94
I have learned a significant amount of coding, however, it's always been in a scientific environment (not computer science), completely self-taught without anyone to guide me in the right direction. Thus, my coding journey has been ... messy. I've noticed now that whenever I build some type of program, by the end, I realize how I could have done it far more elegantly, far more efficiently, and in a way that is far more flexible and easy to manage going forward. In some circumstances, I've actually gone back and rebuilt things from the ground up, but usually this is not practically feasible. While most of my programs so far have been relatively small, it seems quite unwieldy to completely rewrite large programs every time you create something.
I'm just wondering, is this a normal experience? If not, how do you prevent this from happening? I've tried planning things in advance, but I can't seem to really foresee everything until I start hammering out some code.
Ashish
  • 359
  • 88
    its normal, program more – Ewan Oct 26 '18 at 06:21
    [Relevant](https://i.redditmedia.com/4oCCqWijqunXvVv_20c4VrysvRYKUdIEMGz7A8H2sEg.png?w=320&s=a6286767a319c8fe4997d7237fb95ef3). – Neil Oct 26 '18 at 08:37
    [Also kinda relevant](https://www.joelonsoftware.com/2000/04/06/things-you-should-never-do-part-i/) – Luke Oct 26 '18 at 10:18
    This [article](https://www.joelonsoftware.com/2000/04/06/things-you-should-never-do-part-i/) is a bit biased, but still an excellent read. – Vorac Oct 26 '18 at 10:23
  • 44
    Welcome to programming. If you don't look at old code and think "urgh" then you should start to worry as it means you've stopped learning. – Caltor Oct 26 '18 at 11:13
    Honestly when I saw this question, I laughed - because literally every programmer I've ever spoken too, including myself, has this feeling, constantly, at all times. If you wanted to go into a field where you felt like the end product you made had no flaws - programming was the wrong field to choose. – Zibbobz Oct 26 '18 at 13:45
    It is worth noting that sometimes, we forget why we made certain compromises. Hence redoing it, might not be as smart as it is tempting. – Chris Wohlert Oct 26 '18 at 13:45
    Have you tried reading about some of the many software refactors/rewrites which ended up being catastrophic failures? That could quickly reduce your eagerness to try. – Nemo Oct 26 '18 at 14:25
    You have to learn to love that feeling. I will be scared if I didn't feel it when reviewing my code from a year ago, because it would mean I stopped improving my skills – Pablo Lozano Oct 26 '18 at 14:46
  • What you can do is to separate the feeling of bad code (->refactor a bit) vs bad design (->refactor alsmost everything). The application i'm currently working on have some code I'd redo. But I don't see any point of redoing from scratch for the moment, because I have yet to know how I'd designed it better. Also if you validate the design of your application with peers , you should be able to have the feeling that you only want to rewrite some internals wheter the whole application or only change a moderate part of the design. – Walfrat Oct 26 '18 at 14:55
  • This is very common in programming, but especially common in scientific software development. If you're writing a program for a scientific purpose, it is likely multiple aspects of what you're doing have never been done before. Your design will inevitably change significantly because of hidden constraints that were completely unknown to you initially. Also, one rarely has the opportunity to invest in a lot of formal process when writing software for scientific data analysis because the software is not the product you're being paid to produce; generalizable knowledge is the product. – Matt Oct 26 '18 at 15:43
  • There's one pretty easy way to stop having that feeling: Be a bad programmer. After all, the hallmark of a bad programmer, as opposed to someone who is bad at programming, is that they _refuse to learn_. And that's what the "ew I could have done this better" feeling is -- a sign that you're learning. – Nic Oct 26 '18 at 16:22
  • You do not describe what is your process of coding... I mean do you just start, create a new project and start writing code? Or before that you try to think about what you want to achieve, what features you want to implement and start devising some high level architecture? Obviously you don't need to use the waterfall model but even Agile requires to think a bit ahead at the high level architecture before starting to write code. Maybe you need a little more whiteboard to organize your thoughts. Then implement one feature, and then review what you did and refactor it. Repeat for other features. – Bakuriu Oct 26 '18 at 17:11
  • I suggest trying it: rebuild your whole program from scratch. (If you are learning, not if someone is paying you to work...) – usul Oct 26 '18 at 19:41
    This question was put on hold because it is “only meaningful to the asker and does not generate lasting value for the broader community.” Meanwhile, every answer acknowledges it’s a universal problem. Come on. – Maxpm Oct 26 '18 at 20:28
    Ashish By ceasing to improve your skills. Unless you improve, you wont see anything wrong with what you built! Therefore fear the day where you stop wanting to recreate your projects! That means you have stopped improving, for whatever reason! – Aphton Oct 26 '18 at 20:48
14 Answers14
100
This is a very common experience
Most people I interact with, and I myself as well, feel like this. From what I can tell one reason for this is that you learn more about the domain and the tools you use as you write your code, which leads you to recognize many opportunities for improvement after you've already written your program.
