Simplified question with a working example: I want to reuse a std::unordered_map (let's call it umap) multiple times, similar to the following dummy code (which does not do anything meaningful). How can I make this code run faster?
#include <iostream>
#include <unordered_map>
#include <time.h>
unsigned size = 1000000;
void foo(){
std::unordered_map<int, double> umap;
umap.reserve(size);
for (int i = 0; i < size; i++) {
// in my real program: umap gets filled with meaningful data here
umap.emplace(i, i * 0.1);
// ... some code here which does something meaningful with umap
int main() {
clock_t t = clock();
for(int i = 0; i < 50; i++){
foo();
t = clock() - t;
printf ("%f s\n",((float)t)/CLOCKS_PER_SEC);
return 0;
In my original code, I want to store matrix entries in umap. In each call to foo, the key values start from 0 up to N, and N can be different in each call to foo, but there is an upper limit of 10M for indices. Also, values can be different (contrary to the dummy code here which is always i*0.1
I tried to make umap
a non-local variable, for avoiding the repeated memory allocation of umap.reserve()
in each call. This requires to call umap.clear()
at the end of foo
, but that turned out to be actually slower than using a local variable (I measured it).
