Is there a protocol or a convention that supports REST (ok, maybe we should use HTTP here instead) processing chain and some neat features to help with that? Let me explain what I mean.
Let's assume I have some public REST service available. Using HTTP GET, I have multiple static pictures, GIFs and movie clips available. Generally, I would like to take this data and send it to another REST endpoint, along with additional data about the recognized visual elements in the content. For example, if the image contains Steve Ballmer drinking tea, a description "Steve Ballmer drinking tea" is normally expected at the endpoint.
However, I don't have an image processing and recognition service available, but if there are some such services available somewhere on the internet, I'm happy. Even if one works exclusively with static images and another one with movies.
So, my application (let's call it MyApp) will do the following:
- Call service (let's call it Src) to retrieve the picture/GIF/video or whatever
- If that resource is a picture, send it to the picture recognition service, let's call it PRS, and retrieve a picture description
- If that resource is a video, send it to the video recognition service, let's call it VRS, and retrieve a description of the video
- Combine the picture/video content with description, pack it inside an archive and send it to the endpoint that expects the result, let's call it End
This means the data flow is:
MyApp -> Src -> MyApp -> PRS (or VRS) -> MyApp_> End -> MyApp (confirmation)
I am looking for the solution where data flow is this:
MyApp -> Src -> PRS (or VRS) -> End -> MyApp
This means that I only have to say to the Src: "Get the whatever video resource I want and forward it to PRS or VRS depending on the content; after that forward it to the End". Then Src takes the picture, sends it to PRS and says "process this, after that forward it (along with result of processing) to the End". You see, I don't want MyApp to be orchestrator of everything, additionally creating extra network traffic along the way.
Oh, btw, since I want it to be neatly archived, I need a zipping service in the chain, so the solution should look more like this:
MyApp -> Src -> PRS (or VRS) -> Zip -> End -> MyApp
One more thing is that I want MyApp to be informed about the percentage of processing, errors. I expect some asynchronous processing somewhere along the path (e.g. VRS is a good candidate) and everything to work correctly in that condition as well.
Does something like this exist? Something maybe most similar to the Unix/Linux piping. Like "web-pipe". Or something. If it does, I can't find it.
EDIT
I am looking for a protocol, convention, whatever fits my need and is neither tied for an existing framework (e.g. Spring, .NET MVC/WebApi, ...) nor a "proprietary" part of some existing technology (Java, .NET etc.) It should be something that just-works with (or via) existing HTTP. So any technology can use it. Maybe "concept" should be the proper term here. If it isn't something widespread already.
For example, there is basic authentication. It just works with any technology. It has its rules, do's and dont's. There are WebSockets, working just the same. I need something in that context.