The other reason is that you might have an idea in your head about the ideal clean code solution and then the real world and its messy limitations get in your way, forcing you to write imperfect work-arounds and hacks that may leave you dissatisfied.
"Everyone has a plan until they get punched in the face."
What to do about it
To some degree you will have to learn to accept that your code will never be perfect. One thing that helped me with that is the mindset of "If I hate the code I wrote a month ago, it means I have learned and become a better programmer".
A way to alleviate the issue is to constantly be on the lookout for potential improvements as you work and refactor continuously. Make sure to hit a good balance between refactoring and adding new features / fixing bugs. This won't help with big design issues, but it will generally leave you with a more polished code base you can be proud of.
    The only thing I'd add to this answer is, learn and follow TDD principles when writing code. Those tests then provide a secure environment for refactoring and rewriting as you continue to improve as a developer and want to make changes to existing code. – David Arno Oct 26 '18 at 07:55
    @DavidArno what's the point of refactoring with tests present? It's like upgrading a system and doing a backup before... 0 fun. – Džuris Oct 26 '18 at 10:10
    @Džuris, :) True, if you like challenges, don't write tests – David Arno Oct 26 '18 at 10:23
    @Džuris It's like jumping out of a plane wearing a parachute! – JollyJoker Oct 26 '18 at 11:25
  • For TTD principles see https://en.wikipedia.org/wiki/Test-driven_development – XavierStuvw Oct 26 '18 at 13:12
  • @Džuris I sincerely hope you're joking. Being familiar with the reality of the industry, I sincerely know that you're not. – Daniel Kamil Kozar Oct 26 '18 at 13:43
  • *The only true wisdom is in knowing you know nothing.* - Socrates – Zibbobz Oct 26 '18 at 14:23
  • Joking aside, the big problem with TDD is that it can produce a beautifully structured implementation of the worst algorithm possible that solves the problem. Of course if you want to make a beautiful looking program but you don't care that it's a thousand or a million times less efficient than it might have been, that won't worry you! – alephzero Oct 26 '18 at 14:51
    @alephzero that's not a problem with TDD - that's akin to saying that the problem with water is that you still starve. Code design and algorithm design are orthogonal to one another. TDD is about reinforcing the former and doing it well makes you free to explore the latter safely, maintaining correctness of the result. – Ant P Oct 26 '18 at 15:09
  • @AntP TDD, especially unit test-driven design, really encourages modularization, usage of things like interfaces and abstract classes to define contracts, etc. If you're trying to eke out every last nanosecond from a calculation (which I've had to do, it's a nightmare) then you don't often have the clock cycles required for indirection. And if you're writing Spectre-hardened code, you use indirection like that a lot less, which can be a challenge. TDD doesn't _prevent_ fast code, no, but it encourages things which can, in some cases, go against it. – Nic Oct 26 '18 at 16:27
  • @NicHartley if your design is preventing you from refactoring effectively (which it is if you can't make performance improvements to algorithms) then the wrong boundaries are being defined, which is a strong indicator of TDD being applied poorly (not a property of TDD itself). Lots of interfaces and mocks/stubs are the biggest symptom of this. The design will be crippling. This is unfortunately common. TDD applied well results in the opposite: Tests are not so granular - they cover meaningful *behavioural* units. Dependencies are not injected into components - they are removed from them... – Ant P Oct 26 '18 at 16:38
  • @AntP Sounds like you misread my comment. I didn't say "_good_ TDD encourages". Though even then, I've worked on projects which demand so much performance that you can't safely split behaviors apart on anything but the absolute largest lines, and trying to unit-test an entire physics engine would be... painful. Again, TDD doesn't _prevent_ fast code, but it encourages things which can, in some cases, go against it. (notice again the lack of any statement on the quality off the test code.) – Nic Oct 26 '18 at 16:39
  • @NicHartley fair enough - but alephzero's comment strongly implies that TDD in and of itself makes implementation changes difficult, which is the opposite of the truth when it's done well. If he'd said "the problem with TDD is that you can make things difficult for yourself if you do it badly," I'd probably have agreed :) – Ant P Oct 26 '18 at 16:49
