Can nested loop have linear time complexity?
Yes. Consider this function:
def linear_time(n):
for i in range(sqrt(n)):
for j in range(sqrt(n)):
something_that_takes_constant_time()
Its time complexity is O(sqrt(n) * sqrt(n)
) = O(n
Remember:
def foo(x):
part_a(x)
part_b(x)
# if part_a(x) has a time complexity of O(f(x))
# and if part_b(x) has a time complexity of O(g(x))
# then foo(x) has a time complexity of O(f(x) + g(x))
def foo(x):
loop f(x) times:
part_of_loop(x)
# if part_of_loop(x) has a time complexity of O(g(x))
# then foo(x) has a time complexity of O(f(x) * g(x))
So let's examine this algorithm:
Partition(a[], l, h)
pivot = a[l]; # O(1)
i = l; j = h; # O(1)
while(i < j) # runs ??? times
while(a[i] <= pivot) # runs O(h - l) times
i++; # O(1)
while(a[j] > pivot) # runs O(h - l) times
j--; # O(1)
if(i < j) # O(1)
swap(a[i], a[j]); # O(1)
swap(a[l], a[j]); # O(1)
return j; # O(1)
So the inner part of the loop has a time complexity of O((h - l) * 1 + (h - l) * 1 + 1 * 1) = O(h - l). But what is the time complexity of the whole loop? It runs as often as (i < j) is true.
The post condition after while(a[i] <= pivot)
is a[i] > pivot
, and after while(a[j] > pivot)
we have a[j] <= pivot
. If i < j
(the only case we care about, otherwise the loop will end anyway!), the values at the two indices are swapped, meaning that a[i] <= pivot
and a[j] > pivot
will be true once more. So, what it does is find the leftmost and rightmost indices that are on the wrong side of the pivot and swap them, until all of them are partitioned right. So how often does that loop run? We can't really say, it depends on how many elements are on the "wrong" side of the pivot. We do know that every loop after the first one i
and j
will be at least one step closer to each other, so the upper bound is going to be (h - l) / 2 + 1 which is of complexity O(h - l).
Now, I skipped over something: the number of times the outer loop runs is dependent on the number of times the inner loop runs. As the number of times the inner loops run tends towards O(h - l), the number of times the outer loop takes tends towards 1 and vice versa. They're sort of eating up each other's runs. The upper bound I mentioned in the previous paragraph is what we get when the inner loops run only once each time, making their complexity O(1). And it turns out, that whenever the inner loops run a
and b
times respectively, the number of times the outer loop runs in O((h - l) / (a + b)
. In other words, the complexity of the content of the outer loop is O(a + b)
and the number of times the outer loop runs has complexity O((h - l) / (a + b)
, making the whole loop have a time complexity of O((h - l) / (a + b) * (a + b)) = O(h - l)
, and thus this partition works in linear time.
(I do think there is a bug here: what happens if a[i] <= a[l]
for all l <= i <= h
