series of "if" statements, nested into each other. It works fine, but I would like to think about maintainability of the method in future, and would really like to refactor it to something cleaner.
Can you give advice on any design patterns which would improve the code?
Here is the code:
if(client = "Client1")
    if(country = "Country1"
        if(location = "Location1"
           return ListMatchingTheCriteria;
        if(location = "Location2"
    if(country = "Country2"
if(client = "Client2")
geocodezip
  • 378
egurb
  • 181
In general a nested if is the clearest way to deal with this kind of thing.
However, if you have a structure to your conditions you can use a dictionary/hashmap etc to look up the result
private Dictionary<string key, ListMatchingTheCriteria value> options; //all the options go here
public GetResult(var whateverSelectionCritera)
    var key = whateverSelectionCritera.ToString(); //add together your various criteria into a unique value
    return options[key]; // or run the returned function etc
As I say, this is great when you have a simple pattern of criteria, but becomes complicated when you have exceptional cases.
There is also the classic OOP inheritance solution:
public class DefaultOption
    public virtual void Run();
public class OptionA : DefaultOption
   public override void Run();
Obviously this has the problem of how you select which class to instantiate initially.
RE: duplicate answers. I have a search and none of the duplicates seem to have definitive accepted answers. maybe we should have a community page of some kind.
Ewan
  • 70,664
  • 76
  • 161