  • @AntP Ah, fair enough. My concern isn't really with people who grok TDD and do it right, though -- those people are also smart enough to know when it has to be ditched, and how it can best fit their program. What I'm worried about are people who _assume_ they know how TDD works, and lean into it all the way, and make a calculation take an hour when it can legally take thirty minutes at most. (Or make it take a millisecond when you have 16 to work with, etc. etc.) – Nic Oct 26 '18 at 16:51
  • @David Arno: In addition to the other points re code efficiency, TDD is really not all that useful in a scientific environment. It assumes you know what the correct results of your tests are supposed to be, while science is experimental. – jamesqf Oct 26 '18 at 17:03
  • @NicHartley that's valid - and it is a genuine issue I come across frequently. I would even venture to say that *most* people I've come across who think they're "doing TDD" are doing themselves more harm than good... but that's true of unit testing in general, come to think of it. – Ant P Oct 26 '18 at 17:05
    @jamesqf - That's a mischaracterisation of what TDD and unit tests do - e.g. they can tell you that your model or algorithm is implemented correctly and that you haven't broken anything when you refactor. They can't tell you that your model is actually useful. That's as true in a scientific environment as it is in any other. – Ant P Oct 26 '18 at 17:18
45
Learn refactoring - the art of gradually improving code. We all learn all the time, so it is very common to realize that the code you have written yourself could be written in a better way.
But you should be able to transform the existing code to apply these improvements without having to start from scratch.
JonH
  • 304
JacquesB
  • 57,310
  • 127
  • 176
    This practice will also help you learn to write code that is modular and can be refactored more easily. All the lectures in the world didn't teach me this habit as much as having to break old big functions into manageable chunks so I wouldn't have to rewrite from scratch. Every new project, I do better at it. – JKreft Oct 26 '18 at 16:17
  • The best starting point in my opinion to learn about refactoring is: [Refactoring is about new features](https://www.codesimplicity.com/post/refactoring-is-about-features/) – Wildcard Oct 26 '18 at 19:38
If you have excellent static requirements and understand them well and have time for detailed analysis you have a chance that you can come up with a good design that you'll still be happy with when you're done.
Even in that blissful case, you may learn new language features that would have helped make a better design though.
However, usually, you won't be that lucky: the requirements will be less than stellar and incomplete and although you thought you understood them, it turns out that there are areas that you made invalid assumptions about.
Then, the requirements will change as the users get a look at your initial deliverables. Then something that the users don't control will change e.g. tax law.
All you can do is design, assuming that things will change. Refactor when you can, but realize that time and budget will often mean that your final deliverable is not as elegant as it would have been if you knew at the beginning what you know now.
Over time, you'll get better at digging into the requirements you receive and get a nose for which parts of your design are likely to need flexibility to absorb change.
In the end though, accept that change is constant and ignore the twinge that says "I could have done it better". Be proud and happy that you delivered a solution at all.
Wildbill
  • 99
  • Or, put a different way: Learn to design for *flexibility* from the start, without introducing unnecessary overheads. Ideally, the flexibility derives from simplicity. Then your design has a chance to pass the test of changing requirements. – cmaster - reinstate monica Oct 26 '18 at 11:40
This feeling is completely normal, and expected. It means you are learning. Almost every time I begin a new project, I start in one direction, and end up designing it differently in the end.
It's common practice to first develop a prototype before starting on the real thing. It's also common to revisit old code and refactor it. This is easier if your design is modular - you can easily redesign bits and pieces at a time without having to totally trash your old design.
