12
I was told most modern computers follow the same floating point standard, does this mean they will all get the same float answer for a given math operation if the inputs are the same?
I ask because i am researching into making an RTS game on a network, and syncing hundreds of unit's positions sounds like a bad way to go.
So if i send just inputs only, i need to guarentee all clients get the same result by having them run the simulation from those inputs.
I read that older RTS games used fixed point arithmetic, but i don't know if that is still required on modern computers if they all adhere to the same standard? I was also told that although imprecise, the result of floating point is deterministic for the same input (which i presume means any computer following the same standard gets the same imprecise result?).
Do computers still have deviations even if they follow the same float point standard?
I am writing this game in C# not sure if that matters though, thought i'd mention it anyway.
WDUK
  • 2,032
  • Even if they did, I wouldn’t use floats for that – Telastyn Dec 10 '18 at 04:51
  • What do you mean ? Why not? – WDUK Dec 10 '18 at 04:54
  • Use of floats may be undesirable anyway because behaviour might depend on the position on the map. Minecraft's [Far Lands](https://minecraft.gamepedia.com/Far_Lands) were a more notable example: movement, rendering, and terrain generation would get glitchy as you moved far away from the spawn point. – amon Dec 10 '18 at 10:30
  • This is a feature of the language if it guarantees a certain behavior or not. Java does. C# probably does too. Check the language definition - you may have to explicitly request a certain behavior. – Thorbjørn Ravn Andersen Jan 17 '23 at 08:15
6 Answers6
20
Unfortunately, yes, especially when you use C# (or another JIT compiled language). The problem which occurs here is that the JIT compilation stage on some processor architectures produces code which uses more CPU registers than on other architectures. This can lead to situations where on some machines, extended floating point precision is used for certain operations, whilst on other machines not. This means for every iterative calculation using doubles, there is a chance to produce different accumulated rounding errors.
That is not a hypothetical problem, I have first-hand experience with such deviations in contemporary engineering simulation software, on more or less modern hardware. This issue makes it really hard to create reliable regression tests for complex floating point calculations which produce exactly the same result on all machines involved.
Doc Brown
  • 199,015
  • 367
  • 565
  • This. Some root causes: IEEE Std 754 includes optional "should" clauses (e.g. NaN handling) and permits design alternatives (e.g. underflow detection). In as far as language bindings support the floating-point standard, they may still give leeway to the compiler when evaluating floating-point expressions, e.g. `FLT_EVAL_METHOD` in ISO C/C++. Transcendental functions (e.g. `sin`, `exp`, `log`) are largely unregulated by both the IEEE floating-point standard and programming language standards. A simple library version upgrade (e.g. a new `glibc` version) could cause results to differ. – njuffa Dec 10 '18 at 19:21
  • I've hit it myself in a game. The rocket flew fine on my laptop, would not fly on my desktop, completely identical installations. – Loren Pechtel Dec 11 '18 at 06:14
Floating Point Errors
Every floating point number accumulates imprecision as it is used for calculation. This is a simple fact of using an imprecise format to calculate in. The calculations are also sensitive to the order of calculation, commutativity is not guaranteed, ie: (a + b) + c may or may not be the same as a + (b + c).
Additionally processors do not necessarily have the same mantissa length as the memory standard. This can generate interesting behavior as the 32/64/128 bit float occasionally operate as if they have more bits.
Fixed-Point Errors
That being said fixed-point arithmetic can also accumulate errors. The difference is that fixed point numbers are clear about what precision is lost, and depending on the chosen operations can avoid rounding errors altogether. They also are commutative (a + b) + c = a + (b + c).
Which?
Which one to use depends entirely on what properties you need.
Floating point numbers:
  • give a vast range of values that become very fine grained close up, and progressively further apart at the extremes.
  • are sensitive to order of calculation
  • accumulate rounding errors over time.
  • can have erratic behaviour due to hardware/memory float size mismatch.
Fixed Point numbers:
  • give a smaller range of numbers with the same distance between any two consecutive numbers.
  • are less sensitive to the order of calculation
  • are clearer about rounding errors
  • can be worked with to minimise/avoid rounding issues.
