You should use techniques to solve the problems they're good at solving when you have those problems. Dependency inversion and injection are no different.
Dependency inversion or injection is a technique that allows your code to decide on what implementation of a method gets called at run time. This maximizes the benefits of late binding. The technique is necessary when the language does not support run time replacement of non-instance functions. For example, Java lacks a mechanism to replace calls to a static method with calls to a different implementation; contrast with Python, where all that's necessary to replace the function call is to bind the name to a different function (reassign the variable holding the function).
Why would we want to vary the implementation of the function? There's a two main reasons:
- We want to use fakes for testing purposes. This allows us to test a class that depends on a database fetch without actually connecting to the database.
- We need to support multiple implementations. For example, we might need to set up a system that supports both MySQL and PostgreSQL databases.
You may also want to take note of inversion of control containers. This is a technique that is intended to help you avoid huge, tangled construction trees that look like this pseudocode:
thing5 = new MyThing5();
thing3 = new MyThing3(thing5, new MyThing10());
myApp = new MyApp(
new MyAppDependency1(thing5, thing3),
new MyAppDependency2(
new Thing1(),
new Thing2(new Thing3(thing5, new Thing4(thing5)))
new MyAppDependency15(thing5)
It lets you register your classes and then does the construction for you:
injector.register(Thing1); // Yes, you'd need some kind of actual class reference.
injector.register(Thing2);
injector.register(MyAppDepdency15);
injector.register(MyApp);
myApp = injector.create(MyApp); // The injector fills in all the construction parameters.
Note that it's simplest if the classes registered can be stateless singletons.
Word of caution
Note that dependency inversion should not be your go-to answer for decoupling logic. Look for opportunities to use parameterization instead. Consider this pseudocode method for example:
myAverageAboveMin()
dbConn = new DbConnection("my connection string");
dbQuery = dbConn.makeQuery();
dbQuery.Command = "SELECT * FROM MY_DATA WHERE x > :min";
dbQuery.setParam("min", 5);
dbQuery.Execute();
myData = dbQuery.getAll();
count = 0;
total = 0;
foreach (row in myData)
count++;
total += row.x;
return total / count;
We could use dependency inversion for some parts of this method:
class MyQuerier
private _dbConn;
MyQueries(dbConn) { this._dbConn = dbConn; }
fetchAboveMin(min)
dbQuery = this._dbConn.makeQuery();
dbQuery.setParam("min", min);
dbQuery.Execute();
return dbQuery.getAll();
class Averager
private _querier;
Averager(querier) { this._querier = querier; }
myAverageAboveMin(min)
myData = this._querier.fetchAboveMin(min);
count = 0;
total = 0;
count++;
total += row.x;
But we shouldn't, at least not completely. Notice that we've created a stateful class with Querier
. It now holds a reference to some essentially global connection object. This creates problems such as difficulty in understanding the overall state of the program and how different classes coordinate with each other. Notice also that we're forced to fake out the querier or the connection if we want to test the averaging logic. Further A better approach would be to increase parameterization:
class MyQuerier
fetchAboveMin(dbConn, min)
dbQuery.Execute();
class Averager
averageData(myData)
count = 0;
total = 0;
count++;
total += row.x;
class StuffDoer
private _querier;
private _averager;
StuffDoer(querier, averager)
this._averager = averager;
myAverageAboveMin(dbConn, min)
myData = this._querier.fetchAboveMin(dbConn, min);
return this._averager.averageData(myData);
And the connection would be managed at some even higher level that's responsible for the operation as a whole and knows what to do with this output.
Now we can test the averaging logic completely independently of the querying, and what's more we can use it in a wider variety of situations. We might question whether we even need the MyQuerier
and Averager
objects, and maybe the answer is that we don't if we don't intend to unit test StuffDoer
, and not unit testing StuffDoer
would be perfectly reasonable since it's so tightly coupled to the database. It might make more sense to just let integration tests cover it. In that case, we might be fine making fetchAboveMin
and averageData
into static methods.