For some people, it helps to write pseudo-code first. Others find it helpful to start with writing comments describing what the code will do, then write the code once the general structure is there. These two things will help you plan your design better, and might avoid the necessity of a rewrite.
If you are part of a team, having a review process is crucial to the design process. Have someone review your code so you can learn how to improve your design.
asrjarratt
  • 149
How can I avoid always feeling like if I completely rebuilt my program from scratch I'd do it much better?
What you could do is to create a throwaway prototype, before start doing the "real" project. Quick and dirty. Then, when you get a prototype to prove a concept, you get to know the system, and how to do things properly.
But do not be surprised, if after N years you come back to this code, and think "what a mess".
BЈовић
  • 13,981
  • 61
  • 81
    Or, you show the prototype to your boss, he say's 'Brilliant, that'll do.' moves you onto another project and your prototype becomes production. – RyanfaeScotland Oct 26 '18 at 13:20
    This advice is so common that there is a saying about it. "Build one to throw away". And that advice is so misused that there is a saying about it: "If you build one to throw away, you'll probably throw away two." – Eric Lippert Oct 26 '18 at 13:59
    @EricLippert My experience has been terrible in the opposite direction - if we build one to throw away, it inevitably gets shipped to the customer. – Jon Oct 26 '18 at 14:56
    @Jon: Yeah, that can happen, particularly when management mistakes "the user interface looks like it works" with there actually being any code there. That said, my experience has always been, as one of my coworkers used to say "we have enough time to build it wrong twice but not enough time to build it right once". :-) – Eric Lippert Oct 26 '18 at 15:56
  • @EricLippert That is exactly the reason to build the GUI last, and NOT build the GUI for a prototype ;) – BЈовић Oct 29 '18 at 07:46
Remember this mantra:
The perfect is the enemy of the good.
The perfect solution is not always the ideal solution. The ideal solution is the one which achieves the status "good enough" with the least amount of work.
  • Does it fulfill all the requirements regarding functionality and performance?
  • Is it free of critical bugs you can't fix in the current architecture?
  • Estimate how much work you will invest into maintaining this application in the future. Would the effort for rewriting be more than the long-term effort it would save?
  • Is there a possibility that your new design might actually make things worse?
If you answer yes to all of these questions, then your software is "good enough" and there is no good reason to rewrite it from scratch. Apply the design lessons you've learned to your next project instead.
It is perfectly normal for every programmer to have a couple of messy programs in their past. It happened several times over my career as a software developer that I looked at some code, wondered "What idiot wrote this mess?", checked the version history, and noticed that it was me from several years ago.
Philipp
  • 23,166
  • 61
  • 67
It is tempting to think that perfect planning will give you perfect software design/architecure, however, it turns out that's categorically false. There's two big problems with this. Firstly, "on paper" and "the code" rarely match, and the reason is because it's easy to say how it should be done as opposed to actually doing it. Secondly, unforeseen changes in requirements become apparent late in the development process that couldn't have been reasoned about from the onset.
Have you heard of the Agile movement? It's a way of thinking where we value "reacting to change" as opposed to "following a plan" (among other things). Here's the manifesto (it's a quick read). You can also read up about Big Design Up Front (BDUF) and what the pitfalls are.
Unfortunately, the corporate version of "Agile" is a bunch of bogus (certified scrum masters, heavy process in the name of "Agile", forcing scrum, forcing 100% code coverage, etc), and usually results in asinine process changes because managers think Agile is a process and a silver bullet (of which it is neither). Read the agile manifesto, listen to people who started this movement like Uncle Bob and Martin Fowler, and don't get sucked into the nonsense version of "corporate Agile".
In particular, you can usually get away with just doing TDD (Test Driven Development) on scientific code, and there's a good chance your software project will turn out pretty darn well. This is because successful scientific code mostly has ultra-usable interfaces, with performance as a secondary (and sometimes competing) concern, and so you can get away with a more "greedy" design. TDD kind of forces your software to be ultra-usable, because you write how you want things to be called (ideally) before you actually implement them. It also forces small functions with small interfaces that can quickly be called in a simple, "input"/"output" fashion, and it puts you in a good position to refactor in case requirements change.