Kain0_0
  • 15,888
    "fixed point numbers are clear about what precision is lost" - floating points are clear too, the difference is rather fixed point inaccuracies are more intuitive to ordinary life numbering – whatsisname Dec 10 '18 at 05:44
    So only fixed point guarantees all computers regardless of hardware etc will experience the same errors/precision loss? – WDUK Dec 10 '18 at 05:47
    Essentially, yes, because you can specify that your fixed point numbers are 32 or 64 bits, and they will be on all systems. Floating point numbers may be 32 or 64-bit, but the hardware may actually use 48 or 96 bits to do the calculation and convert to 32 or 64 bits at the end resulting in differences between different types of hardware. – user1118321 Dec 10 '18 at 05:53
  • @whatsisname While the floating point specifications are quite clear, you cannot easily tell me what rounding issues I will encounter in this sum: `(a + b * c) / d - e`. Excepting obvious issues like `NaN`, division by zero, or overflow/underflow it is possible for this expression to be incorrect. Add to that the impedence between memory and register in terms of precision and even a simple load/store from memory of the "same" floating point value will change the answer. – Kain0_0 Dec 10 '18 at 07:11
  • @Kain0_0: you're right, I can't easily tell you what I'll encounter, because I am not a floating point expert. That is exactly what is meant when I said "more intuitive to ordinary life numbering". When you say fixed point is "clear" and floating point is not, you make it sound as though floats are just seemingly randomly inaccurate. – whatsisname Dec 10 '18 at 22:04
  • @whatsisname Look at [the Accuracy Section](https://en.wikipedia.org/wiki/Floating-point_arithmetic). While fixed precision does have its own rounding issues, and there are non-representable numbers, it is quite clear that these exist and what they are. You could easily tell me where the issues are, no expert required. Floating point numbers on the other hand break many basic mathematical primitives in interesting ways. Ways which are not broken for integer or fixed-point mathematics, and unless known in advance can easily surprise even an expert. I do not recommend them for repeatability. – Kain0_0 Dec 10 '18 at 23:28
The answers given are light on relevant specifics (sadly a common problem with C# discussion). The problem isn't a trivial one, and much is written about it (it's often called "floating point determinism", a name which inevitably leads to people pointlessly arguing about what "determinism" means). Long story short it seems that a+b or a*b will always give the same answer, and it seems like the same executable will give the same results too (there might be caveats), the biggest problem seems to be what the compiler will do, namely arranging operations differently or even using different operations, which is going to be a problem if your game runs on different platforms. A way around this (for compiled languages) might be to use compiler options for a strict IEEE-754 compliance, which should avoid a reshuffling of operations that would ruin consistency across platforms, but another problem, again only when comparing different builds on different platforms, is that trigonometrical functions like say atan2() might give slightly different results due to different implementations, as in the code isn't the same at all so it might produce minute differences.
So if all your players are on Windows x86 64 bits running the same binary build (not really an option with C# because of JIT), you probably have nothing to worry about. Otherwise you might have problems, in which case you might want to check IEEE-754 compilation options, implement your own trigonometric functions or even do it all in fixed point, although even though the latter is a good approach it might not be necessary. This being said an advantage of using fixed point arithmetic for an RTS is that precision is consistent across the map, instead of having overkill precision around the origin and less and less precision towards the edges. But fixed point arithmetic isn't an easy drop-in replacement, you must carefully consider the format as well as what happens with each operation to maintain precision yet avoid overflows. There isn't one answer, Warcraft III uses fixed point arithmetic, Supreme Commander uses floating point arithmetic, but the use of C# should nudge one towards fixed point.
Some relevant discussion that goes more into details:
https://stackoverflow.com/questions/20963419/cross-platform-floating-point-consistency
https://stackoverflow.com/questions/57931671/portable-consistent-floats
https://www.yosoygames.com.ar/wp/2013/07/on-floating-point-determinism/
https://gafferongames.com/post/floating_point_determinism/
https://gamedev.stackexchange.com/questions/14776/how-are-deterministic-games-possible-in-the-face-of-floating-point-non-determini
You still need to be careful.
Conversion between floating point and decimal may give different results in very rare cases (depending on the quality of the compiler and standard library).
Standard library functions like sin, cos, exp may give slightly different results.
long double is quite likely to give different results, because it may be 64, 80, or 128 bits on current compilers.
Behaviour of denormalised numbers may be different.
Single precision operations may be executed in double precision, producing different results.
Fused multiply-add will give better, but different results.
Setting floating-point rounding mode and precision may or may not be respected, producing different results.
There are some macros that you can check to find out about compiler behaviour, for example if it will contract fp operations or perform them with higher precision than the source code says.
And practically every compiler has different compiler options to force the behaviour you want.
gnasher729
  • 42,090
  • 59
  • 119
No! At least not across different processor architectures. The C# standard says:
Floating-point operations may be performed with higher precision than the result type of the operation.
While C# generally attempt to be consistent across platforms, this is a concession to the differences in the underlying processors. For example the x86 processors internally uses 80-bit registers for floating-point operations. So if you perform an arithmetic operation on 64 bit double-precions floating point values, they will first get converted into 80 bit, then the operation is performed, and then the result is converted back into 64 bit.
Other processors may use different precisions internally (although they must use at least 64 bit to support C#). I believe the ARM processor use 64 bit floating points internally.
The standard states:
Other than delivering more precise results, this rarely has any measurable effects.
Sure, but "more precise" still means different, so operations may have different results across processors. And while the difference may be very small, subsequent operations may turn a small difference into a large difference.
If all your clients are using the same platform you will probably be safe, but the C# standard does not guarantee that floating point operations will give the same result across platforms.
JacquesB
  • 57,310
  • 127
  • 176
-3
There’s the question why you would want to guarantee identical results, since identical results give no guarantee at all that your results are useful.
You could have a numerically unstable algorithm that gives two identical but completely nonsensical results in different computers. If there are differences, but results are the same within 13 digits, that is much more trustworthy.
There are very few situations where reproducibility is really important: in a layout engine, or lossless compression/decompression. Using fixed point is very likely to be misguided.
gnasher729
  • 42,090
  • 59
  • 119
    I did not downvote your answer, but it seems the case described by the OP is exactly "one of those few situations where reproducibility is really important". In an RTS game, a small rounding error can make the difference between "two objects collided" or not. – Doc Brown Dec 10 '18 at 16:35
