Almost every blog post I've encountered around generic auth handling using JWTs in a React/Redux/Saga application does the same thing, which is to store the JWT in local storage, in the action/saga.
For example:
Example A (redux-saga):
function* authorize({ payload: { login, password } }) {
const options = {
body: JSON.stringify({ login, password }),
method: 'POST',
headers: { 'Content-Type': 'application/json' }
try {
const { token } = yield call(fetchJSON, '/login', options);
yield put({ type: AUTH_SUCCESS, payload: token });
localStorage.setItem('token', token);
} catch (error) {
let message;
switch (error.status) {
case 500: message = 'Internal Server Error'; break;
case 401: message = 'Invalid credentials'; break;
default: message = 'Something went wrong';
yield put({ type: AUTH_FAILURE, payload: message });
localStorage.removeItem('token');
function* Saga() {
yield takeLatest(AUTH_REQUEST, authorize);
function login(username, password) {
const requestOptions = {
method: 'POST',
headers: { 'Content-Type': 'application/json' },
body: JSON.stringify({ username, password })
return fetch(`${config.apiUrl}/users/authenticate`, requestOptions)
.then(handleResponse)
.then(user => {
// login successful if there's a jwt token in the response
if (user.token) {
// store user details and jwt token in local storage to keep user logged in between page refreshes
localStorage.setItem('user', JSON.stringify(user));
return user;
function logout() {
// remove user from local storage to log user out
localStorage.removeItem('user');
Now - storing JWTs in local storage aside - what concerns me - is the setting of state inside of the action creator/saga - rather than in a reducer.
My understanding is that action creators/sagas should be used just to determine the data to be used - and it is up to the reducers to actual store/persist the data.
Now of course - at its initial state, redux won't persist data. However, you can use a redux middleware like redux-persist to persist it to local storage (and there are other redux-persist middlewares to persist data to other places). Point here is - redux is the state management.
Why then - does everybody seem to just sidestep using redux as your application state when it comes to authentication?