I think we can all agree that numpy is successful scientific computing software. Their interfaces are small, super usable, and everything plays nicely together. Note that numpy's reference guide explicitly recommends TDD: https://docs.scipy.org/doc/numpy-1.15.1/reference/testing.html. I've used TDD in the past for SAR (Synthetic Aperature Radar) imaging software: and I can also assert that it works extremely well for that particular domain.
Caveat: The design part of TDD works less well in systems where a fundamental refactoring (like deciding that you need your software to be highly concurrent) would be hard, like in a distributed system. For instance, if you had to design something like Facebook where you have millions of concurrent users, doing TDD (to drive your design) would be a mistake (still okay to use after you have a preliminary design, and just do "test first development"). It's important to think about the resources and the structure of your application before jumping into the code. TDD will never lead you to a highly available, distributed system.
Given the above, it should be somewhat evident that a perfect design is actually impossible to achieve, so chasing a perfect design is a fools game. You can really only get close. Even if you think you can redesign from scratch, there are probably still hidden requirements that haven't shown themselves. Furthermore, rewrites take at least as long as it took to develop the original code. It almost certainly won't be shorter, since it's likely that the new design will have unforseen problems of its own, plus you have to re-implement all the features of the old system.
Another thing to consider is that your design only really matters when requirements change. It doesn't matter how bad the design is if nothing ever changes (assuming it's fully functional for the current use cases). I worked on a baseline that had a 22,000 line switch statement (the function was even longer). Was it terrible design? Heck yea, it was awful. Did we fix it? No. It worked just fine as it was, and that part of the system never really caused crashes or bugs. It only got touched once in the two years I was on the project, and someone, you guessed it, inserted another case into the switch. But it's not worth taking the time to fix something that is touched so infrequently, it just isn't. Let the imperfect design be as it is, and if it aint broke (or constantly breaking) then don't fix it. So maybe you could do better...but would it be worth a rewrite? What will you gain?
HTH.
I fully agree with the answer provided by Andreas Kammerloher yet I'm surprised no-one has yet suggested learning and applying some coding best practices. Of course this is no silver bullet, but using open-oriented approach, design patterns, understanding when your code smells and so on will make you a better programmer. Investigate what is the best use of libraries, frameworks etc. There's a lot more for sure, I'm just scratching the surface.
It doesn't mean you won't look at your old code as a total rubbish (you'll actually see the oldest programs even more rubbish than you do without this knowledge) but with every new piece of software you write you'll see you improve. Note also that the number of coding best practices increases over time, some simply change so you'll actually never get to perfection. Accept this or quite the path.
One more good thing is having a code revision. When you work alone it's easy to cut corners. If you have a second person reviewing your code, they'll be able to point out where you don't follow those best practices. This way you'll produce better code and you'll learn something.
Ister
  • 764
To add to the other excellent answers here, one thing I find helpful is knowing where you want to get to.
It's rare to be given the go-ahead for a major bit of refactoring on its own.  But you can often do smaller bits of refactoring as you go along, ‘under the radar’, as you work on each area of the codebase.  And if you have a goal in mind, you can take these opportunities to move, step by step, in the right direction.
It might take a long time, but most of the steps will improve the code, and the final result will be worth it.
Also, feeling like you could do better is a good sign!  It shows that you care about the quality of your work, and that you're evaluating it critically; so you're probably learning and improving.  Don't let these things worry you — but don't stop doing them!
gidds
  • 789
You have inadvertently stumbled upon one of mankind’s greatest challenges (adventures), the bridge between man and machine. The bridge between man and physical structure, Civil Engineering for example, has been in progress for about 200 years or more.
Since software development really only became mainstream in the 90’s, it is approximately 30 years old. We’ve learned that it is not so much an engineering discipline as a social science, and we have only just begun.
Yes, you will try TDD, Refactoring, Functional Programming, the Repository Pattern, Event Sourcing, MV something, Java Script (<- Do this, it’s crazy), Model Binding, No Sql, Containers, Agile, SQL (<- do this it’s powerful).
There is no one fix. Even the experts are still grasping at straws.
