I recently watched "All the Little Things" from RailsConf 2014. During this talk, Sandi Metz refactors a function that includes a large nested if-statement:
def tick
if @name != 'Aged Brie' && @name != 'Backstage passes to a TAFKAL80ETC concert'
if @quality > 0
if @name != 'Sulfuras, Hand of Ragnaros'
@quality -= 1
end
end
else
end
end
The first step is to break the function into several smaller ones:
def tick
case name
when 'Aged Brie'
return brie_tick
end
end
def brie_tick
@days_remaining -= 1
return if quality >= 50
@quality += 1
@quality += 1 if @days_remaining <= 0
end
What I found interesting was the way these smaller functions were written. brie_tick
, for example, was not written by extracting the relevant parts of the original tick
function, but from scratch by referring to the test_brie_*
unit tests. Once all of these unit tests passed, brie_tick
was considered done. Once all of the small functions were done, the original monolithic tick
function was deleted.
Unfortunately, the presenter seemed unaware that this approach led to three of the four *_tick
functions being wrong (and the other was empty!). There are edge cases in which the behaviour of the *_tick
functions differs from that of the original tick
function. For example, @days_remaining <= 0
in brie_tick
should be < 0
- so brie_tick
does not work correctly when called with days_remaining == 1
and quality < 50
What has gone wrong here? Is this a failure of testing - because there were no tests for these particular edge cases? Or a failure of refactoring - because the code should have been transformed step-by-step rather than rewritten from scratch?
