13
I work for a very large fortune 500 company who is subcontracted to another fortune 500 company on a DoD contract. As you can guess the red tape is tremendous to do anything.
We have simply shared a VM that is loaded up with Microsoft dev tools from someone elses MSDN subscription. When I have questioned our MSDN licensing, each time I was always told it is in the works. This has been going on for over a year now.
We also have other products that we are using that have a 30 day trial. One developer found an exploit to extend the 30 day trial infinitely, this approach has been encouraged by our management while they get the licensing "worked".
I have contacted 4 levels of managers on this program. No tangible action in over a year now.
What should I do? Report them to Microsoft and the other appropriate software vendors? Contact my companies ethics hotline? STFU and go with the flow?
Thanks
Ixrec
  • 27,621
  • 80
  • 87
    +1 because it's a great question, but unfortunately also a possible duplicate of [Usage of Pirated software at a company](http://programmers.stackexchange.com/questions/32830/usage-of-pirated-software-at-a-company) – Josh K Jan 19 '11 at 16:37
    @Josh - both questions are pretty similar. I think the difference is enough to add value to the site. This one is asking about reporting to outside authorities/groups which has much different possible outcomes than reporting it to an internal manager. – Walter Jan 19 '11 at 17:20
    @Walter: Good point, that's reasonable. – Josh K Jan 19 '11 at 18:14
At the end of the day, you need to understand that you are not responsibile for your employers actions when it comes to licensing. If they force you to use unlicensed software and they get audited for their software, it will come down on them, not you. It's their problem, and probably isn't a battle worth fighting.
George
  • 361
    This is a good point. A more important question is: do I want to work for a monster that large? – Job Jan 19 '11 at 20:06
  • George - yes you are correct it is the employers problem - PROVIDED you have brought it to the attention of the management. If you did it without the management consent you will be (rightly) hung out to dry. – quickly_now Jan 19 '11 at 22:35
In Fortune 500 companies there is often a Master Contract with a vendor like Microsoft that licenses the software in bulk to the company but the internal politics, budgets, product assignment and accounting procedures can hinder distribution internally for years. In other words your company likely has paid for the appropriate licenses but simply has not installed the products correctly. Until you know the dimensions of the Master Contract it is a wise idea not to make too much of an issue. Unless of course, you are a compliance officer and its your job to make an issue of these sorts of things.
kloucks
  • 209
    There should also be a compliance or s/w licensing person who has a clear responsibility to record s/w licenses in a central register, and who normally arranges purchase or updates records against the master contract. This person *should* be well known to those in the business who need to purchase and use software. – quickly_now Jan 19 '11 at 22:33
  • I might add that in this case, last I knew, MSDN subscriptions were tied to a person and thus not even transferable inside a company (let alone between companies). – quickly_now Jan 19 '11 at 22:34
    It's possible to transfer MSDN subscriptions. Also as Kloucks mentioned, there are MSDN Volume Licenses. Most likely his company has one...but they still have to account for usage on a per user basis...and using trial versions is definitely unethical at best. – Michael Brown Jan 19 '11 at 23:22
  • @quickly_now in one of the 3 F-500 companies I worked for the systems people would run automated scans to enumerate installed software and would update their records and the # of licensed seats based on the results of their scan. Additional seats were purchased if needed - BUT no one cared how the software got onto the machines only that the seat was paid for. Worse the people monitoring and paying for the licenses had nothing to do with the internal distribution of licensed software. They did pass all their audits though so reporting them to Microsoft, etc would only get the OP fired. – kloucks Jan 19 '11 at 23:49
  • Heh. Where I used to work, everything had to be purchased, there was a central officer, the records were immaculate. The central people also did scans periodically and asked when discrepancies were found. And the company passed its audit from a large well known s/w company with no problems or fines to pay. A first time for everything. – quickly_now Jan 20 '11 at 00:09
  • I don't want to seek the Fortune of that company ... – Chris May 27 '11 at 18:46
Given the size of the companies involved, the left hand may not know what the right hand is doing. I think I would notify the ethics office since they should be in a position to bring the two hands together. As others have stated this could very well be a site licensing issue.
Having worked in the software field for long enough I try to make sure software vendors are compensated for the products I use.
Jeff
  • 1,318
  • @Jeff, even Microsoft? ;) – Job Jan 19 '11 at 20:06
    When you go to the ethics office, make sure you have off-site copies of relevant e-mails where you tell appropriate people about the problems, in case your ethics department is as unethical as your bosses. – Michael Kohne Jan 19 '11 at 20:21
    @Job yes, you are using their product. I understand MS is a company everybody can hate, at times for good reason. That doesn't give anyone a free pass to act less ethically. – Jeff Jan 19 '11 at 20:39
  • @Michael I agree offsite documentation as proof that you took the required steps is important. – Jeff Jan 19 '11 at 20:44
  • +1: Keep your evidence in your "smoking gun" file, just in case. – quickly_now Jan 19 '11 at 22:32
  • Offsite documentation has been secured. –  Jan 24 '11 at 21:54