Welcome, and be warned, it’s a lonely place; but absolutely fascinating.
Marius
  • 89
I'm going to go a little against the grain. This is incredibly common, but it's not acceptable. What this indicates is that you're not recognizing good ways of organizing your code as you write it. The feeling comes from your code not being straightforward.
Your experience was mine for a long time as well, but recently (the past couple years), I've been producing more code that does not make me feel like I need to throw everything away. Here's roughly what I did:
  1. Be clear about what assumptions any particular block of code is making. Throw errors if they aren't met. Think about this in isolation, without depending on details about what the rest of the software is doing. (What the rest of the software is doing influences what assumptions you enforce and what use cases you support, but it doesn't influence whether you throw an error when an assumption is violated.)
  2. Stop believing following rules and patterns and practices will produce good code. Throw away mindsets and practices that aren't obvious and straightforward. This one was huge. OO and TDD are usually taught in a way that isn't grounded in practical considerations, as a set of abstract principles you should follow when writing code. But this is completely unhelpful for actually developing good code. If you use OO or TDD at all, it should be used as solutions to problems you understand you have. In other words, they should only be used when you look at a problem and think, "Okay, this makes complete sense and is extremely obvious as a good solution." Not before.
  3. When I'm writing code, focus on two questions:
    • Am I using features and libraries in the way they were designed to be used? This includes using it for the kinds of problems it was intended to solve, or at least very similar ones.
    • Is it simple? Will my coworkers and myself be able to follow the logic easily later on? Are there things that aren't immediately obvious from the code?
My code is now more "procedural," by which I mean it's organized by what actions it takes rather than what data structures it uses. I do use objects in languages where standalone functions cannot be replaced on the fly (C# and Java can't replace functions on the fly, Python can). I have a tendency to create more utility functions now, that just shove some annoying boilerplate out of the way so I can actually read the logic of my code. (E.g., when I needed to process all the combinations of items in a list, I shoved the index looping out to an extension method that returns Tuples so that the original function wouldn't be cluttered with those implementation details.) I pass a lot more things as parameters to functions now, instead of having a function reach out to some other object to fetch it. (The caller fetches or creates it instead and passes it in.) I now leave more comments that explain things that aren't obvious just from looking at the code, which makes following the logic of a method easier. I only write tests in limited cases where I'm concerned about the logic of something I just made, and I avoid using mocks. (I do more input/output testing on isolated pieces of logic.) The result is code that isn't perfect, but that actually seems okay, even 2 or 3 years later. It's code that responds fairly well to change; minor things can be added or removed or changed around without the entire system falling apart.
To some degree, you have to go through a period where things are a mess so that you have some experience to go off of. But if things are still so messed up that you want to throw it all away and start over, something is wrong; you're not learning.
jpmc26
  • 5,389
By remembering that your time is limited. And your future time is limited as well. Whether for work or school or personal projects, when it comes to working code, you have to ask yourself "is rewriting this the best use of my limited and valuable time?". Or maybe, "is this the most responsible use of my limited time"?
Sometimes the answer will be unequivocally yes. Usually not. Sometimes it'll be on the fence, and you'll have to use your discretion. Sometimes it's a good use of your time simply because of the things you'll learn by doing it.
I have a lot of projects, both work and personal, that would benefit from a port/rewrite. I also have other things to do.
Jared Smith
  • 1,620
It is a completely normal part of learning. You realize mistakes as you go.
That is how you get better and it is not something you should want to avoid.
mathreadler
  • 200
You can give yourself the experience to know that the seductive urge to rewrite is usually unproductive. Find some old, hairy, inelegant open source project of moderate complexity. Try to rewrite it from scratch and see how you do.
  • Did your from-scratch design end up as elegant as you hoped it would?
  • Is your solution really to the same exact problem? What features did you leave out? What edge cases did you miss?
  • What hard-earned lessons in the original project did you erase in the pursuit of elegance?
  • After you add those missing pieces back in to your design, is it as clean as it was without them?
Eventually, your instinct will shift from thinking "I could rewrite this system so much better" to thinking "this system's cruftiness may be indicative of some complexity that isn't immediately apparent."
Maxpm
  • 3,146
