On a typical web app, we commonly have to deal the LOADING/SUCCESS/ERROR problem - which is that:
- When I make a backend request I want to display a loading cursor, perhaps disable some buttons.
- When the request finishes successfully, I want to display the data.
- When the request finishes with an error - I want to display or handle the error.
If you're not careful, this can lead to spaghetti code - especially if you're doing things like having two requests running at the same time, and managing that when one request ends, it doesn't stop the loading cursor for the other item, for example.
For redux only - I came across this solution which I found works pretty well.
Basically it you define three actions:
GET_FOO_REQUEST
GET_FOO_SUCCESS
GET_FOO_FAILURE
and then has a generic reducer that will intercept all requests and set in your redux state the loading and error state, for that particular request type (in this case GET_FOO
You can then select for the loading or error state on the component that needs it:
const loadingSelector = createLoadingSelector(['GET_FOO']);
const mapStateToProps = (state) => ({ isFetching: loadingSelector(state) });
My question is - if I'm using redux-saga - this this pattern still apply well - or does redux-saga already solve this problem?
